RTEMS 5.2-rc1
uart.h
1
9/*
10 * This software is Copyright (C) 1998 by T.sqware - all rights limited
11 * It is provided in to the public domain "as is", can be freely modified
12 * as far as this copyight notice is kept unchanged, but does not imply
13 * an endorsement by T.sqware of the product in which it is included.
14 *
15 * Copyright (c) Canon Research France SA.]
16 * Emmanuel Raguet, mailto:raguet@crf.canon.fr
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _BSPUART_H
24#define _BSPUART_H
25
26#include <rtems/bspIo.h>
27
28void BSP_uart_init(int uart, int baud, int hwFlow);
29void BSP_uart_set_baud(int aurt, int baud);
30void BSP_uart_intr_ctrl(int uart, int cmd);
31void BSP_uart_throttle(int uart);
32void BSP_uart_unthrottle(int uart);
33int BSP_uart_polled_status(int uart);
34void BSP_uart_polled_write(int uart, int val);
35int BSP_uart_polled_read(int uart);
36void BSP_uart_termios_set(int uart, void *ttyp);
37int BSP_uart_termios_write_com1(int minor, const char *buf, int len);
38int BSP_uart_termios_write_com2(int minor, const char *buf, int len);
39void BSP_uart_termios_isr_com1(void);
40void BSP_uart_termios_isr_com2(void);
41void BSP_uart_dbgisr_com1(void);
42void BSP_uart_dbgisr_com2(void);
43extern unsigned BSP_poll_char_via_serial(void);
44extern void BSP_output_char_via_serial(int val);
45extern int BSPConsolePort;
46extern int BSPBaseBaud;
47/*
48 * Command values for BSP_uart_intr_ctrl(),
49 * values are strange in order to catch errors
50 * with assert
51 */
52#define BSP_UART_INTR_CTRL_DISABLE (0)
53#define BSP_UART_INTR_CTRL_GDB (0xaa) /* RX only */
54#define BSP_UART_INTR_CTRL_ENABLE (0xbb) /* Normal operations */
55#define BSP_UART_INTR_CTRL_TERMIOS (0xcc) /* RX & line status */
56
57/* Return values for uart_polled_status() */
58#define BSP_UART_STATUS_ERROR (-1) /* No character */
59#define BSP_UART_STATUS_NOCHAR (0) /* No character */
60#define BSP_UART_STATUS_CHAR (1) /* Character present */
61#define BSP_UART_STATUS_BREAK (2) /* Break point is detected */
62
63/* PC UART definitions */
64#define BSP_UART_COM1 (0)
65#define BSP_UART_COM2 (1)
66
67/*
68 * Base IO for UART
69 */
70
71#define COM1_BASE_IO 0x3F8
72#define COM2_BASE_IO 0x2F8
73
74/*
75 * Offsets from base
76 */
77
78/* DLAB 0 */
79#define RBR RSRBR /* Rx Buffer Register (read) */
80#define THR RSTHR /* Tx Buffer Register (write) */
81#define IER RSIER /* Interrupt Enable Register */
82
83/* DLAB X */
84#define IIR RSIIR /* Interrupt Ident Register (read) */
85#define FCR RSFCR /* FIFO Control Register (write) */
86#define LCR RSLCR /* Line Control Register */
87#define LSR RSLSR /* Line Status Register */
88
89/* DLAB 1 */
90#define DLL RSDLL /* Divisor Latch, LSB */
91#define DLM RSDLH /* Divisor Latch, MSB */
92
93/* Uart control */
94#define CNT RSCNT /* General Control register */
95
96/*
97 * define bit for CNT
98 */
99#define UART_ENABLE 1
100#define PAD_ENABLE 2
101
102/*
103 * Interrupt source definition via IIR
104 */
105#define NO_MORE_INTR 1
106#define TRANSMITTER_HODING_REGISTER_EMPTY 2
107#define RECEIVER_DATA_AVAIL 4
108#define RECEIVER_ERROR 6
109#define CHARACTER_TIMEOUT_INDICATION 12
110
111/*
112 * Bits definition of IER
113 */
114#define RECEIVE_ENABLE 0x1
115#define TRANSMIT_ENABLE 0x2
116#define RECEIVER_LINE_ST_ENABLE 0x4
117#define INTERRUPT_DISABLE 0x0
118
119/*
120 * Bits definition of the Line Status Register (LSR)
121 */
122#define DR 0x01 /* Data Ready */
123#define OE 0x02 /* Overrun Error */
124#define PE 0x04 /* Parity Error */
125#define FE 0x08 /* Framing Error */
126#define BI 0x10 /* Break Interrupt */
127#define THRE 0x20 /* Transmitter Holding Register Empty */
128#define TEMT 0x40 /* Transmitter Empty */
129#define ERFIFO 0x80 /* Error receive Fifo */
130
131/*
132 * Bits definition of the Line Control Register (LCR)
133 */
134#define CHR_5_BITS 0
135#define CHR_6_BITS 1
136#define CHR_7_BITS 2
137#define CHR_8_BITS 3
138
139#define WL 0x03 /* Word length mask */
140#define STB 0x04 /* 1 Stop Bit, otherwise 2 Stop Bits */
141#define PEN 0x08 /* Parity Enabled */
142#define EPS 0x10 /* Even Parity Select, otherwise Odd */
143#define SP 0x20 /* Stick Parity */
144#define BCB 0x40 /* Break Control Bit */
145#define DLAB 0x80 /* Enable Divisor Latch Access */
146
147/*
148 * Bits definition of the FIFO Control Register : WD16C552 or NS16550
149 */
150
151#define FIFO_CTRL 0x01 /* Set to 1 permit access to other bits */
152#define FIFO_EN 0x01 /* Enable the FIFO */
153#define XMIT_RESET 0x04 /* Transmit FIFO Reset */
154#define RCV_RESET 0x02 /* Receive FIFO Reset */
155#define FCR3 0x08 /* do not understand manual! */
156
157#define RECEIVE_FIFO_TRIGGER1 0x0 /* trigger recieve interrupt after 1 byte */
158#define RECEIVE_FIFO_TRIGGER4 0x40 /* trigger recieve interrupt after 4 byte */
159#define RECEIVE_FIFO_TRIGGER8 0x80 /* trigger recieve interrupt after 8 byte */
160#define RECEIVE_FIFO_TRIGGER12 0xc0 /* trigger recieve interrupt after 14 byte */
161#define TRIG_LEVEL 0xc0 /* Mask for the trigger level */
162
163#endif /* _BSPUART_H */
Interface to Kernel Print Methods.
