RTEMS 5.2-rc1
Data Structures | Macros
at91rm9200_usart.h File Reference
Atmel AT91RM9200_USART Register definitions. More...
#include <bits.h>
struct  at91rm9200_usart_regs_t
#define US_CR   0x00 /* Control Register */
#define US_MR   0x04 /* Mode Register */
#define US_IER   0x08 /* Interrupt Enable Register */
#define US_IDR   0x0C /* Interrupt Disable Register */
#define US_IMR   0x10 /* Interrupt Mask Register */
#define US_SR   0x14 /* Channel Status Register */
#define US_RHR   0x18 /* Receiver Holding Register */
#define US_THR   0x1C /* Transmitter Holding Register */
#define US_BRGR   0x20 /* Baud Rate Generator Register */
#define US_RTOR   0x24 /* Receiver Time-out Register */
#define US_TTGR   0x28 /* Transmitter Timeguard Register */
#define US_C1R   0x40 /* Chip ID1 Register - FI DI Ratio Register */
#define US_C2R   0x44 /* Chip ID2 Register - Number of Erros Register */
#define US_FNTR   0x48 /* Force NTRST Register */
#define US_IF   0x4C /* IrDA Filter Register */
#define US_CR_RSTRX   BIT2 /* 1 = Reset and disable receiver */
#define US_CR_RSTTX   BIT3 /* 1 = Reset and disable transmitter */
#define US_CR_RXEN   BIT4 /* 1 = Receiver enable */
#define US_CR_RXDIS   BIT5 /* 1 = Receiver disable */
#define US_CR_TXEN   BIT6 /* 1 = Transmitter enable */
#define US_CR_TXDIS   BIT7 /* 1 = Transmitter disable */
#define US_CR_RSTSTA   BIT8 /* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */
#define US_CR_STTBRK   BIT9 /* 1 = Start transmission of a Break */
#define US_CR_STPBRK   BIT10 /* 1 = Stop transmission of a Break */
#define US_CR_STTTO   BIT11 /* 1 = Start Time-out */
#define US_CR_SENDA   BIT12 /* 1 = Send Address - MDROP mode only */
#define US_CR_RSTIT   BIT13 /* 1 = Reset Iteration */
#define US_CR_RSTNACK   BIT14 /* 1 = Reset Non Acknowledge */
#define US_CR_RETTO   BIT15 /* 1 = Restart Time-out */
#define US_CR_DTREN   BIT16 /* 1 = Data Terminal Ready Enable - AT91RM9200 only */
#define US_CR_DTRDIS   BIT17 /* 1 = Data Terminal Ready Disable - AT91RM9200 only */
#define US_CR_RTSEN   BIT18 /* 1 = Request To Send Enable */
#define US_CR_RTSDIS   BIT19 /* 1 = Request To Send Disable */
#define US_MR_USMODE   (0xF << 0) /* Mode of the USART */
#define US_MR_USMODE_NORMAL   0
#define US_MR_USMODE_RS485   1
#define US_MR_USMODE_HWHS   2
#define US_MR_USMODE_MODEM   3
#define US_MR_USMODE_ISO7816_T0   4
#define US_MR_USMODE_ISO7816_T1   6
#define US_MR_USMODE_IRDA   8
#define US_MR_USCLKS   (3 << 4) /* Clock Selection */
#define US_MR_USCLKS_MCK   (0 << 4)
#define US_MR_USCLKS_MCK_DIV8   (1 << 4)
#define US_MR_USCLKS_SCK   (3 << 4)
#define US_MR_CHRL   (3 << 6) /* Character Length */
#define US_MR_CHRL_5   (0 << 6)
#define US_MR_CHRL_6   (1 << 6)
#define US_MR_CHRL_7   (2 << 6)
#define US_MR_CHRL_8   (3 << 6)
#define US_MR_SYNC   (1 << 8) /* Synchronous Mode Select */
#define US_MR_PAR   (7 << 9) /* Parity Type */
#define US_MR_PAR_EVEN   (0 << 9) /* Even Parity */
#define US_MR_PAR_ODD   (1 << 9) /* Odd Parity */
#define US_MR_PAR_SPACE   (2 << 9) /* Parity forced to 0 (Space) */
#define US_MR_PAR_MARK   (3 << 9) /* Parity forced to 1 (Mark) */
#define US_MR_PAR_NONE   (4 << 9) /* No Parity */
#define US_MR_PAR_MDROP   (6 << 9) /* Multi-drop mode */
#define US_MR_NBSTOP   (3 << 12) /* Number of Stop Bits */
#define US_MR_NBSTOP_1   (0 << 12)
#define US_MR_NBSTOP_1_5   (1 << 12)
#define US_MR_NBSTOP_2   (2 << 12)
#define US_MR_CHMODE   (3 << 14) /* Channel Mode */
#define US_MR_CHMODE_NORM   (0 << 14) /* Normal Mode */
#define US_MR_CHMODE_AUTO   (1 << 14) /* Auto Echo: RXD drives TXD */
#define US_MR_CHMODE_LOC   (2 << 14) /* Local Loopback: TXD drives RXD */
#define US_MR_CHMODE_REM   (3 << 14) /* Remote Loopback: RXD pin connected to TXD pin. */
#define US_MR_MSBF   (1 << 16) /* Bit Order */
#define US_MR_MODE9   (1 << 17) /* 9-bit Character Length */
#define US_MR_CLKO   (1 << 18) /* Clock Output Select */
#define US_MR_OVER   (1 << 19) /* Oversampling Mode */
#define US_MR_INACK   (1 << 20) /* Inhibit Non Acknowledge */
#define US_MR_DSNACK   (1 << 21) /* Disable Successive NACK */
#define US_MR_MAX_ITER   (7 << 24) /* Max Iterations */
#define US_MR_FILTER   (1 << 28) /* Infrared Receive Line Filter */
#define US_IER_RXRDY   BIT0 /* RXRDY Interrupt */
#define US_IER_TXRDY   BIT1 /* TXRDY Interrupt */
#define US_IER_RXBRK   BIT2 /* End of Receive Transfer Interrupt */
#define US_IER_ENDRX   BIT3 /* End of Receiver Transfer */
#define US_IER_OVRE   BIT5 /* Overrun Interrupt */
#define US_IER_FRAME   BIT6 /* Framing Error Interrupt */
#define US_IER_PARE   BIT7 /* Parity Error */
#define US_IER_TIMEOUT   BIT8 /* Receiver Time-out */
#define US_IER_TXEMPTY   BIT9 /* Transmitter Empty */
#define US_IER_ITERATION   BIT10 /* Max number of Repetitions Reached */
#define US_IER_TXBUFE   BIT11 /* Transmission Buffer Empty */
#define US_IER_RXBUFF   BIT12 /* Reception Buffer Full */
#define US_IER_NACK   BIT13 /* Non Acknowledge */
#define US_IER_RIIC   BIT16 /* Ring Indicator Input Change [AT91RM9200 only] */
#define US_IER_DSRIC   BIT17 /* Data Set Ready Input Change [AT91RM9200 only] */
#define US_IER_DCDIC   BIT18 /* Data Carrier Detect Input Change [AT91RM9200 only] */
#define US_IER_CTSIC   BIT19 /* Clear to Send Input Change */
#define US_IER_ALL   0xC0001AFB /* all assigned bits */
#define US_FNTR_NTRST   BIT0 /* 1 = Force NTRST low in JTAG */
