RTEMS 5.2-rc1
interrupt.h
1
24#ifndef _BFIN_INTERRUPT_H_
25#define _BFIN_INTERRUPT_H_
26
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
34typedef enum {
35 IRQ_PLL_WAKEUP_INTERRUPT, /* 0 */
36 IRQ_DMA_ERROR_0, /* 1 */
37 IRQ_DMAR0_BLOCK_INTERRUPT, /* 2 */
38 IRQ_DMAR1_BLOCK_INTERRUPT, /* 3 */
39 IRQ_DMAR0_OVERFLOW_ERROR, /* 4 */
40 IRQ_DMAR1_OVERFLOW_ERROR, /* 5 */
41 IRQ_PPI_STATUS, /* 6 */
42 IRQ_MAC_STATUS, /* 7 */
43 IRQ_SPORT0_STATUS, /* 8 */
44 IRQ_SPORT1_STATUS, /* 9 */
45 IRQ_RESERVED_10, /* 10 */
46 IRQ_RESERVED_11, /* 11 */
47 IRQ_UART0_STATUS, /* 12 */
48 IRQ_UART1_STATUS, /* 13 */
49 IRQ_REAL_TIME_CLOCK, /* 14 */
50 IRQ_DMA0_PPI_NFC, /* 15 */
51 IRQ_DMA3_SPORT0_RX, /* 16 */
52 IRQ_DMA4_SPORT0_TX, /* 17 */
53 IRQ_DMA5_SPORT1_RX, /* 18 */
54 IRQ_DMA6_SPORT1_TX, /* 19 */
55 IRQ_TWI_INTERRUPT, /* 20 */
56 IRQ_DMA7_SPI, /* 21 */
57 IRQ_DMA8_UART0_RX, /* 22 */
58 IRQ_DMA9_UART0_TX, /* 23 */
59 IRQ_DMA10_UART1_RX, /* 24 */
60 IRQ_DMA11_UART1_TX, /* 25 */
61 IRQ_OTP, /* 26 */
62 IRQ_GP_COUNTER, /* 27 */
63 IRQ_DMA1_MAC_RX_HOSTDP, /* 28 */
64 IRQ_PORT_H_INTERRUPT_A, /* 29 */
65 IRQ_DMA2_MAC_TX_NFC, /* 30 */
66 IRQ_PORT_H_INTERRUPT_B, /* 31 */
67 SIC_ISR0_MAX, /* 32 ***/
68 IRQ_TIMER0 = SIC_ISR0_MAX, /* 32 */
69 IRQ_TIMER1, /* 33 */
70 IRQ_TIMER2, /* 34 */
71 IRQ_TIMER3, /* 35 */
72 IRQ_TIMER4, /* 36 */
73 IRQ_TIMER5, /* 37 */
74 IRQ_TIMER6, /* 38 */
75 IRQ_TIMER7, /* 39 */
76 IRQ_PORT_G_INTERRUPT_A, /* 40 */
77 IRQ_PORT_G_INTERRUPT_B, /* 41 */
78 IRQ_MDMA0_STREAM_0_INTERRUPT, /* 42 */
79 IRQ_MDMA1_STREAM_0_INTERRUPT, /* 43 */
80 IRQ_SOFTWARE_WATCHDOG_INTERRUPT, /* 44 */
81 IRQ_PORT_F_INTERRUPT_A, /* 45 */
82 IRQ_PORT_F_INTERRUPT_B, /* 46 */
83 IRQ_SPI_STATUS, /* 47 */
84 IRQ_NFC_STATUS, /* 48 */
85 IRQ_HOSTDP_STATUS, /* 49 */
86 IRQ_HOREAD_DONE_INTERRUPT, /* 50 */
87 IRQ_RESERVED_19, /* 51 */
88 IRQ_USB_INT0_INTERRUPT, /* 52 */
89 IRQ_USB_INT1_INTERRUPT, /* 53 */
90 IRQ_USB_INT2_INTERRUPT, /* 54 */
91 IRQ_USB_DMAINT, /* 55 */
92 IRQ_MAX, /* 56 */
93} e_isr_t;
94
95
96
97
98/* source is the source to the SIC (the bit number in SIC_ISR). isr is
99 the function that will be called when the interrupt is active. */
100typedef struct bfin_isr_s {
101#if INTERRUPT_USE_TABLE
102 e_isr_t source;
103 void (*pFunc)(void *arg);
104 void *pArg;
105 int priority;
106#else
107 int source;
108 void (*isr)(void *arg);
109 void *_arg;
110 /* the following are for internal use only */
111 uint32_t mask0;
112 uint32_t mask1;
113 uint32_t vector;
114 struct bfin_isr_s *next;
115#endif
116} bfin_isr_t;
117
124
130
136void bfin_interrupt_init(void);
137
138
139#ifdef __cplusplus
140}
141#endif
142
143#endif /* _BFIN_INTERRUPT_H_ */
144
Definition: interrupt.c:50
rtems_status_code bfin_interrupt_register(bfin_isr_t *isr)
Definition: interrupt.c:98
e_isr_t
Definition: interrupt.h:34
rtems_status_code bfin_interrupt_unregister(bfin_isr_t *isr)
Definition: interrupt.c:126
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: interrupt.h:100
