RTEMS 5.2-rc1
dpmemdata.h
1
9/* COPYRIGHT (c) 1989-2008.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef _RTEMS_RTEMS_DPMEMDATA_H
18#define _RTEMS_RTEMS_DPMEMDATA_H
19
20#include <rtems/rtems/dpmem.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
38typedef struct {
46 uint32_t length;
48
53
63#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE( max ) \
64 OBJECTS_INFORMATION_DEFINE( \
65 _Dual_ported_memory, \
66 OBJECTS_CLASSIC_API, \
67 OBJECTS_RTEMS_PORTS, \
68 Dual_ported_memory_Control, \
69 max, \
70 OBJECTS_NO_STRING_NAME, \
71 NULL \
72 )
73
76#ifdef __cplusplus
77}
78#endif
79
80#endif
81/* end of include file */
Classic Dual Ported Memory Manager API.
Objects_Information _Dual_ported_memory_Information
The Classic Dual Ported Memory objects information.
Object Handler Data Structures.
Definition: dpmemdata.h:38
Objects_Control Object
Definition: dpmemdata.h:40
uint32_t length
Definition: dpmemdata.h:46
void * external_base
Definition: dpmemdata.h:44
void * internal_base
Definition: dpmemdata.h:42
Definition: objectdata.h:39
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
