RTEMS 5.2-rc1
pci.h
1/*
2 * PCI library. Defines in this file was taken from FreeBSD and auto-generated
3 * pci_ids.h reused from RTEMS.
4 *
5 * COPYRIGHT (c) 2009 Cobham Gaisler AB.
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __PCI_H__
13#define __PCI_H__
14
15#include <pci/pcireg.h>
16#include <pci/ids.h>
17
18#define PCI_INVALID_VENDORDEVICEID 0xffffffff
19
20#define PCID_CLASS(class, dev) ((class << 8) | dev)
21#define PCID_PCI2PCI_BRIDGE PCID_CLASS(PCIC_BRIDGE, PCIS_BRIDGE_PCI)
22
23#include <pci/access.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29/* The PCI Library have the following build time configuration options. It is
30 * up to the BSP header file (bsp.h) to set options properly.
31 *
32 * BSP_PCI_BIG_ENDIAN - Access inline routines will be for a big-endian PCI
33 * bus, if not defined the routines will assume that
34 * PCI is as the standard defines: little-endian.
35 *
36 * Note that drivers may be run-time configurable,
37 * meaning that they may adopt to either big-endian or
38 * little-endian PCI bus, the host driver or BSP may
39 * detect endianness during run-time.
40 */
41
42/* Error return values */
43enum {
44 PCISTS_ERR = -1, /* Undefined Error */
45 PCISTS_OK = 0,
46 PCISTS_EINVAL = 1, /* Bad input arguments */
47 PCISTS_MSTABRT = 2, /* CFG space access error (can be ignored) */
48};
49
50/* PCI System type can be used to determine system for drivers. Normally
51 * the system is Host, but the peripheral configuration library also supports
52 * being PCI peripheral not allowed to access configuration space.
53 *
54 * The active configuration Library set this variable.
55 */
56enum pci_system_type {
57 PCI_SYSTEM_NONE = 0,
58 PCI_SYSTEM_HOST = 1,
59 PCI_SYSTEM_PERIPHERAL = 2,
60};
61extern enum pci_system_type pci_system_type;
62
63/* PCI Bus Endianness. The PCI specification is little endian, however on some
64 * embedded systems (AT697-LEON2 for example) the PCI bus is defined as big
65 * endian (non-standard) in order to avoid byte-twisting.
66 */
67enum {
68 PCI_LITTLE_ENDIAN = 0,
69 PCI_BIG_ENDIAN = 1,
70};
71extern int pci_endian;
72
73/* Return the number of PCI busses in the system */
74extern int pci_bus_count(void);
75
76/* Scan the PCI bus and print the PCI device/functions/bridges and their
77 * current resources and size to the system console.
78 */
79extern void pci_print(void);
80
81/* Print current configuration of a single PCI device by reading PCI
82 * configuration space
83 */
84extern void pci_print_dev(pci_dev_t dev);
85extern void pci_print_device(int bus, int slot, int function);
86
87/*** PCI Configuration Space direct access routines ***/
88
89/* Function iterates over all PCI buses/devices/functions and calls
90 * func(PCIDEV,arg) for each present device. The iteration is stopped if
91 * func() returns non-zero result the same result is returned. As long
92 * as func() returns zero the function will keep on iterating, when all
93 * devices has been processed the function return zero.
94 *
95 * The function iterates over all devices/functions on all buses by accessing
96 * configuration space directly (PCI RAM data structures not used). This
97 * function is valid to call after PCI buses have been enumrated.
98 */
99extern int pci_for_each(int (*func)(pci_dev_t, void*), void *arg);
100
101/* Get PCI Configuration space BUS|SLOT|FUNC for a device matching PCI
102 * Vendor, Device and instance number 'index'.
103 *
104 * Return Values
105 * -1 pci_find_dev did not find a device matching the criterion.
106 * 0 device was found, *pdev was updated with the device's BUS|SLOT|FUNC
107 */
108extern int pci_find(uint16_t ven, uint16_t dev, int index, pci_dev_t *pdev);
109
110#ifdef __cplusplus
111}
112#endif
113
114#endif /* __PCI_H__ */
