RTEMS 5.2-rc1
chap.h
1/*
2 * chap.h - Challenge Handshake Authentication Protocol definitions.
3 *
4 * Copyright (c) 1993 The Australian National University.
5 * All rights reserved.
6 *
7 * Redistribution and use in source and binary forms are permitted
8 * provided that the above copyright notice and this paragraph are
9 * duplicated in all such forms and that any documentation,
10 * advertising materials, and other materials related to such
11 * distribution and use acknowledge that the software was developed
12 * by the Australian National University. The name of the University
13 * may not be used to endorse or promote products derived from this
14 * software without specific prior written permission.
15 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16 * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17 * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18 *
19 * Copyright (c) 1991 Gregory M. Christy
20 * All rights reserved.
21 *
22 * Redistribution and use in source and binary forms are permitted
23 * provided that the above copyright notice and this paragraph are
24 * duplicated in all such forms and that any documentation,
25 * advertising materials, and other materials related to such
26 * distribution and use acknowledge that the software was developed
27 * by the author.
28 *
29 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
30 * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
31 * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
32 *
33 * $Id$
34 */
35
36#ifndef __CHAP_INCLUDE__
37
38/* Code + ID + length */
39#define CHAP_HEADERLEN 4
40
41/*
42 * CHAP codes.
43 */
44
45#define CHAP_DIGEST_MD5 5 /* use MD5 algorithm */
46#define MD5_SIGNATURE_SIZE 16 /* 16 bytes in a MD5 message digest */
47#define CHAP_MICROSOFT 0x80 /* use Microsoft-compatible alg. */
48#define MS_CHAP_RESPONSE_LEN 49 /* Response length for MS-CHAP */
49
50#define CHAP_CHALLENGE 1
51#define CHAP_RESPONSE 2
52#define CHAP_SUCCESS 3
53#define CHAP_FAILURE 4
54
55/*
56 * Challenge lengths (for challenges we send) and other limits.
57 */
58#define MIN_CHALLENGE_LENGTH 16
59#define MAX_CHALLENGE_LENGTH 24
60#define MAX_RESPONSE_LENGTH 64 /* sufficient for MD5 or MS-CHAP */
61
62/*
63 * Each interface is described by a chap structure.
64 */
65
66typedef struct chap_state {
67 int unit; /* Interface unit number */
68 int clientstate; /* Client state */
69 int serverstate; /* Server state */
70 u_char challenge[MAX_CHALLENGE_LENGTH]; /* last challenge string sent */
71 u_char chal_len; /* challenge length */
72 u_char chal_id; /* ID of last challenge */
73 u_char chal_type; /* hash algorithm for challenges */
74 u_char id; /* Current id */
75 char *chal_name; /* Our name to use with challenge */
76 int chal_interval; /* Time until we challenge peer again */
77 int timeouttime; /* Timeout time in seconds */
78 int max_transmits; /* Maximum # of challenge transmissions */
79 int chal_transmits; /* Number of transmissions of challenge */
80 int resp_transmits; /* Number of transmissions of response */
81 u_char response[MAX_RESPONSE_LENGTH]; /* Response to send */
82 u_char resp_length; /* length of response */
83 u_char resp_id; /* ID for response messages */
84 u_char resp_type; /* hash algorithm for responses */
85 char *resp_name; /* Our name to send with response */
87
88
89/*
90 * Client (peer) states.
91 */
92#define CHAPCS_INITIAL 0 /* Lower layer down, not opened */
93#define CHAPCS_CLOSED 1 /* Lower layer up, not opened */
94#define CHAPCS_PENDING 2 /* Auth us to peer when lower up */
95#define CHAPCS_LISTEN 3 /* Listening for a challenge */
96#define CHAPCS_RESPONSE 4 /* Sent response, waiting for status */
97#define CHAPCS_OPEN 5 /* We've received Success */
98
99/*
100 * Server (authenticator) states.
101 */
102#define CHAPSS_INITIAL 0 /* Lower layer down, not opened */
103#define CHAPSS_CLOSED 1 /* Lower layer up, not opened */
104#define CHAPSS_PENDING 2 /* Auth peer when lower up */
105#define CHAPSS_INITIAL_CHAL 3 /* We've sent the first challenge */
106#define CHAPSS_OPEN 4 /* We've sent a Success msg */
107#define CHAPSS_RECHALLENGE 5 /* We've sent another challenge */
108#define CHAPSS_BADAUTH 6 /* We've sent a Failure msg */
109
110/*
111 * Timeouts.
112 */
113#define CHAP_DEFTIMEOUT 5 /* Timeout time in seconds */
114#define CHAP_DEFTRANSMITS 10 /* max # times to send challenge */
115
116extern chap_state chap[];
117
118void ChapAuthWithPeer(int, char *, int);
119void ChapAuthPeer(int, char *, int);
120
121extern struct protent chap_protent;
122
123#define __CHAP_INCLUDE__
124#endif /* __CHAP_INCLUDE__ */
Definition: chap.h:66
Definition: pppd.h:249
