RTEMS 5.2-rc1
cs8900.h
1/*
2 ------------------------------------------------------------------------
3
4 Copyright Cybertec Pty Ltd, 2000
5 All rights reserved Cybertec Pty Ltd, 2000
6
7 Port to the DIMM PC copyright (c) 2004 Angelo Fraietta
8 This project has been assisted by the Commonwealth Government
9 through the Australia Council, its arts funding and advisory body.
10
11 COPYRIGHT (c) 1989-1998.
12 On-Line Applications Research Corporation (OAR).
13
14 The license and distribution terms for this file may be
15 found in the file LICENSE in this distribution or at
16 http://www.rtems.org/license/LICENSE.
17
18 ------------------------------------------------------------------------
19
20 CS8900 RTEMS driver.
21
22 This is a generic driver that requires a BSP backend. The BSP backend
23 provides the glue to the specific bus for the target hardware. It has
24 been tested with Coldfire processors, and the PC. These targets have
25 completely different bus, byte order and interrupt structures.
26
27 An example BSP backend is provided in the pci386 BSP.
28
29 The BSP provides the following functions:
30
31 cs8900_io_set_reg
32 cs8900_io_get_reg
33 cs8900_mem_set_reg
34 cs8900_mem_get_reg
35 cs8900_put_data_block
36 cs8900_get_data_block
37 cs8900_tx_load
38 cs8900_attach_interrupt
39 cs8900_detach_interrupt
40
41 The header file provides documentation for these functions. There
42 are four types of functions.
43
44 The I/O set/get functions access the CS8900 I/O registers via the
45 I/O Mode. For example on a PC with an ISA bus you would use the
46 IA32 in/out port instructions. The cs8900_device structure passed
47 to these functions provide these functions with the I/O base
48 address. The BSP must provide these functions.
49
50 The Memory set/get functions access the CS8900 internal registers
51 and frame buffers directly from a 4K byte block of host memory.
52 Memory mode provides a faster access to the CS8900. The cs8900_device
53 structure passed to these functions provides the memory base
54 address. The BSP needs to provide these functions but they do not
55 need to be implemented if the mem_base field is set to 0. The
56 driver will use I/O mode only.
57
58 The Block transfer functions are used to read or write a block
59 of memory from the CS8900. This saves the driver making a number
60 of small calls. The BSP driver must know if I/O or Memory mode
61 can be used.
62
63 The final group of functions is to handle interrupts. The BSP
64 must take care of save and restoring any interrupt state
65 information.
66
67 The BSP declares a 'cs8900_device' structure for each device being
68 attached to the networking stack. It also creates a
69 'struct rtems_bsdnet_ifconfig' which is used to attach the interface
70 to the networking stack. The following code declares the BSD config:
71
72 static cs8900_device cs8900;
73
74 static struct rtems_bsdnet_ifconfig cs8900_ifconfig =
75 {
76 "cs0",
77 cs8900_driver_attach,
78 NULL,
79 NULL,
80 NULL,
81 NULL,
82 0,
83 0,
84 0,
85 0,
86 0,
87 0,
88 0,
89 0
90 };
91
92 The device linked to the BSD config structure with:
93
94 cs8900_ifconfig.drv_ctrl = &cs8900;
95
96 If you have a specific hardware address you should point the BSD
97 config structure to that address. If you do not the driver will read
98 the MAC address from the CS8900. This assumes the CS8900 has read
99 the address from an external EEPROM or has been setup by a BIOS or
100 boot monitor. For EEPROM less you need to supply the MAC address.
101
102 Set the I/O and Memory base addresses. If the Memory base address
103 is 0 the driver will use I/O mode only. A typical initialisation
104 looks like:
105
106 printf ("RTEMS BSD Network initialisation.\n");
107 rtems_bsdnet_initialize_network ();
108
109 #define ETHERNET_IO_BASE 0x300
110 #define ETHERNET_MEM_BASE 0
111 #define ETHERNET_IRQ_LEVEL 0
112
113 cs8900_device *cs = &cs8900;
114
115 memset (cs, 0, sizeof (cs8900_device));
116
117 cs->dev = 0;
118 cs->io_base = ETHERNET_IO_BASE;
119 cs->mem_base = ETHERNET_MEM_BASE;
120 cs->irq_level = ETHERNET_IRQ_LEVEL;
121 cs->rx_queue_size = 30;
122
123 cs8900_ifconfig.drv_ctrl = &cs8900;
124
125 printf ("CS8900 initialisation\n");
126
127 rtems_bsdnet_attach (&cs8900_ifconfig);
128
129 flags = IFF_UP;
130 if (rtems_bsdnet_ifconfig (cs8900_ifconfig.name,
131 SIOCSIFFLAGS,
132 &flags) < 0)
133 {
134 printf ("error: can't bring up %s: %s\n",
135 cs8900_ifconfig.name, strerror (errno));
136 return;
137 }
138
139 rtems_bsdnet_do_bootp_and_rootfs ();
140
141 The IRQ level is the one documented in the CS8900 datasheet and below
142 in the CS8900 device structure. You need to map your target IRQ to the
143 CS8900 in the BSP driver.
144
145 */
146
147#if !defined(_CS8900_H_)
148#define _CS8900_H_
149
150#include <rtems.h>
151#include <rtems/error.h>
152#include <rtems/rtems_bsdnet.h>
153
154#include <sys/param.h>
155#include <sys/mbuf.h>
156#include <sys/socket.h>
157#include <sys/sockio.h>
158
159#include <net/if.h>
160
161#include <netinet/in.h>
162#include <netinet/if_ether.h>
163
164/* #include <target.h> what does this provide? joel to chris */
165
166#define ET_MINLEN 60
167
168/*
169 * CS8900 device register definitions
170 */
171
172/*
173 * Crystal ESIA product id.
174 */
175
176#define CS8900_ESIA_ID (0x630e)
177
178/*
179 * IO Registers.
180 */
181
182#define CS8900_IO_RX_TX_DATA_PORT0 (0x0000)
183#define CS8900_IO_TX_TX_DATA_PORT1 (0x0002)
184#define CS8900_IO_TxCMD (0x0004)
185#define CS8900_IO_TxLength (0x0006)
186#define CS8900_IO_ISQ (0x0008)
187#define CS8900_IO_PACKET_PAGE_PTR (0x000a)
188#define CS8900_IO_PP_DATA_PORT0 (0x000c)
189#define CS8900_IO_PP_DATA_PORT1 (0x000e)
190
191/*
192 * Packet Page Registers.
193 */
194
195/*
196 * Bus Interface Registers.
197 */
198
199#define CS8900_PP_PROD_ID (0x0000)
200#define CS8900_PP_IO_BASE (0x0020)
201#define CS8900_PP_INT (0x0022)
202#define CS8900_PP_DMA_CHANNEL (0x0024)
203#define CS8900_PP_DMA_SOF (0x0026)
204#define CS8900_PP_DMA_FRM_CNT (0x0028)
205#define CS8900_PP_DMA_RX_BCNT (0x002a)
206#define CS8900_PP_MEM_BASE (0x002c)
207#define CS8900_PP_BPROM_BASE (0x0030)
208#define CS8900_PP_BPROM_AMASK (0x0034)
209#define CS8900_PP_EEPROM_CMD (0x0040)
210#define CS8900_PP_EEPROM_DATA (0x0042)
211#define CS8900_PP_RX_FRAME_BCNT (0x0050)
212
213/*
214 * Configuration and Control Registers.
215 */
216
217#define CS8900_PP_RxCFG (0x0102)
218#define CS8900_PP_RxCTL (0x0104)
219#define CS8900_PP_TxCFG (0x0106)
220#define CS8900_PP_TxCMD_READ (0x0108)
221#define CS8900_PP_BufCFG (0x010a)
222#define CS8900_PP_LineCFG (0x0112)
223#define CS8900_PP_SelfCTL (0x0114)
224#define CS8900_PP_BusCTL (0x0116)
225#define CS8900_PP_TestCTL (0x0118)
226
227/*
228 * Status and Event Registers.
229 */
230
231#define CS8900_PP_ISQ (0x0120)
232#define CS8900_PP_RxEvent (0x0124)
233#define CS8900_PP_TxEvent (0x0128)
234#define CS8900_PP_BufEvent (0x012c)
235#define CS8900_PP_RxMISS (0x0130)
236#define CS8900_PP_TxCol (0x0132)
237#define CS8900_PP_LineST (0x0134)
238#define CS8900_PP_SelfST (0x0136)
239#define CS8900_PP_BusST (0x0138)
240#define CS8900_PP_TDR (0x013c)
241
242/*
243 * Initiate Transmit Registers.
244 */
245
246#define CS8900_PP_TxCMD (0x0144)
247#define CS8900_PP_TxLength (0x0146)
248
249/*
250 * Address Filter Registers.
251 */
252
253#define CS8900_PP_LAF (0x0150)
254#define CS8900_PP_IA (0x0158)
255
256/*
257 * Frame Location.
258 */
259
260#define CS8900_PP_RxStatus (0x0400)
261#define CS8900_PP_RxLength (0x0402)
262#define CS8900_PP_RxFrameLoc (0x0404)
263#define CS8900_PP_TxFrameLoc (0x0a00)
264
265/*
266 * Bit Definitions of Registers.
267 */
268
269/*
270 * IO Packet Page Pointer.
271 */
272
273#define CS8900_PPP_AUTO_INCREMENT (0x8000)
274
275/*
276 * Reg 3. Receiver Configuration.
277 */
278
279#define CS8900_RX_CONFIG_SKIP_1 (1 << 6)
280#define CS8900_RX_CONFIG_STREAM_ENABLE (1 << 7)
281#define CS8900_RX_CONFIG_RX_OK (1 << 8)
282#define CS8900_RX_CONFIG_RX_DMA (1 << 9)
283#define CS8900_RX_CONFIG_RX_AUTO_DMA (1 << 10)
284#define CS8900_RX_CONFIG_BUFFER_CRC (1 << 11)
285#define CS8900_RX_CONFIG_CRC_ERROR (1 << 12)
286#define CS8900_RX_CONFIG_RUNT (1 << 13)
287#define CS8900_RX_CONFIG_EXTRA_DATA (1 << 14)
288
289/*
290 * Reg 4. Receiver Event.
291 */
292
293#define CS8900_RX_EVENT_HASH_IA_MATCH (1 << 6)
294#define CS8900_RX_EVENT_DRIBBLE_BITS (1 << 7)
295#define CS8900_RX_EVENT_RX_OK (1 << 8)
296#define CS8900_RX_EVENT_HASHED (1 << 9)
297#define CS8900_RX_EVENT_IA (1 << 10)
298#define CS8900_RX_EVENT_BROADCAST (1 << 11)
299#define CS8900_RX_EVENT_CRC_ERROR (1 << 12)
300#define CS8900_RX_EVENT_RUNT (1 << 13)
301#define CS8900_RX_EVENT_EXTRA_DATA (1 << 14)
302
303/*
304 * Reg 5. Receiver Control.
305 */
306
307#define CS8900_RX_CTRL_HASH_IA_MATCH (1 << 6)
308#define CS8900_RX_CTRL_PROMISCUOUS (1 << 7)
309#define CS8900_RX_CTRL_RX_OK (1 << 8)
310#define CS8900_RX_CTRL_MULTICAST (1 << 9)
311#define CS8900_RX_CTRL_INDIVIDUAL (1 << 10)
312#define CS8900_RX_CTRL_BROADCAST (1 << 11)
313#define CS8900_RX_CTRL_CRC_ERROR (1 << 12)
314#define CS8900_RX_CTRL_RUNT (1 << 13)
315#define CS8900_RX_CTRL_EXTRA_DATA (1 << 14)
316
317/*
318 * Reg 7. Transmit Configuration.
319 */
320
321#define CS8900_TX_CONFIG_LOSS_OF_CARRIER (1 << 6)
322#define CS8900_TX_CONFIG_SQ_ERROR (1 << 7)
323#define CS8900_TX_CONFIG_TX_OK (1 << 8)
324#define CS8900_TX_CONFIG_OUT_OF_WINDOW (1 << 9)
325#define CS8900_TX_CONFIG_JABBER (1 << 10)
326#define CS8900_TX_CONFIG_ANY_COLLISION (1 << 11)
327#define CS8900_TX_CONFIG_16_COLLISION (1 << 15)
328
329/*
330 * Reg 8. Transmit Event.
331 */
332
333#define CS8900_TX_EVENT_LOSS_OF_CARRIER (1 << 6)
334#define CS8900_TX_EVENT_SQ_ERROR (1 << 7)
335#define CS8900_TX_EVENT_TX_OK (1 << 8)
336#define CS8900_TX_EVENT_OUT_OF_WINDOW (1 << 9)
337#define CS8900_TX_EVENT_JABBER (1 << 10)
338#define CS8900_TX_EVENT_16_COLLISIONS (1 << 15)
339
340/*
341 * Reg 9. Transmit Command Status.
342 */
343
344#define CS8900_TX_CMD_STATUS_TX_START_5 (0 << 6)
345#define CS8900_TX_CMD_STATUS_TX_START_381 (1 << 6)
346#define CS8900_TX_CMD_STATUS_TX_START_1021 (2 << 6)
347#define CS8900_TX_CMD_STATUS_TX_START_ENTIRE (3 << 6)
348#define CS8900_TX_CMD_STATUS_FORCE (1 << 8)
349#define CS8900_TX_CMD_STATUS_ONE_COLLISION (1 << 9)
350#define CS8900_TX_CMD_STATUS_INHIBIT_CRC (1 << 12)
351#define CS8900_TX_CMD_STATUS_TX_PAD_DISABLED (1 << 13)
352
353/*
354 * Reg B. Buffer Configuration.
355 */
356
357#define CS8900_BUFFER_CONFIG_SW_INT (1 << 6)
358#define CS8900_BUFFER_CONFIG_RX_DMA_DONE (1 << 7)
359#define CS8900_BUFFER_CONFIG_RDY_FOR_TX (1 << 8)
360#define CS8900_BUFFER_CONFIG_TX_UNDERRUN (1 << 9)
361#define CS8900_BUFFER_CONFIG_RX_MISSED (1 << 10)
362#define CS8900_BUFFER_CONFIG_RX_128_BYTES (1 << 11)
363#define CS8900_BUFFER_CONFIG_TX_COL_OVF (1 << 12)
364#define CS8900_BUFFER_CONFIG_RX_MISSED_OVF (1 << 13)
365#define CS8900_BUFFER_CONFIG_RX_DEST_MATCH (1 << 15)
366
367/*
368 * Reg C. Buffer Event.
369 */
370
371#define CS8900_BUFFER_EVENT_SW_INT (1 << 6)
372#define CS8900_BUFFER_EVENT_RX_DMA_DONE (1 << 7)
373#define CS8900_BUFFER_EVENT_RDY_FOR_TX (1 << 8)
374#define CS8900_BUFFER_EVENT_TX_UNDERRUN (1 << 9)
375#define CS8900_BUFFER_EVENT_RX_MISSED (1 << 10)
376#define CS8900_BUFFER_EVENT_RX_128_BYTES (1 << 11)
377#define CS8900_BUFFER_EVENT_RX_DEST_MATCH (1 << 15)
378
379/*
380 * Reg 13. Line Control.
381 */
382
383#define CS8900_LINE_CTRL_RX_ON (1 << 6)
384#define CS8900_LINE_CTRL_TX_ON (1 << 7)
385#define CS8900_LINE_CTRL_AUI (1 << 8)
386#define CS8900_LINE_CTRL_10BASET (0 << 9)
387#define CS8900_LINE_CTRL_AUTO_AUI_10BASET (1 << 9)
388#define CS8900_LINE_CTRL_MOD_BACKOFF (1 << 11)
389#define CS8900_LINE_CTRL_POLARITY_DISABLED (1 << 12)
390#define CS8900_LINE_CTRL_2_PART_DEF_DISABLED (1 << 13)
391#define CS8900_LINE_CTRL_LO_RX_SQUELCH (1 << 14)
392
393/*
394 * Reg 14. Line Status.
395 */
396
397#define CS8900_LINE_STATUS_LINK_OK (1 << 7)
398#define CS8900_LINE_STATUS_AUI (1 << 8)
399#define CS8900_LINE_STATUS_10_BASE_T (1 << 9)
400#define CS8900_LINE_STATUS_POLARITY_OK (1 << 12)
401#define CS8900_LINE_STATUS_CRS (1 << 14)
402
403/*
404 * Reg 15. Self Control.
405 */
406
407#define CS8900_SELF_CTRL_RESET (1 << 6)
408#define CS8900_SELF_CTRL_SW_SUSPEND (1 << 8)
409#define CS8900_SELF_CTRL_HW_SLEEP (1 << 9)
410#define CS8900_SELF_CTRL_HW_STANDBY (1 << 10)
411#define CS8900_SELF_CTRL_HC0E (1 << 12)
412#define CS8900_SELF_CTRL_HC1E (1 << 13)
413#define CS8900_SELF_CTRL_HCB0 (1 << 14)
414#define CS8900_SELF_CTRL_HCB1 (1 << 15)
415
416/*
417 * Reg 16. Self Status.
418 */
419
420#define CS8900_SELF_STATUS_3_3_V (1 << 6)
421#define CS8900_SELF_STATUS_INITD (1 << 7)
422#define CS8900_SELF_STATUS_SIBUST (1 << 8)
423#define CS8900_SELF_STATUS_EEPROM_PRESENT (1 << 9)
424#define CS8900_SELF_STATUS_EEPROM_OK (1 << 10)
425#define CS8900_SELF_STATUS_EL_PRESENT (1 << 11)
426#define CS8900_SELF_STATUS_EE_SIZE (1 << 12)
427
428/*
429 * Reg 17. Bus Control.
430 */
431
432#define CS8900_BUS_CTRL_RESET_RX_DMA (1 << 6)
433#define CS8900_BUS_CTRL_USE_SA (1 << 9)
434#define CS8900_BUS_CTRL_MEMORY_ENABLE (1 << 10)
435#define CS8900_BUS_CTRL_DMA_BURST (1 << 11)
436#define CS8900_BUS_CTRL_IOCHRDYE (1 << 12)
437#define CS8900_BUS_CTRL_RX_DMA_SIZE (1 << 13)
438#define CS8900_BUS_CTRL_ENABLE_INT (1 << 15)
439
440/*
441 * Reg 18. Bus Status.
442 */
443
444#define CS8900_BUS_STATUS_TX_BID_ERROR (1 << 7)
445#define CS8900_BUS_STATUS_RDY_FOR_TX_NOW (1 << 8)
446
447/*
448 * Trace for debugging the isq processing. Define to 1 to enable.
449 */
450#define CS8900_TRACE 0
451#define CS8900_TRACE_SIZE (400)
452
453/*
454 * The default receive queue size. If the BSP sets this field to
455 * 0 this default is used.
456 */
457#define CS8900_RX_QUEUE_SIZE (30)
458
459/*
460 * Stats, more for debugging than anything else.
461 */
462
463typedef struct
464{
465 unsigned long rx_packets; /* total packets received */
466 unsigned long tx_packets; /* total packets transmitted */
467 unsigned long rx_bytes; /* total bytes received */
468 unsigned long tx_bytes; /* total bytes transmitted */
469 unsigned long rx_interrupts; /* total number of rx interrupts */
470 unsigned long tx_interrupts; /* total number of tx interrupts */
471
472 /* detailed rx errors: */
473 unsigned long rx_dropped; /* no mbufs in queue */
474 unsigned long rx_no_mbufs; /* no mbufs */
475 unsigned long rx_no_clusters; /* no clusters */
476 unsigned long rx_oversize_errors;
477 unsigned long rx_crc_errors; /* recved pkt with crc error */
478 unsigned long rx_runt_errors;
479 unsigned long rx_missed_errors; /* receiver missed packet */
480
481 /* detailed tx errors */
482 unsigned long tx_ok;
483 unsigned long tx_collisions;
484 unsigned long tx_bid_errors;
485 unsigned long tx_wait_for_rdy4tx;
486 unsigned long tx_rdy4tx;
487 unsigned long tx_underrun_errors;
488 unsigned long tx_dropped;
489 unsigned long tx_resends;
490
491 /* interrupt watch dog */
492 unsigned long int_swint_req;
493 unsigned long int_swint_res;
494 unsigned long int_lockup;
495
496 unsigned long interrupts;
497
499
500/*
501 * CS8900 device structure
502 */
503
504typedef struct
505{
506 /*
507 * Device number.
508 */
509
510 int dev;
511
512 /*
513 * Memory base addresses. Making mem_base 0 forces the
514 * driver to perform only I/O space accesses.
515 */
516
517 unsigned long io_base;
518 unsigned long mem_base;
519
520 /*
521 * The IRQ level as defined in the datasheet for the CS8900.
522 *
523 * ISA BUS Pin Value
524 * IRQ10 INTRQ0 0
525 * IRQ11 INTRQ1 1
526 * IRQ12 INTRQ2 2
527 * IRQ5 INTRQ3 3
528 */
529
530 int irq_level;
531
532 /*
533 * The MAC address.
534 */
535
536 unsigned char mac_address[6];
537
538 /*
539 * The bsdnet information structure.
540 */
541
542 struct arpcom arpcom;
543
544 /*
545 * Driver state and resources.
546 */
547
548 int accept_bcast;
549 int tx_active;
550
551 rtems_id rx_task;
552 rtems_id tx_task;
553
554 /*
555 * The queues. FIXME : these should be changed to be mbuf lists.
556 */
557
558 struct mbuf *rx_ready_head;
559 struct mbuf *rx_ready_tail;
560 int rx_ready_len;
561
562 struct mbuf *rx_loaded_head;
563 struct mbuf *rx_loaded_tail;
564 int rx_loaded_len;
565
566 /*
567 * Number of mbufs queued for the interrupt handler to
568 * loop reading.
569 */
570
571 int rx_queue_size;
572
573#if CS8900_TRACE
574 unsigned short trace_key[CS8900_TRACE_SIZE];
575 unsigned long trace_var[CS8900_TRACE_SIZE];
576 unsigned long trace_time[CS8900_TRACE_SIZE];
577 int trace_in;
578#endif
579
585
587
588/*
589 * Link active returns the state of the PHY.
590 *
591 * @param cs Pointer to the device structure.
592 */
593
594int cs8900_link_active (cs8900_device *cs);
595
610int cs8900_driver_attach (struct rtems_bsdnet_ifconfig *config,
611 int attaching);
612
625rtems_isr cs8900_interrupt (rtems_vector_number v, void *cs);
626
636void cs8900_get_mac_addr (cs8900_device *cs, unsigned char *mac_address);
637
647void cs8900_attach_interrupt (cs8900_device *cs);
648
657void cs8900_detach_interrupt (cs8900_device *cs);
658
671void cs8900_io_set_reg (cs8900_device *cs,
672 unsigned short reg, unsigned short data);
673
686unsigned short cs8900_io_get_reg (cs8900_device *cs, unsigned short reg);
687
701void cs8900_mem_set_reg (cs8900_device *cs,
702 unsigned long reg, unsigned short data);
703
717unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg);
718
732void cs8900_put_data_block (cs8900_device *cs, int len, unsigned char *data);
733
747unsigned short cs8900_get_data_block (cs8900_device *cs, unsigned char *data);
748
759void cs8900_tx_load (cs8900_device *cs, struct mbuf *m);
760
761#endif
RTEMS Error Reporting.
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
int cs8900_driver_attach(struct rtems_bsdnet_ifconfig *config, int attaching)
Definition: cs8900.c:1136
Definition: deflate.c:115
Definition: cs8900.h:505
eth_statistics eth_stats
Definition: cs8900.h:584
Definition: cs8900.h:464
unsigned v
Definition: tte.h:0
