RTEMS 5.2-rc1
au1x00.h
1
7/*
8 * Copyright (c) 2005 by Cogent Computer Systems
9 * Written by Jay Monkman <jtm@lopingdog.com>
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __AU1X00_H__
17#define __AU1X00_H__
18
19#define bit(x) (1 << (x))
20
21/* Au1x00 CP0 registers
22 */
23#define CP0_Index $0
24#define CP0_Random $1
25#define CP0_EntryLo0 $2
26#define CP0_EntryLo1 $3
27#define CP0_Context $4
28#define CP0_PageMask $5
29#define CP0_Wired $6
30#define CP0_BadVAddr $8
31#define CP0_Count $9
32#define CP0_EntryHi $10
33#define CP0_Compare $11
34#define CP0_Status $12
35#define CP0_Cause $13
36#define CP0_EPC $14
37#define CP0_PRId $15
38#define CP0_Config $16
39#define CP0_Config0 $16
40#define CP0_Config1 $16,1
41#define CP0_LLAddr $17
42#define CP0_WatchLo $18
43#define CP0_IWatchLo $18,1
44#define CP0_WatchHi $19
45#define CP0_IWatchHi $19,1
46#define CP0_Scratch $22
47#define CP0_Debug $23
48#define CP0_DEPC $24
49#define CP0_PerfCnt $25
50#define CP0_PerfCtrl $25,1
51#define CP0_DTag $28
52#define CP0_DData $28,1
53#define CP0_ITag $29
54#define CP0_IData $29,1
55#define CP0_ErrorEPC $30
56#define CP0_DESave $31
57
58/* Addresses common to all AU1x00 CPUs */
59#define AU1X00_MEM_ADDR 0xB4000000
60#define AU1X00_AC97_ADDR 0xB0000000
61#define AU1X00_USBH_ADDR 0xB0100000
62#define AU1X00_USBD_ADDR 0xB0200000
63#define AU1X00_MACDMA0_ADDR 0xB4004000
64#define AU1X00_MACDMA1_ADDR 0xB4004200
65#define AU1X00_UART0_ADDR 0xB1100000
66#define AU1X00_UART3_ADDR 0xB1400000
67#define AU1X00_SYS_ADDR 0xB1900000
68#define AU1X00_GPIO2_ADDR 0xB1700000
69#define AU1X00_IC0_ADDR 0xB0400000
70#define AU1X00_IC1_ADDR 0xB1800000
71
72/* Au1100 base addresses (in KSEG1 region) */
73#define AU1100_MAC0_ADDR 0xB0500000
74#define AU1100_MACEN_ADDR 0xB0520000
75
76/* Au1500 base addresses (in KSEG1 region) */
77#define AU1500_MAC0_ADDR 0xB1500000
78#define AU1500_MAC1_ADDR 0xB1510000
79#define AU1500_MACEN_ADDR 0xB1520000
80#define AU1500_PCI_ADDR 0xB4005000
81
82/* Au1x00 gpio2 register offsets
83 */
84#define gpio2_dir 0x0000
85#define gpio2_output 0x0008
86#define gpio2_pinstate 0x000c
87#define gpio2_inten 0x0010
88#define gpio2_enable 0x0014
89
90/* Au1x00 memory controller register offsets
91 */
92#define mem_sdmode0 0x0000
93#define mem_sdmode1 0x0004
94#define mem_sdmode2 0x0008
95#define mem_sdaddr0 0x000C
96#define mem_sdaddr1 0x0010
97#define mem_sdaddr2 0x0014
98#define mem_sdrefcfg 0x0018
99#define mem_sdprecmd 0x001C
100#define mem_sdautoref 0x0020
101#define mem_sdwrmd0 0x0024
102#define mem_sdwrmd1 0x0028
103#define mem_sdwrmd2 0x002C
104#define mem_sdsleep 0x0030
105#define mem_sdsmcke 0x0034
106
107#define mem_stcfg0 0x1000
108#define mem_sttime0 0x1004
109#define mem_staddr0 0x1008
110#define mem_stcfg1 0x1010
111#define mem_sttime1 0x1014
112#define mem_staddr1 0x1018
113#define mem_stcfg2 0x1020
114#define mem_sttime2 0x1024
115#define mem_staddr2 0x1028
116#define mem_stcfg3 0x1030
117#define mem_sttime3 0x1034
118#define mem_staddr3 0x1038
119
120/*
121 * Au1x00 peripheral register offsets
122 */
123#define ac97_enable 0x0010
124#define usbh_enable 0x0007FFFC
125#define usbd_enable 0x0058
126#define irda_enable 0x0040
127#define macen_mac0 0x0000
128#define macen_mac1 0x0004
129#define i2s_enable 0x0008
130#define uart_enable 0x0100
131#define ssi_enable 0x0100
132
133#define sys_scratch0 0x0018
134#define sys_scratch1 0x001c
135#define sys_cntctrl 0x0014
136#define sys_freqctrl0 0x0020
137#define sys_freqctrl1 0x0024
138#define sys_clksrc 0x0028
139#define sys_pinfunc 0x002C
140#define sys_powerctrl 0x003C
141#define sys_endian 0x0038
142#define sys_wakesrc 0x005C
143#define sys_cpupll 0x0060
144#define sys_auxpll 0x0064
145#define sys_pininputen 0x0110
146
147#define pci_cmem 0x0000
148#define pci_config 0x0004
149#define pci_b2bmask_cch 0x0008
150#define pci_b2bbase0_venid 0x000C
151#define pci_b2bbase1_id 0x0010
152#define pci_mwmask_dev 0x0014
153#define pci_mwbase_rev_ccl 0x0018
154#define pci_err_addr 0x001C
155#define pci_spec_intack 0x0020
156#define pci_id 0x0100
157#define pci_statcmd 0x0104
158#define pci_classrev 0x0108
159#define pci_hdrtype 0x010C
160#define pci_mbar 0x0110
161
162/*
163 * CSB250-specific values
164 */
165
166#define SYS_CPUPLL 33
167#define SYS_POWERCTRL 1
168#define SYS_AUXPLL 8
169#define SYS_CNTCTRL 256
170
171/* RCE0: */
172#define MEM_STCFG0 0x00000203
173#define MEM_STTIME0 0x22080b20
174#define MEM_STADDR0 0x11f03fc0
175
176/* RCE1: */
177#define MEM_STCFG1 0x00000203
178#define MEM_STTIME1 0x22080b20
179#define MEM_STADDR1 0x11e03fc0
180
181/* RCE2: */
182#define MEM_STCFG2 0x00000244
183#define MEM_STTIME2 0x22080a20
184#define MEM_STADDR2 0x11803f00
185
186/* RCE3: */
187#define MEM_STCFG3 0x00000201
188#define MEM_STTIME3 0x22080b20
189#define MEM_STADDR3 0x11003f00
190
191/*
192 * SDCS0 -
193 * SDCS1 -
194 * SDCS2 -
195 */
196#define MEM_SDMODE0 0x00552229
197#define MEM_SDMODE1 0x00552229
198#define MEM_SDMODE2 0x00552229
199
200#define MEM_SDADDR0 0x001003F8
201#define MEM_SDADDR1 0x001023F8
202#define MEM_SDADDR2 0x001043F8
203
204#define MEM_SDREFCFG_D 0x74000c30 /* disable */
205#define MEM_SDREFCFG_E 0x76000c30 /* enable */
206#define MEM_SDWRMD0 0x00000023
207#define MEM_SDWRMD1 0x00000023
208#define MEM_SDWRMD2 0x00000023
209
210#define MEM_1MS ((396000000/1000000) * 1000)
211
212#define AU1X00_IC_CFG0RD(x) (*(volatile uint32_t*)(x + 0x40))
213#define AU1X00_IC_CFG0SET(x) (*(volatile uint32_t*)(x + 0x40))
214#define AU1X00_IC_CFG0CLR(x) (*(volatile uint32_t*)(x + 0x44))
215#define AU1X00_IC_CFG1RD(x) (*(volatile uint32_t*)(x + 0x48))
216#define AU1X00_IC_CFG1SET(x) (*(volatile uint32_t*)(x + 0x48))
217#define AU1X00_IC_CFG1CLR(x) (*(volatile uint32_t*)(x + 0x4c))
218#define AU1X00_IC_CFG2RD(x) (*(volatile uint32_t*)(x + 0x50))
219#define AU1X00_IC_CFG2SET(x) (*(volatile uint32_t*)(x + 0x50))
220#define AU1X00_IC_CFG2CLR(x) (*(volatile uint32_t*)(x + 0x54))
221#define AU1X00_IC_REQ0INT(x) (*(volatile uint32_t*)(x + 0x54))
222#define AU1X00_IC_SRCRD(x) (*(volatile uint32_t*)(x + 0x58))
223#define AU1X00_IC_SRCSET(x) (*(volatile uint32_t*)(x + 0x58))
224#define AU1X00_IC_SRCCLR(x) (*(volatile uint32_t*)(x + 0x5c))
225#define AU1X00_IC_REQ1INT(x) (*(volatile uint32_t*)(x + 0x5c))
226#define AU1X00_IC_ASSIGNRD(x) (*(volatile uint32_t*)(x + 0x60))
227#define AU1X00_IC_ASSIGNSET(x) (*(volatile uint32_t*)(x + 0x60))
228#define AU1X00_IC_ASSIGNCLR(x) (*(volatile uint32_t*)(x + 0x64))
229#define AU1X00_IC_WAKERD(x) (*(volatile uint32_t*)(x + 0x68))
230#define AU1X00_IC_WAKESET(x) (*(volatile uint32_t*)(x + 0x68))
231#define AU1X00_IC_WAKECLR(x) (*(volatile uint32_t*)(x + 0x6c))
232#define AU1X00_IC_MASKRD(x) (*(volatile uint32_t*)(x + 0x70))
233#define AU1X00_IC_MASKSET(x) (*(volatile uint32_t*)(x + 0x70))
234#define AU1X00_IC_MASKCLR(x) (*(volatile uint32_t*)(x + 0x74))
235#define AU1X00_IC_RISINGRD(x) (*(volatile uint32_t*)(x + 0x78))
236#define AU1X00_IC_RISINGCLR(x) (*(volatile uint32_t*)(x + 0x78))
237#define AU1X00_IC_FALLINGRD(x) (*(volatile uint32_t*)(x + 0x7c))
238#define AU1X00_IC_FALLINGCLR(x) (*(volatile uint32_t*)(x + 0x7c))
239#define AU1X00_IC_TESTBIT(x) (*(volatile uint32_t*)(x + 0x80))
240#define AU1X00_IC_IRQ_MAC0 (bit(28))
241#define AU1X00_IC_IRQ_MAC1 (bit(29))
242#define AU1X00_IC_IRQ_TOY_MATCH0 (bit(15))
243#define AU1X00_IC_IRQ_TOY_MATCH1 (bit(16))
244#define AU1X00_IC_IRQ_TOY_MATCH2 (bit(17))
245
246
247
248#define AU1X00_SYS_TOYTRIM(x) (*(volatile uint32_t*)(x + 0x00))
249#define AU1X00_SYS_TOYWRITE(x) (*(volatile uint32_t*)(x + 0x04))
250#define AU1X00_SYS_TOYMATCH0(x) (*(volatile uint32_t*)(x + 0x08))
251#define AU1X00_SYS_TOYMATCH1(x) (*(volatile uint32_t*)(x + 0x0c))
252#define AU1X00_SYS_TOYMATCH2(x) (*(volatile uint32_t*)(x + 0x10))
253#define AU1X00_SYS_CNTCTRL(x) (*(volatile uint32_t*)(x + 0x14))
254#define AU1X00_SYS_SCRATCH0(x) (*(volatile uint32_t*)(x + 0x18))
255#define AU1X00_SYS_SCRATCH1(x) (*(volatile uint32_t*)(x + 0x1c))
256#define AU1X00_SYS_WAKEMSK(x) (*(volatile uint32_t*)(x + 0x34))
257#define AU1X00_SYS_ENDIAN(x) (*(volatile uint32_t*)(x + 0x38))
258#define AU1X00_SYS_POWERCTRL(x) (*(volatile uint32_t*)(x + 0x3c))
259#define AU1X00_SYS_TOYREAD(x) (*(volatile uint32_t*)(x + 0x40))
260#define AU1X00_SYS_RTCTRIM(x) (*(volatile uint32_t*)(x + 0x44))
261#define AU1X00_SYS_RTCWRITE(x) (*(volatile uint32_t*)(x + 0x48))
262#define AU1X00_SYS_RTCMATCH0(x) (*(volatile uint32_t*)(x + 0x4c))
263#define AU1X00_SYS_RTCMATCH1(x) (*(volatile uint32_t*)(x + 0x50))
264#define AU1X00_SYS_RTCMATCH2(x) (*(volatile uint32_t*)(x + 0x54))
265#define AU1X00_SYS_RTCREAD(x) (*(volatile uint32_t*)(x + 0x58))
266#define AU1X00_SYS_WAKESRC(x) (*(volatile uint32_t*)(x + 0x5c))
267#define AU1X00_SYS_SLPPWR(x) (*(volatile uint32_t*)(x + 0x78))
268#define AU1X00_SYS_SLEEP(x) (*(volatile uint32_t*)(x + 0x7c))
269
270#define AU1X00_SYS_CNTCTRL_ERS (bit(23))
271#define AU1X00_SYS_CNTCTRL_RTS (bit(20))
272#define AU1X00_SYS_CNTCTRL_RM2 (bit(19))
273#define AU1X00_SYS_CNTCTRL_RM1 (bit(18))
274#define AU1X00_SYS_CNTCTRL_RM0 (bit(17))
275#define AU1X00_SYS_CNTCTRL_RS (bit(16))
276#define AU1X00_SYS_CNTCTRL_BP (bit(14))
277#define AU1X00_SYS_CNTCTRL_REN (bit(13))
278#define AU1X00_SYS_CNTCTRL_BRT (bit(12))
279#define AU1X00_SYS_CNTCTRL_TEN (bit(11))
280#define AU1X00_SYS_CNTCTRL_BTT (bit(10))
281#define AU1X00_SYS_CNTCTRL_E0 (bit(8))
282#define AU1X00_SYS_CNTCTRL_ETS (bit(7))
283#define AU1X00_SYS_CNTCTRL_32S (bit(5))
284#define AU1X00_SYS_CNTCTRL_TTS (bit(4))
285#define AU1X00_SYS_CNTCTRL_TM2 (bit(3))
286#define AU1X00_SYS_CNTCTRL_TM1 (bit(2))
287#define AU1X00_SYS_CNTCTRL_TM0 (bit(1))
288#define AU1X00_SYS_CNTCTRL_TS (bit(0))
289#define AU1X00_SYS_WAKEMSK_M20 (bit(8))
290
291#define AU1X00_MAC_CONTROL(x) (*(volatile uint32_t*)(x + 0x00))
292#define AU1X00_MAC_ADDRHIGH(x) (*(volatile uint32_t*)(x + 0x04))
293#define AU1X00_MAC_ADDRLOW(x) (*(volatile uint32_t*)(x + 0x08))
294#define AU1X00_MAC_HASHHIGH(x) (*(volatile uint32_t*)(x + 0x0c))
295#define AU1X00_MAC_HASHLOW(x) (*(volatile uint32_t*)(x + 0x10))
296#define AU1X00_MAC_MIICTRL(x) (*(volatile uint32_t*)(x + 0x14))
297#define AU1X00_MAC_MIIDATA(x) (*(volatile uint32_t*)(x + 0x18))
298#define AU1X00_MAC_FLOWCTRL(x) (*(volatile uint32_t*)(x + 0x1c))
299#define AU1X00_MAC_VLAN1(x) (*(volatile uint32_t*)(x + 0x20))
300#define AU1X00_MAC_VLAN2(x) (*(volatile uint32_t*)(x + 0x24))
301#define AU1X00_MAC_EN0 (*(volatile uint32_t*)(AU1X00_MACEN_ADDR + 0x0))
302#define AU1X00_MAC_EN1 (*(volatile uint32_t*)(AU1X00_MACEN_ADDR + 0x4))
303#define AU1X00_MAC_DMA_TX0_ADDR(x) (*(volatile uint32_t*)(x + 0x000))
304#define AU1X00_MAC_DMA_TX1_ADDR(x) (*(volatile uint32_t*)(x + 0x010))
305#define AU1X00_MAC_DMA_TX2_ADDR(x) (*(volatile uint32_t*)(x + 0x020))
306#define AU1X00_MAC_DMA_TX3_ADDR(x) (*(volatile uint32_t*)(x + 0x030))
307#define AU1X00_MAC_DMA_RX0_ADDR(x) (*(volatile uint32_t*)(x + 0x100))
308#define AU1X00_MAC_DMA_RX1_ADDR(x) (*(volatile uint32_t*)(x + 0x110))
309#define AU1X00_MAC_DMA_RX2_ADDR(x) (*(volatile uint32_t*)(x + 0x120))
310#define AU1X00_MAC_DMA_RX3_ADDR(x) (*(volatile uint32_t*)(x + 0x130))
311
312typedef struct {
313 volatile uint32_t stat;
314 volatile uint32_t addr;
315 uint32_t _rsv0;
316 uint32_t _rsv1;
318
319
320typedef struct {
321 volatile uint32_t stat;
322 volatile uint32_t addr;
323 volatile uint32_t len;
324 uint32_t _rsv0;
326
327#define AU1X00_MAC_CTRL_RA (bit(31))
328#define AU1X00_MAC_CTRL_EM (bit(30))
329#define AU1X00_MAC_CTRL_DO (bit(23))
330#define AU1X00_MAC_CTRL_LM(x) ((x) << 21)
331#define AU1X00_MAC_CTRL_LM_NORMAL ((0) << 21)
332#define AU1X00_MAC_CTRL_LM_INTERNAL ((1) << 21)
333#define AU1X00_MAC_CTRL_LM_EXTERNAL ((2) << 21)
334#define AU1X00_MAC_CTRL_F (bit(20))
335#define AU1X00_MAC_CTRL_PM (bit(19))
336#define AU1X00_MAC_CTRL_PR (bit(18))
337#define AU1X00_MAC_CTRL_IF (bit(17))
338#define AU1X00_MAC_CTRL_PB (bit(16))
339#define AU1X00_MAC_CTRL_HO (bit(15))
340#define AU1X00_MAC_CTRL_HP (bit(13))
341#define AU1X00_MAC_CTRL_LC (bit(12))
342#define AU1X00_MAC_CTRL_DB (bit(11))
343#define AU1X00_MAC_CTRL_DR (bit(10))
344#define AU1X00_MAC_CTRL_AP (bit(8))
345#define AU1X00_MAC_CTRL_BL(x) ((x) << 6)
346#define AU1X00_MAC_CTRL_DC (bit(5))
347#define AU1X00_MAC_CTRL_TE (bit(3))
348#define AU1X00_MAC_CTRL_RE (bit(2))
349
350#define AU1X00_MAC_EN_JP (bit(6))
351#define AU1X00_MAC_EN_E2 (bit(5))
352#define AU1X00_MAC_EN_E1 (bit(4))
353#define AU1X00_MAC_EN_C (bit(3))
354#define AU1X00_MAC_EN_TS (bit(2))
355#define AU1X00_MAC_EN_E0 (bit(1))
356#define AU1X00_MAC_EN_CE (bit(0))
357
358#define AU1X00_MAC_ADDRHIGH_MASK (0xffff)_
359#define AU1X00_MAC_MIICTRL_PHYADDR(x) ((x & 0x1f) << 11)
360#define AU1X00_MAC_MIICTRL_MIIREG(x) ((x & 0x1f) << 6)
361#define AU1X00_MAC_MIICTRL_MW (bit(1))
362#define AU1X00_MAC_MIICTRL_MB (bit(0))
363#define AU1X00_MAC_MIIDATA_MASK (0xffff)
364#define AU1X00_MAC_FLOWCTRL_PT(x) (((x) & 0xffff) << 16)
365#define AU1X00_MAC_FLOWCTRL_PC (bit(2))
366#define AU1X00_MAC_FLOWCTRL_FE (bit(1))
367#define AU1X00_MAC_FLOWCTRL_FB (bit(0))
368
369#define AU1X00_MAC_DMA_RXSTAT_MI (bit(31))
370#define AU1X00_MAC_DMA_RXSTAT_PF (bit(30))
371#define AU1X00_MAC_DMA_RXSTAT_FF (bit(29))
372#define AU1X00_MAC_DMA_RXSTAT_BF (bit(28))
373#define AU1X00_MAC_DMA_RXSTAT_MF (bit(27))
374#define AU1X00_MAC_DMA_RXSTAT_UC (bit(26))
375#define AU1X00_MAC_DMA_RXSTAT_CF (bit(25))
376#define AU1X00_MAC_DMA_RXSTAT_LE (bit(24))
377#define AU1X00_MAC_DMA_RXSTAT_V2 (bit(23))
378#define AU1X00_MAC_DMA_RXSTAT_V1 (bit(22))
379#define AU1X00_MAC_DMA_RXSTAT_CR (bit(21))
380#define AU1X00_MAC_DMA_RXSTAT_DB (bit(20))
381#define AU1X00_MAC_DMA_RXSTAT_ME (bit(19))
382#define AU1X00_MAC_DMA_RXSTAT_FT (bit(18))
383#define AU1X00_MAC_DMA_RXSTAT_CS (bit(17))
384#define AU1X00_MAC_DMA_RXSTAT_FL (bit(16))
385#define AU1X00_MAC_DMA_RXSTAT_RF (bit(15))
386#define AU1X00_MAC_DMA_RXSTAT_WT (bit(14))
387#define AU1X00_MAC_DMA_RXSTAT_LEN(x) ((x) & 0x3fff)
388#define AU1X00_MAC_DMA_RXADDR_ADDR(x) ((x) & ~0x1f)
389#define AU1X00_MAC_DMA_RXADDR_CB_MASK (0x3 << 0x2)
390#define AU1X00_MAC_DMA_RXADDR_DN (bit(1))
391#define AU1X00_MAC_DMA_RXADDR_EN (bit(0))
392
393
394#define AU1X00_MAC_DMA_TXSTAT_PR (bit(31))
395#define AU1X00_MAC_DMA_TXSTAT_CC_MASK (0xf << 10)
396#define AU1X00_MAC_DMA_TXSTAT_LO (bit(9))
397#define AU1X00_MAC_DMA_TXSTAT_DF (bit(8))
398#define AU1X00_MAC_DMA_TXSTAT_UR (bit(7))
399#define AU1X00_MAC_DMA_TXSTAT_EC (bit(6))
400#define AU1X00_MAC_DMA_TXSTAT_LC (bit(5))
401#define AU1X00_MAC_DMA_TXSTAT_ED (bit(4))
402#define AU1X00_MAC_DMA_TXSTAT_LS (bit(3))
403#define AU1X00_MAC_DMA_TXSTAT_NC (bit(2))
404#define AU1X00_MAC_DMA_TXSTAT_JT (bit(1))
405#define AU1X00_MAC_DMA_TXSTAT_FA (bit(0))
406#define AU1X00_MAC_DMA_TXADDR_ADDR(x) ((x) & ~0x1f)
407#define AU1X00_MAC_DMA_TXADDR_CB_MASK (0x3 << 0x2)
408#define AU1X00_MAC_DMA_TXADDR_DN (bit(1))
409#define AU1X00_MAC_DMA_TXADDR_EN (bit(0))
410
411
412
413typedef struct {
414 volatile uint32_t rxdata;
415 volatile uint32_t txdata;
416 volatile uint32_t inten;
417 volatile uint32_t intcause;
418 volatile uint32_t fifoctrl;
419 volatile uint32_t linectrl;
420 volatile uint32_t mdmctrl;
421 volatile uint32_t linestat;
422 volatile uint32_t mdmstat;
423 volatile uint32_t clkdiv;
424 volatile uint32_t _resv[54];
425 volatile uint32_t enable;
427
428extern au1x00_uart_t *uart0;
429extern au1x00_uart_t *uart3;
430
431void static inline au_sync(void)
432{
433 __asm__ volatile ("sync");
434}
435
436
437extern void mips_default_isr( int vector );
438
439/* Generate a software interrupt */
440extern int assert_sw_irq(uint32_t irqnum);
441
442/* Clear a software interrupt */
443extern int negate_sw_irq(uint32_t irqnum);
444
445#endif
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: au1x00.h:312
Definition: au1x00.h:320
Definition: au1x00.h:413
