RTEMS
5.2-rc1
bsps
include
bsp
default-initial-extension.h
1
9
10
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Obere Lagerstr. 30
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_SHARED_DEFAULT_INITIAL_EXTENSION_H
24
#define LIBBSP_SHARED_DEFAULT_INITIAL_EXTENSION_H
25
26
rtems.h
27
28
#ifdef __cplusplus
29
extern
"C"
30
#endif
/* __cplusplus */
31
40
void
bsp_fatal_extension(
41
rtems_fatal_source
source,
42
bool
always_set_to_false,
43
rtems_fatal_code error
44
45
46
#define BSP_INITIAL_EXTENSION \
47
{ NULL, NULL, NULL, NULL, NULL, NULL, NULL, bsp_fatal_extension, NULL }
48
49
#ifdef __cplusplus
50
51
#endif
/* __cplusplus */
52
53
#endif
/* LIBBSP_SHARED_DEFAULT_INITIAL_EXTENSION_H */
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition:
interr.h:47
rtems.h
