RTEMS 5.2-rc1
ccp.h
1/*
2 * ccp.h - Definitions for PPP Compression Control Protocol.
3 *
4 * Copyright (c) 1994 The Australian National University.
5 * All rights reserved.
6 *
7 * Permission to use, copy, modify, and distribute this software and its
8 * documentation is hereby granted, provided that the above copyright
9 * notice appears in all copies. This software is provided without any
10 * warranty, express or implied. The Australian National University
11 * makes no representations about the suitability of this software for
12 * any purpose.
13 *
14 * IN NO EVENT SHALL THE AUSTRALIAN NATIONAL UNIVERSITY BE LIABLE TO ANY
15 * PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
16 * ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
17 * THE AUSTRALIAN NATIONAL UNIVERSITY HAVE BEEN ADVISED OF THE POSSIBILITY
18 * OF SUCH DAMAGE.
19 *
20 * THE AUSTRALIAN NATIONAL UNIVERSITY SPECIFICALLY DISCLAIMS ANY WARRANTIES,
21 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
22 * AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS
23 * ON AN "AS IS" BASIS, AND THE AUSTRALIAN NATIONAL UNIVERSITY HAS NO
24 * OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
25 * OR MODIFICATIONS.
26 *
27 * $Id$
28 */
29
30typedef struct ccp_options {
31 bool bsd_compress; /* do BSD Compress? */
32 bool deflate; /* do Deflate? */
33 bool predictor_1; /* do Predictor-1? */
34 bool predictor_2; /* do Predictor-2? */
35 bool deflate_correct; /* use correct code for deflate? */
36 bool deflate_draft; /* use draft RFC code for deflate? */
37 u_short bsd_bits; /* # bits/code for BSD Compress */
38 u_short deflate_size; /* lg(window size) for Deflate */
39 short method; /* code for chosen compression method */
41
42extern fsm ccp_fsm[];
43extern ccp_options ccp_wantoptions[];
44extern ccp_options ccp_gotoptions[];
45extern ccp_options ccp_allowoptions[];
46extern ccp_options ccp_hisoptions[];
47
48extern struct protent ccp_protent;
Definition: ccp.h:30
Definition: fsm.h:43
Definition: pppd.h:249
