RTEMS 5.2-rc1
bbb-pwm.h
1
21#ifndef LIBBSP_ARM_BEAGLE_BBB_PWM_H
22#define LIBBSP_ARM_BEAGLE_BBB_PWM_H
23
24#ifdef __cplusplus
25extern "C" {
26#endif /* __cplusplus */
27
31#define BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4))
32#define BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4))
33
39typedef enum{
40 BBB_PWMSS0 = 0,
41 BBB_PWMSS1,
42 BBB_PWMSS2,
43 BBB_PWMSS_COUNT
45
46typedef enum{
47 BBB_P8_13_2B = 3,
48 BBB_P8_19_2A,
49 BBB_P8_45_2A,
50 BBB_P8_46_2B,
51 BBB_P8_34_1B,
52 BBB_P8_36_1A,
53 BBB_P9_14_1A,
54 BBB_P9_16_1B,
55 BBB_P9_21_0B,
56 BBB_P9_22_0A,
57 BBB_P9_29_0B,
58 BBB_P9_31_0A
59}bbb_pwm_pin_t;
60
61#define BBB_P8_13_MUX_PWM 4
62#define BBB_P8_19_MUX_PWM 4
63#define BBB_P8_45_MUX_PWM 3
64#define BBB_P8_46_MUX_PWM 3
65#define BBB_P8_34_MUX_PWM 2
66#define BBB_P8_36_MUX_PWM 2
67#define BBB_P9_14_MUX_PWM 6
68#define BBB_P9_16_MUX_PWM 6
69#define BBB_P9_21_MUX_PWM 3
70#define BBB_P9_22_MUX_PWM 3
71#define BBB_P9_29_MUX_PWM 1
72#define BBB_P9_31_MUX_PWM 1
73#define BBB_PWM_FREQ_THRESHOLD 0.5f
74
89
90/* PWMSS setting
91 * set pulse argument of epwm module
92 *
93 * @param pwm_id : EPWMSS number , 0~2
94 * @param pwm_freq : frequency to be generated
95 * @param dutyA : Duty Cycle(in percentage) in PWM channel A
96 * @param dutyB : Duty Cycle(in percentage) in PWM channel B
97 *
98 * @return : 1 for success
99 * @return : 0 for failed
100 *
101 * @example : beagle_pwm_configure(0 , 50.0f , 50.0f , 25.0f); // Generate 50HZ pwm in PWM0 ,
102 * // duty cycle is 50% for ePWM0A , 25% for ePWM0B
103 *
104 * @Note :
105 * find an number nearst 65535 for TBPRD , to improve duty precision,
106 *
107 * Using big TBPRD can increase the range of CMPA and CMPB ,
108 * and it means we can get better precision on duty cycle.
109 *
110 * EX : 20.25% duty cycle
111 * on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) , real duty : 20.2496% (12656 /62500)
112 * on TBPRD = 6250 , CMPA = 1265.625 ( .625 rejection), real duty : 20.24% (1265 6250)
113 * on TBPRD = 500 , CMPA = 101.25 ( .25 rejection) , real duty : 20.2% (101/500)
114 *
115 * Divisor = CLKDIV * HSPCLKDIV
116 * 1 TBPRD : 10 ns (default)
117 * 65535 TBPRD : 655350 ns
118 * 65535 TBPRD : 655350 * Divisor ns = X TBPRD : Cycle
119 *
120 * accrooding to that , we must find a Divisor value , let X nearest 65535 .
121 * so , Divisor must Nearest Cycle/655350
122 */
123int beagle_pwm_configure(BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b);
124
135
146
159bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id);
160
171bool beagle_pwmss_is_running(unsigned int pwmss_id);
172
173
174#ifdef __cplusplus
175}
176#endif /* __cplusplus */
177
178#endif /* LIBBSP_ARM_BEAGLE_BBB_PWM_H */
bool beagle_pwm_disable(BBB_PWMSS pwmid)
This API disables the particular PWM module.
bool beagle_pwm_enable(BBB_PWMSS pwmid)
This API enables the particular PWM module.
This function determines whether PWMSS-wide clocks enabled or not.
bool beagle_pwm_init(BBB_PWMSS pwmss_id)
BeagleBone Black PWM API.
BBB_PWMSS
The set of possible PWM subsystem module.
Definition: bbb-pwm.h:39
This function enables pinmuxing for PWM module.
