RTEMS 5.2-rc1
cons.h
1/* Console driver interface to UART drivers
2 *
3 * - First console device that has System Console flag set will be
4 * system console.
5 * - If none of the registered console devices has system console set,
6 * the first is registered device is used, unless it has
7 *
8 * COPYRIGHT (c) 2010.
9 * Cobham Gaisler AB.
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __CONS_H__
17#define __CONS_H__
18
19#include <rtems/termiostypes.h>
20
21struct console_dev;
22
23#define CONSOLE_FLAG_SYSCON 0x01
24#define CONSOLE_FLAG_SYSCON_GRANT 0x02
25
28 /* Set CONSOLE_FLAG_SYSCON to request this device to be system console
29 * and/or debug console. CONSOLE_FLAG_SYSCON_GRANT will be set on the
30 * device which was selected as system console.
31 */
32 int flags;
33 char *fsname; /* File system prefix */
34 const rtems_termios_device_handler *handler;
35};
36
37extern void console_dev_register(struct console_dev *dev);
38#if 0
39extern void console_dev_unregister(struct console_dev *dev);
40#endif
41
42#endif
Definition: cons.h:26
Termios device context.
Definition: termiostypes.h:75
Termios device handler.
Definition: termiostypes.h:141
