RTEMS
5.2-rc1
bsps
i386
include
libcpu
cpuModel.h
1
2
* This file contains declaration for variables and code
3
* that may be used to get the Intel Cpu identification
4
* that has been performed by checkCPUtypeSetCr0 function.
5
6
7
8
* COPYRIGHT (c) 1998 valette@crf.canon.fr
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
* http://www.rtems.org/license/LICENSE.
13
14
15
#ifndef libcpu_cpuModel_h
16
#define libcpu_cpuModel_h
17
18
19
* Tell us the machine setup..
20
21
22
extern
char
hard_math;
/* floating point coprocessor present indicator */
23
extern
char
x86
/* type of cpu (3 = 386, 4 =486, ...) */
24
extern
char
x86_model;
25
extern
char
x86_mask;
26
extern
int
x86_capability;
/* cpuid:EDX */
27
extern
int
x86_capability_x;
/* cpuid:ECX */
28
extern
int
x86_capability_ebx;
/* cpuid:EBX */
29
extern
int
x86_capability_cores;
/* cpuid.(EAX=4, ECX=0) - physical cores */
30
extern
char
x86_vendor_id[13];
31
extern
int
have_cpuid;
32
extern
unsigned
char
Cx86_step;
/* cyrix processor identification */
33
34
/* Display this information on console in ascii form */
35
extern
void
printCpuInfo(
void
36
37
/* determine if the CPU has a TSC */
38
#define x86_has_tsc() \
39
(x86_capability & (1 << 4))
40
41
static
inline
unsigned
long
long
42
rdtsc(
void
43
44
/* Return the value of the on-chip cycle counter. */
45
unsigned
long
long
result;
46
__asm__
volatile
".byte 0x0F, 0x31"
"=A"
(result));
47
return
result;
48
/* rdtsc */
49
50
51
#endif
__asm__
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
_x86
Definition:
em86.c:52
