RTEMS 5.2-rc1
captureimpl.h
1
10/*
11 ------------------------------------------------------------------------
12
13 Copyright 2002, 2016 Chris Johns <chrisj@rtems.org>.
14 All rights reserved.
15
16 COPYRIGHT (c) 1989-2014.
17 On-Line Applications Research Corporation (OAR).
18
19 The license and distribution terms for this file may be
20 found in the file LICENSE in this distribution.
21
22 This software with is provided ``as is'' and with NO WARRANTY.
23
24 ------------------------------------------------------------------------
25
26 RTEMS Performance Monitoring and Measurement Framework.
27 This is the Capture Engine component.
28
29*/
30
31#ifndef __CAPTUREIMPL_H_
32#define __CAPTUREIMPL_H_
33
34#include "capture.h"
35
37#ifdef __cplusplus
38extern "C" {
39#endif
40
51
61
72uint32_t rtems_capture_get_flags(void);
73
81void rtems_capture_set_flags(uint32_t mask);
82
93
103
118 rtems_tcb* tt,
119 uint32_t events);
120
131void rtems_capture_print_trace_records ( int total, bool csv );
132
140void rtems_capture_print_timestamp (uint64_t uptime);
141
153 const rtems_capture_record* rec,
154 const rtems_capture_task_record* task_rec);
155
169 const rtems_capture_record* rec,
170 uint64_t diff,
171 const rtems_name* name);
172
179
180#ifdef __cplusplus
181}
182#endif
185#endif
Capture Engine Component of the RTEMS Measurement and Monitoring System.
rtems_status_code rtems_capture_user_extension_open(void)
Capture user extension open.
Definition: capture_user_extension.c:94
void rtems_capture_print_watch_list(void)
Capture print watch list.
Definition: capture_support.c:403
Capture set flags.
Definition: capture.c:138
void rtems_capture_set_extension_index(int index)
Capture set extension index.
Definition: capture.c:123
Capture get flags.
Definition: capture.c:133
bool rtems_capture_trigger_fired(rtems_tcb *ft, rtems_tcb *tt, uint32_t events)
Capture check trigger.
Definition: capture.c:520
rtems_status_code rtems_capture_user_extension_close(void)
Capture user extension close.
Definition: capture_user_extension.c:115
void rtems_capture_print_timestamp(uint64_t uptime)
Capture print timestamp.
Definition: capture_support.c:169
int rtems_capture_get_extension_index(void)
Capture get extension index.
Definition: capture.c:128
void rtems_capture_print_record_task(int cpu, const rtems_capture_record *rec, const rtems_capture_task_record *task_rec)
Capture print record task.
Definition: capture_support.c:189
void rtems_capture_print_trace_records(int total, bool csv)
Capture print trace records.
Definition: capture_support.c:263
void rtems_capture_print_record_capture(int cpu, const rtems_capture_record *rec, uint64_t diff, const rtems_name *name)
Capture print capture record.
Definition: capture_support.c:218
rtems_status_code
Classic API Status.
Definition: status.h:43
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
Definition: thread.h:732
Definition: capture.h:173
Definition: capture.h:188
