RTEMS 5.2-rc1
24#define DEFAULT_PHY_ADDRESS (0x01)
26#define PHY_BMCR (0x00)
27#define PHY_BMCR_RESET (1<<15)
28#define PHY_BMCR_LOOPBACK (1<<14)
29#define PHY_BMCR_SPEEDSEL (1<<13)
30#define PHY_BMCR_AN_ENA (1<<12)
31#define PHY_BMCR_PWRDWN (1<<11)
32#define PHY_BMCR_ISOLATE (1<<10)
33#define PHY_BMCR_RESTART_AN (1<<9)
34#define PHY_BMCR_DUPLEX_MODE (1<<8)
35#define PHY_BMCR_COLL_TEST (1<<7)
36#define PHY_BMSR (0x01)
37#define PHY_BMSR_100_T4 (1<<15)
38#define PHY_BMSR_100_TX_FD (1<<14)
39#define PHY_BMSR_100_TX_HD (1<<13)
40#define PHY_BMSR_10_T_FD (1<<12)
41#define PHY_BMSR_10_T_HD (1<<11)
42#define PHY_BMSR_PRESUP (1<<6)
43#define PHY_BMSR_AN_CMPL (1<<5)
44#define PHY_BMSR_REM_FLT (1<<4)
45#define PHY_BMSR_AN_AB (1<<3)
46#define PHY_BMSR_LINK_STAT (1<<2)
47#define PHY_BMSR_JABBDET (1<<1)
48#define PHY_BMSR_EXT_CAP (1<<0)
49#define PHY_PHYIDR1 (0x02)
50#define DEFAULT_PHYIDR1 (0x2000)
51#define PHY_PHYIDR2 (0x03)
52#define DEFAULT_PHYIDR2 (0x5C90)
53#define PHY_ANAR (0x04)
54#define PHY_ANAR_NP (1<<15)
55#define PHY_ANAR_RF (1<<13)
56#define PHY_ANAR_ASM_DIR (1<<11)
57#define PHY_ANAR_PAUSE (1<<10)
58#define PHY_ANAR_T4 (1<<9)
59#define PHY_ANAR_TX_FD (1<<8)
60#define PHY_ANAR_TX (1<<7)
61#define PHY_ANAR_10_FD (1<<6)
62#define PHY_ANAR_10 (1<<5)
63#define PHY_ANAR_SEL_MASK (0x0f)
64#define PHY_ANAR_SEL_SHIFT (0)
65#define PHY_ANAR_SEL_DEF (1)
66#define PHY_ANLPAR (0x05)
67#define PHY_ANLPAR_NP (1<<15)
68#define PHY_ANLPAR_ACK (1<<14)
69#define PHY_ANLPAR_RF (1<<13)
70#define PHY_ANLPAR_ASM_DIR (1<<11)
71#define PHY_ANLPAR_PAUSE (1<<10)
72#define PHY_ANLPAR_T4 (1<<9)
73#define PHY_ANLPAR_TX_FD (1<<8)
74#define PHY_ANLPAR_TX (1<<7)
75#define PHY_ANLPAR_10_FD (1<<6)
76#define PHY_ANLPAR_10 (1<<5)
77#define PHY_ANLPAR_SEL_MASK (0x0f)
78#define PHY_ANLPAR_SEL_SHIFT (0)
79#define PHY_ANLPARNP (0x05)
80#define PHY_ANLPARNP_NP (1<<15)
81#define PHY_ANLPARNP_ACK (1<<14)
82#define PHY_ANLPARNP_MP (1<<13)
83#define PHY_ANLPARNP_ACK2 (1<<12)
84#define PHY_ANLPARNP_TOGGLE (1<<11)
85#define PHY_ANLPARNP_CDE_MASK (0x03ff)
86#define PHY_ANER (0x06)
87#define PHY_ANER_PDF (1<<4)
88#define PHY_ANER_LP_NP_ABLE (1<<3)
89#define PHY_ANER_NP_ABLE (1<<2)
90#define PHY_ANER_PAGE_RX (1<<1)
91#define PHY_ANER_LP_AN_ABLE (1<<0)
92#define PHY_ANNPTR (0x07)
93#define PHY_ANNPTR_NP (1<<15)
94#define PHY_ANNPTR_MP (1<<13)
95#define PHY_ANNPTR_ACK2 (1<<12)
96#define PHY_ANNPTR_TOG_TX (1<<11)
97#define PHY_ANNPTR_CDE_MASK (0x03ff)
98#define PHY_PHYSTS (0x10)
99#define PHY_PHYSTS_MDIX_MDE (1<<14)
100#define PHY_PHYSTS_RCV_ERRL (1<<13)
101#define PHY_PHYSTS_POLSTAT (1<<12)
102#define PHY_PHYSTS_FCSL (1<<11)
103#define PHY_PHYSTS_SD (1<<10)
104#define PHY_PHYSTS_DESCL (1<<9)
105#define PHY_PHYSTS_PGREC (1<<8)
106#define PHY_PHYSTS_MIIIRQ (1<<7)
107#define PHY_PHYSTS_REM_FLT (1<<6)
108#define PHY_PHYSTS_JABBDET (1<<5)
109#define PHY_PHYSTS_AN_CMP (1<<4)
110#define PHY_PHYSTS_LOOPBACK (1<<3)
111#define PHY_PHYSTS_DUPLEX (1<<2)
112#define PHY_PHYSTS_SPEED (1<<1)
113#define PHY_PHYSTS_LINK (1<<0)
114#define PHY_MICR (0x11)
115#define PHY_MICR_TINT (1<<2)
116#define PHY_MICR_INTEN (1<<1)
117#define PHY_MICR_INT_OE (1<<0)
118#define PHY_MISR (0x12)
119#define PHY_MISR_ED_INT (1<<14)
120#define PHY_MISR_LINK_INT (1<<13)
121#define PHY_MISR_SPD_INT (1<<12)
122#define PHY_MISR_DUP_INT (1<<11)
123#define PHY_MISR_ANC_INT (1<<10)
124#define PHY_MISR_FHF_INT (1<<9)
125#define PHY_MISR_RHF_INT (1<<8)
126#define PHY_MISR_ED_INT_EN (1<<6)
127#define PHY_MISR_LINK_INT_EN (1<<5)
128#define PHY_MISR_SPD_INT_EN (1<<4)
129#define PHY_MISR_DUP_INT_EN (1<<3)
130#define PHY_MISR_ANC_INT_EN (1<<2)
131#define PHY_MISR_FHF_INT_EN (1<<1)
132#define PHY_MISR_RHF_INT_EN (1<<0)
133#define PHY_FCSCR (0x14)
134#define PHY_RECR (0x15)
135#define PHY_PCSR (0x16)
136#define PHY_PCSR_TQ_EN (1<<10)
137#define PHY_PCSR_SDFPMA (1<<9)
138#define PHY_PCSR_SD_OPT (1<<8)
139#define PHY_PCSR_DESC_TIME (1<<7)
140#define PHY_PCSR_F_100_OK (1<<5)
141#define PHY_PCSR_NRZI_BYPASS (1<<2)
142#define PHY_RBR (0x17)
143#define PHY_RBR_RMII_MODE (1<<5)
144#define PHY_RBR_RMII_REV1_0 (1<<4)
145#define PHY_RBR_RX_OVF_STS (1<<3)
146#define PHY_RBR_RX_UNF_STS (1<<2)
147#define PHY_RBR_ELAST_BUF1 (1<<1)
148#define PHY_RBR_ELAST_BUF0 (1<<0)
149#define PHY_LEDCR (0x18)
150#define PHY_LEDCR_DRV_SPDLED (1<<5)
151#define PHY_LEDCR_DRV_LNKLED (1<<4)
152#define PHY_LEDCR_DRV_ACTLED (1<<3)
153#define PHY_LEDCR_SPDLED (1<<2)
154#define PHY_LEDCR_LNKLED (1<<1)
155#define PHY_LEDCR_ACTLED (1<<0)
156#define PHY_PHYCR (0x19)
157#define PHY_PHYCR_MDIX_EN (1<<15)
158#define PHY_PHYCR_FORCE_MDIX (1<<14)
159#define PHY_PHYCR_PAUSE_RX (1<<13)
160#define PHY_PHYCR_PAUSE_TX (1<<12)
161#define PHY_PHYCR_BIST_FE (1<<11)
162#define PHY_PHYCR_PSR_15 (1<<10)
163#define PHY_PHYCR_BIST_STATUS (1<<9)
164#define PHY_PHYCR_BIST_START (1<<8)
165#define PHY_PHYCR_BP_STRETCH (1<<7)
166#define PHY_PHYCR_LED_CNFG1 (1<<6)
167#define PHY_PHYCR_LED_CNFG0 (1<<5)
168#define PHY_PHYCR_ADDR4 (1<<4)
169#define PHY_PHYCR_ADDR3 (1<<3)
170#define PHY_PHYCR_ADDR2 (1<<2)
171#define PHY_PHYCR_ADDR1 (1<<1)
172#define PHY_PHYCR_ADDR0 (1<<0)
173#define PHY_10BTSCR (0x1A)
174#define PHY_10BTSCR_SERIAL (1<<15)
175#define PHY_10BTSCR_SQ_MASK (0x07)
176#define PHY_10BTSCR_SQ_SHIFT (9)
177#define PHY_10BTSCR_LP_10_DIS (1<<8)
178#define PHY_10BTSCR_LP_DIS (1<<7)
179#define PHY_10BTSCR_FLINK_10 (1<<1)
180#define PHY_10BTSCR_POL (1<<4)
181#define PHY_10BTSCR_HB_DIS (1<<1)
182#define PHY_10BTSCR_JAB_DIS (1<<0)
183#define PHY_CDCTRL1 (0x1B)
184#define PHY_EDCR (0x1D)
