RTEMS 5.2-rc1
i2c.c File Reference
I2C support implementation. More...
#include <bsp.h>
#include <bsp/i2c.h>
void lpc32xx_i2c_reset (volatile lpc32xx_i2c *i2c)
 Resets the I2C module i2c.
rtems_status_code lpc32xx_i2c_init (volatile lpc32xx_i2c *i2c, unsigned clock_in_hz)
 Initializes the I2C module i2c. More...
rtems_status_code lpc32xx_i2c_clock (volatile lpc32xx_i2c *i2c, unsigned clock_in_hz)
 Sets the I2C module i2c clock. More...
rtems_status_code lpc32xx_i2c_write_start (volatile lpc32xx_i2c *i2c, unsigned addr)
 Starts a write transaction on the I2C module i2c. More...
rtems_status_code lpc32xx_i2c_read_start (volatile lpc32xx_i2c *i2c, unsigned addr)
 Starts a read transaction on the I2C module i2c. More...
rtems_status_code lpc32xx_i2c_write_with_optional_stop (volatile lpc32xx_i2c *i2c, const uint8_t *out, size_t n, bool stop)
 Writes data via the I2C module i2c with optional stop. More...
rtems_status_code lpc32xx_i2c_read_with_optional_stop (volatile lpc32xx_i2c *i2c, uint8_t *in, size_t n, bool stop)
 Reads data via the I2C module i2c with optional stop. More...
rtems_status_code lpc32xx_i2c_write_and_read (volatile lpc32xx_i2c *i2c, unsigned addr, const uint8_t *out, size_t out_size, uint8_t *in, size_t in_size)
 Writes and reads data via the I2C module i2c. More...
