RTEMS 5.2-rc1
atsam-clock-config.h
1/*
2 * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef ATSAM_CLOCK_CONFIG_H
16#define ATSAM_CLOCK_CONFIG_H
17
18#include <rtems.h>
19#include <bsp/linker-symbols.h>
20#include <bspopts.h>
21
22#ifdef __cplusplus
23extern "C" {
24#endif /* __cplusplus */
25
26#if ATSAM_CHANGE_CLOCK_FROM_SRAM != 0
27/* Note: fast_text is the simplest section to put this code into. Other
28 * possibilities would include creating a new section. */
29#define ATSAM_START_SRAM_SECTION BSP_FAST_TEXT_SECTION
30#else
31#define ATSAM_START_SRAM_SECTION
32#endif
33
35 /* Initialization value for the PMC_PLLAR. */
36 uint32_t pllar_init;
37 /* Initialization value for the PMC_MCKR. */
38 uint32_t mckr_init;
39 /* Resulting frequency in Hz. */
40 uint32_t mck_freq;
41};
42
43ATSAM_START_SRAM_SECTION
44extern const struct atsam_clock_config atsam_clock_config;
45
46#define BOARD_MCK (atsam_clock_config.mck_freq)
47
48typedef struct BOARD_Sdram_Config {
49 uint32_t sdramc_tr;
50 uint32_t sdramc_cr;
51 uint32_t sdramc_mdr;
52 uint32_t sdramc_cfr1;
53 uint32_t sdramc_lpr;
55
56ATSAM_START_SRAM_SECTION
58
59#ifdef __cplusplus
60}
61#endif /* __cplusplus */
62
63#endif /* ATSAM_CLOCK_CONFIG_H */
Definition: atsam-clock-config.h:48
Definition: atsam-clock-config.h:34
