RTEMS 5.2-rc1
Evaluate Per-CPU Configuration Options. More...
Since the idle thread stack size (CONFIGURE_IDLE_TASK_STACK_SIZE) depends on CONFIGURE_MINIMUM_TASK_STACK_SIZE, the POSIX-specific CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE configuration option is also evaluated in this header file for simplicity.
This header file defines _CONFIGURE_MAXIMUM_PROCESSORS for use by other configuration header files.
