RTEMS 5.2-rc1
arm-gic-irq.h
1
9/*
10 * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <info@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
24#define LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
25
26#include <bsp.h>
27#include <bsp/arm-gic.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif /* __cplusplus */
33
34#define ARM_GIC_IRQ_SGI_0 0
35#define ARM_GIC_IRQ_SGI_1 1
36#define ARM_GIC_IRQ_SGI_2 2
37#define ARM_GIC_IRQ_SGI_3 3
38#define ARM_GIC_IRQ_SGI_5 5
39#define ARM_GIC_IRQ_SGI_6 6
40#define ARM_GIC_IRQ_SGI_7 7
41#define ARM_GIC_IRQ_SGI_8 8
42#define ARM_GIC_IRQ_SGI_9 9
43#define ARM_GIC_IRQ_SGI_10 10
44#define ARM_GIC_IRQ_SGI_11 11
45#define ARM_GIC_IRQ_SGI_12 12
46#define ARM_GIC_IRQ_SGI_13 13
47#define ARM_GIC_IRQ_SGI_14 14
48#define ARM_GIC_IRQ_SGI_15 15
49
50#define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
51
52rtems_status_code arm_gic_irq_set_priority(
54 uint8_t priority
55);
56
57rtems_status_code arm_gic_irq_get_priority(
59 uint8_t *priority
60);
61
62rtems_status_code arm_gic_irq_set_group(
64 gic_group group
65);
66
67rtems_status_code arm_gic_irq_get_group(
69 gic_group *group
70);
71
72void bsp_interrupt_set_affinity(
74 const Processor_mask *affinity
75);
76
77void bsp_interrupt_get_affinity(
79 Processor_mask *affinity
80);
81
82typedef enum {
83 ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
84 ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_EXCEPT_SELF,
85 ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF
86} arm_gic_irq_software_irq_target_filter;
87
88void arm_gic_trigger_sgi(
90 arm_gic_irq_software_irq_target_filter filter,
91 uint8_t targets
92);
93
94static inline rtems_status_code arm_gic_irq_generate_software_irq(
96 arm_gic_irq_software_irq_target_filter filter,
97 uint8_t targets
98)
99{
101
102 if (vector <= ARM_GIC_IRQ_SGI_15) {
103 arm_gic_trigger_sgi(vector, filter, targets);
104 } else {
105 sc = RTEMS_INVALID_ID;
106 }
107
108 return sc;
109}
110
111static inline uint32_t arm_gic_irq_processor_count(void)
112{
113 volatile gic_dist *dist = ARM_GIC_DIST;
114
115 return GIC_DIST_ICDICTR_CPU_NUMBER_GET(dist->icdictr) + 1;
116}
117
118void arm_gic_irq_initialize_secondary_cpu(void);
119
120#ifdef __cplusplus
121}
122#endif /* __cplusplus */
123
124#endif /* LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H */
ARM GIC Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
@ RTEMS_SUCCESSFUL
Definition: status.h:47
@ RTEMS_INVALID_ID
Definition: status.h:63
Processor Mask API.
Definition: arm-gic-regs.h:88
