RTEMS 5.2-rc1
Data Structures | Macros | Typedefs
alt_rstmgr.h File Reference
struct  ALT_RSTMGR_STAT_s
struct  ALT_RSTMGR_CTL_s
struct  ALT_RSTMGR_COUNTS_s
struct  ALT_RSTMGR_MPUMODRST_s
struct  ALT_RSTMGR_PERMODRST_s
struct  ALT_RSTMGR_PER2MODRST_s
struct  ALT_RSTMGR_BRGMODRST_s
struct  ALT_RSTMGR_MISCMODRST_s
struct  ALT_RSTMGR_s
struct  ALT_RSTMGR_raw_s
#define ALT_RSTMGR_STAT_PORVOLTRST_LSB   0
#define ALT_RSTMGR_STAT_PORVOLTRST_MSB   0
#define ALT_RSTMGR_STAT_PORVOLTRST_WIDTH   1
#define ALT_RSTMGR_STAT_PORVOLTRST_SET_MSK   0x00000001
#define ALT_RSTMGR_STAT_PORVOLTRST_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_STAT_PORVOLTRST_RESET   0x0
#define ALT_RSTMGR_STAT_PORVOLTRST_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_STAT_PORVOLTRST_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_STAT_NPORPINRST_LSB   1
#define ALT_RSTMGR_STAT_NPORPINRST_MSB   1
#define ALT_RSTMGR_STAT_NPORPINRST_WIDTH   1
#define ALT_RSTMGR_STAT_NPORPINRST_SET_MSK   0x00000002
#define ALT_RSTMGR_STAT_NPORPINRST_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_STAT_NPORPINRST_RESET   0x0
#define ALT_RSTMGR_STAT_NPORPINRST_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_STAT_NPORPINRST_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_STAT_FPGACOLDRST_LSB   2
#define ALT_RSTMGR_STAT_FPGACOLDRST_MSB   2
#define ALT_RSTMGR_STAT_FPGACOLDRST_WIDTH   1
#define ALT_RSTMGR_STAT_FPGACOLDRST_SET_MSK   0x00000004
#define ALT_RSTMGR_STAT_FPGACOLDRST_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_STAT_FPGACOLDRST_RESET   0x0
#define ALT_RSTMGR_STAT_FPGACOLDRST_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_STAT_FPGACOLDRST_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_LSB   3
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_MSB   3
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_WIDTH   1
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_SET_MSK   0x00000008
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_CLR_MSK   0xfffffff7
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_RESET   0x0
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_RSTMGR_STAT_CFGIOCOLDRST_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_RSTMGR_STAT_SWCOLDRST_LSB   4
#define ALT_RSTMGR_STAT_SWCOLDRST_MSB   4
#define ALT_RSTMGR_STAT_SWCOLDRST_WIDTH   1
#define ALT_RSTMGR_STAT_SWCOLDRST_SET_MSK   0x00000010
#define ALT_RSTMGR_STAT_SWCOLDRST_CLR_MSK   0xffffffef
#define ALT_RSTMGR_STAT_SWCOLDRST_RESET   0x0
#define ALT_RSTMGR_STAT_SWCOLDRST_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_STAT_SWCOLDRST_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_STAT_NRSTPINRST_LSB   8
#define ALT_RSTMGR_STAT_NRSTPINRST_MSB   8
#define ALT_RSTMGR_STAT_NRSTPINRST_WIDTH   1
#define ALT_RSTMGR_STAT_NRSTPINRST_SET_MSK   0x00000100
#define ALT_RSTMGR_STAT_NRSTPINRST_CLR_MSK   0xfffffeff
#define ALT_RSTMGR_STAT_NRSTPINRST_RESET   0x0
#define ALT_RSTMGR_STAT_NRSTPINRST_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_RSTMGR_STAT_NRSTPINRST_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_RSTMGR_STAT_FPGAWARMRST_LSB   9
#define ALT_RSTMGR_STAT_FPGAWARMRST_MSB   9
#define ALT_RSTMGR_STAT_FPGAWARMRST_WIDTH   1
#define ALT_RSTMGR_STAT_FPGAWARMRST_SET_MSK   0x00000200
#define ALT_RSTMGR_STAT_FPGAWARMRST_CLR_MSK   0xfffffdff
#define ALT_RSTMGR_STAT_FPGAWARMRST_RESET   0x0
#define ALT_RSTMGR_STAT_FPGAWARMRST_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_RSTMGR_STAT_FPGAWARMRST_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_RSTMGR_STAT_SWWARMRST_LSB   10
#define ALT_RSTMGR_STAT_SWWARMRST_MSB   10
#define ALT_RSTMGR_STAT_SWWARMRST_WIDTH   1
#define ALT_RSTMGR_STAT_SWWARMRST_SET_MSK   0x00000400
#define ALT_RSTMGR_STAT_SWWARMRST_CLR_MSK   0xfffffbff
#define ALT_RSTMGR_STAT_SWWARMRST_RESET   0x0
#define ALT_RSTMGR_STAT_SWWARMRST_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_RSTMGR_STAT_SWWARMRST_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_RSTMGR_STAT_MPUWD0RST_LSB   12
#define ALT_RSTMGR_STAT_MPUWD0RST_MSB   12
#define ALT_RSTMGR_STAT_MPUWD0RST_WIDTH   1
#define ALT_RSTMGR_STAT_MPUWD0RST_SET_MSK   0x00001000
#define ALT_RSTMGR_STAT_MPUWD0RST_CLR_MSK   0xffffefff
#define ALT_RSTMGR_STAT_MPUWD0RST_RESET   0x0
#define ALT_RSTMGR_STAT_MPUWD0RST_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_RSTMGR_STAT_MPUWD0RST_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_RSTMGR_STAT_MPUWD1RST_LSB   13
#define ALT_RSTMGR_STAT_MPUWD1RST_MSB   13
#define ALT_RSTMGR_STAT_MPUWD1RST_WIDTH   1
#define ALT_RSTMGR_STAT_MPUWD1RST_SET_MSK   0x00002000
#define ALT_RSTMGR_STAT_MPUWD1RST_CLR_MSK   0xffffdfff
#define ALT_RSTMGR_STAT_MPUWD1RST_RESET   0x0
#define ALT_RSTMGR_STAT_MPUWD1RST_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_RSTMGR_STAT_MPUWD1RST_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_RSTMGR_STAT_L4WD0RST_LSB   14
#define ALT_RSTMGR_STAT_L4WD0RST_MSB   14
#define ALT_RSTMGR_STAT_L4WD0RST_WIDTH   1
#define ALT_RSTMGR_STAT_L4WD0RST_SET_MSK   0x00004000
#define ALT_RSTMGR_STAT_L4WD0RST_CLR_MSK   0xffffbfff
#define ALT_RSTMGR_STAT_L4WD0RST_RESET   0x0
#define ALT_RSTMGR_STAT_L4WD0RST_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_RSTMGR_STAT_L4WD0RST_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_RSTMGR_STAT_L4WD1RST_LSB   15
#define ALT_RSTMGR_STAT_L4WD1RST_MSB   15
#define ALT_RSTMGR_STAT_L4WD1RST_WIDTH   1
#define ALT_RSTMGR_STAT_L4WD1RST_SET_MSK   0x00008000
#define ALT_RSTMGR_STAT_L4WD1RST_CLR_MSK   0xffff7fff
#define ALT_RSTMGR_STAT_L4WD1RST_RESET   0x0
#define ALT_RSTMGR_STAT_L4WD1RST_GET(value)   (((value) & 0x00008000) >> 15)
#define ALT_RSTMGR_STAT_L4WD1RST_SET(value)   (((value) << 15) & 0x00008000)
#define ALT_RSTMGR_STAT_FPGADBGRST_LSB   18
#define ALT_RSTMGR_STAT_FPGADBGRST_MSB   18
#define ALT_RSTMGR_STAT_FPGADBGRST_WIDTH   1
#define ALT_RSTMGR_STAT_FPGADBGRST_SET_MSK   0x00040000
#define ALT_RSTMGR_STAT_FPGADBGRST_CLR_MSK   0xfffbffff
#define ALT_RSTMGR_STAT_FPGADBGRST_RESET   0x0
#define ALT_RSTMGR_STAT_FPGADBGRST_GET(value)   (((value) & 0x00040000) >> 18)
#define ALT_RSTMGR_STAT_FPGADBGRST_SET(value)   (((value) << 18) & 0x00040000)
#define ALT_RSTMGR_STAT_CDBGREQRST_LSB   19
#define ALT_RSTMGR_STAT_CDBGREQRST_MSB   19
#define ALT_RSTMGR_STAT_CDBGREQRST_WIDTH   1
#define ALT_RSTMGR_STAT_CDBGREQRST_SET_MSK   0x00080000
#define ALT_RSTMGR_STAT_CDBGREQRST_CLR_MSK   0xfff7ffff
#define ALT_RSTMGR_STAT_CDBGREQRST_RESET   0x0
#define ALT_RSTMGR_STAT_CDBGREQRST_GET(value)   (((value) & 0x00080000) >> 19)
#define ALT_RSTMGR_STAT_CDBGREQRST_SET(value)   (((value) << 19) & 0x00080000)
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_LSB   24
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_MSB   24
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_WIDTH   1
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_SET_MSK   0x01000000
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_CLR_MSK   0xfeffffff
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_RESET   0x0
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_GET(value)   (((value) & 0x01000000) >> 24)
#define ALT_RSTMGR_STAT_SDRSELFREFTMO_SET(value)   (((value) << 24) & 0x01000000)
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_LSB   25
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_MSB   25
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_WIDTH   1
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_SET_MSK   0x02000000
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_CLR_MSK   0xfdffffff
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_RESET   0x0
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_GET(value)   (((value) & 0x02000000) >> 25)
#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_SET(value)   (((value) << 25) & 0x02000000)
#define ALT_RSTMGR_STAT_SCANHSTMO_LSB   26
#define ALT_RSTMGR_STAT_SCANHSTMO_MSB   26
#define ALT_RSTMGR_STAT_SCANHSTMO_WIDTH   1
#define ALT_RSTMGR_STAT_SCANHSTMO_SET_MSK   0x04000000
#define ALT_RSTMGR_STAT_SCANHSTMO_CLR_MSK   0xfbffffff
#define ALT_RSTMGR_STAT_SCANHSTMO_RESET   0x0
#define ALT_RSTMGR_STAT_SCANHSTMO_GET(value)   (((value) & 0x04000000) >> 26)
#define ALT_RSTMGR_STAT_SCANHSTMO_SET(value)   (((value) << 26) & 0x04000000)
#define ALT_RSTMGR_STAT_FPGAHSTMO_LSB   27
#define ALT_RSTMGR_STAT_FPGAHSTMO_MSB   27
#define ALT_RSTMGR_STAT_FPGAHSTMO_WIDTH   1
#define ALT_RSTMGR_STAT_FPGAHSTMO_SET_MSK   0x08000000
#define ALT_RSTMGR_STAT_FPGAHSTMO_CLR_MSK   0xf7ffffff
#define ALT_RSTMGR_STAT_FPGAHSTMO_RESET   0x0
#define ALT_RSTMGR_STAT_FPGAHSTMO_GET(value)   (((value) & 0x08000000) >> 27)
#define ALT_RSTMGR_STAT_FPGAHSTMO_SET(value)   (((value) << 27) & 0x08000000)
#define ALT_RSTMGR_STAT_ETRSTALLTMO_LSB   28
#define ALT_RSTMGR_STAT_ETRSTALLTMO_MSB   28
#define ALT_RSTMGR_STAT_ETRSTALLTMO_WIDTH   1
#define ALT_RSTMGR_STAT_ETRSTALLTMO_SET_MSK   0x10000000
#define ALT_RSTMGR_STAT_ETRSTALLTMO_CLR_MSK   0xefffffff
#define ALT_RSTMGR_STAT_ETRSTALLTMO_RESET   0x0
#define ALT_RSTMGR_STAT_ETRSTALLTMO_GET(value)   (((value) & 0x10000000) >> 28)
#define ALT_RSTMGR_STAT_ETRSTALLTMO_SET(value)   (((value) << 28) & 0x10000000)
#define ALT_RSTMGR_STAT_OFST   0x0
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_LSB   0
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_MSB   0
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_WIDTH   1
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_SET_MSK   0x00000001
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_RESET   0x0
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_LSB   1
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_MSB   1
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_WIDTH   1
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK   0x00000002
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_RESET   0x0
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_CTL_SDRSELFREFEN_LSB   4
#define ALT_RSTMGR_CTL_SDRSELFREFEN_MSB   4
#define ALT_RSTMGR_CTL_SDRSELFREFEN_WIDTH   1
#define ALT_RSTMGR_CTL_SDRSELFREFEN_SET_MSK   0x00000010
#define ALT_RSTMGR_CTL_SDRSELFREFEN_CLR_MSK   0xffffffef
#define ALT_RSTMGR_CTL_SDRSELFREFEN_RESET   0x0
#define ALT_RSTMGR_CTL_SDRSELFREFEN_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_CTL_SDRSELFREFEN_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_LSB   5
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_MSB   5
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_WIDTH   1
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_SET_MSK   0x00000020
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_CLR_MSK   0xffffffdf
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_RESET   0x0
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_RSTMGR_CTL_SDRSELFREFREQ_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_RSTMGR_CTL_SDRSELFREQACK_LSB   6
#define ALT_RSTMGR_CTL_SDRSELFREQACK_MSB   6
#define ALT_RSTMGR_CTL_SDRSELFREQACK_WIDTH   1
#define ALT_RSTMGR_CTL_SDRSELFREQACK_SET_MSK   0x00000040
#define ALT_RSTMGR_CTL_SDRSELFREQACK_CLR_MSK   0xffffffbf
#define ALT_RSTMGR_CTL_SDRSELFREQACK_RESET   0x0
#define ALT_RSTMGR_CTL_SDRSELFREQACK_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_RSTMGR_CTL_SDRSELFREQACK_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_LSB   8
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_MSB   8
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_SET_MSK   0x00000100
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_CLR_MSK   0xfffffeff
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_RSTMGR_CTL_FPGAMGRHSEN_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_LSB   9
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_MSB   9
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_SET_MSK   0x00000200
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_CLR_MSK   0xfffffdff
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_LSB   10
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_MSB   10
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_SET_MSK   0x00000400
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_CLR_MSK   0xfffffbff
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_RSTMGR_CTL_FPGAMGRHSACK_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_RSTMGR_CTL_SCANMGRHSEN_LSB   12
#define ALT_RSTMGR_CTL_SCANMGRHSEN_MSB   12
#define ALT_RSTMGR_CTL_SCANMGRHSEN_WIDTH   1
#define ALT_RSTMGR_CTL_SCANMGRHSEN_SET_MSK   0x00001000
#define ALT_RSTMGR_CTL_SCANMGRHSEN_CLR_MSK   0xffffefff
#define ALT_RSTMGR_CTL_SCANMGRHSEN_RESET   0x0
#define ALT_RSTMGR_CTL_SCANMGRHSEN_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_RSTMGR_CTL_SCANMGRHSEN_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_LSB   13
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_MSB   13
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_WIDTH   1
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_SET_MSK   0x00002000
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_CLR_MSK   0xffffdfff
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_RESET   0x0
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_RSTMGR_CTL_SCANMGRHSREQ_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_RSTMGR_CTL_SCANMGRHSACK_LSB   14
#define ALT_RSTMGR_CTL_SCANMGRHSACK_MSB   14
#define ALT_RSTMGR_CTL_SCANMGRHSACK_WIDTH   1
#define ALT_RSTMGR_CTL_SCANMGRHSACK_SET_MSK   0x00004000
#define ALT_RSTMGR_CTL_SCANMGRHSACK_CLR_MSK   0xffffbfff
#define ALT_RSTMGR_CTL_SCANMGRHSACK_RESET   0x0
#define ALT_RSTMGR_CTL_SCANMGRHSACK_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_RSTMGR_CTL_SCANMGRHSACK_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_RSTMGR_CTL_FPGAHSEN_LSB   16
#define ALT_RSTMGR_CTL_FPGAHSEN_MSB   16
#define ALT_RSTMGR_CTL_FPGAHSEN_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAHSEN_SET_MSK   0x00010000
#define ALT_RSTMGR_CTL_FPGAHSEN_CLR_MSK   0xfffeffff
#define ALT_RSTMGR_CTL_FPGAHSEN_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAHSEN_GET(value)   (((value) & 0x00010000) >> 16)
#define ALT_RSTMGR_CTL_FPGAHSEN_SET(value)   (((value) << 16) & 0x00010000)
#define ALT_RSTMGR_CTL_FPGAHSREQ_LSB   17
#define ALT_RSTMGR_CTL_FPGAHSREQ_MSB   17
#define ALT_RSTMGR_CTL_FPGAHSREQ_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAHSREQ_SET_MSK   0x00020000
#define ALT_RSTMGR_CTL_FPGAHSREQ_CLR_MSK   0xfffdffff
#define ALT_RSTMGR_CTL_FPGAHSREQ_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAHSREQ_GET(value)   (((value) & 0x00020000) >> 17)
#define ALT_RSTMGR_CTL_FPGAHSREQ_SET(value)   (((value) << 17) & 0x00020000)
#define ALT_RSTMGR_CTL_FPGAHSACK_LSB   18
#define ALT_RSTMGR_CTL_FPGAHSACK_MSB   18
#define ALT_RSTMGR_CTL_FPGAHSACK_WIDTH   1
#define ALT_RSTMGR_CTL_FPGAHSACK_SET_MSK   0x00040000
#define ALT_RSTMGR_CTL_FPGAHSACK_CLR_MSK   0xfffbffff
#define ALT_RSTMGR_CTL_FPGAHSACK_RESET   0x0
#define ALT_RSTMGR_CTL_FPGAHSACK_GET(value)   (((value) & 0x00040000) >> 18)
#define ALT_RSTMGR_CTL_FPGAHSACK_SET(value)   (((value) << 18) & 0x00040000)
#define ALT_RSTMGR_CTL_ETRSTALLEN_LSB   20
#define ALT_RSTMGR_CTL_ETRSTALLEN_MSB   20
#define ALT_RSTMGR_CTL_ETRSTALLEN_WIDTH   1
#define ALT_RSTMGR_CTL_ETRSTALLEN_SET_MSK   0x00100000
#define ALT_RSTMGR_CTL_ETRSTALLEN_CLR_MSK   0xffefffff
#define ALT_RSTMGR_CTL_ETRSTALLEN_RESET   0x1
#define ALT_RSTMGR_CTL_ETRSTALLEN_GET(value)   (((value) & 0x00100000) >> 20)
#define ALT_RSTMGR_CTL_ETRSTALLEN_SET(value)   (((value) << 20) & 0x00100000)
#define ALT_RSTMGR_CTL_ETRSTALLREQ_LSB   21
#define ALT_RSTMGR_CTL_ETRSTALLREQ_MSB   21
#define ALT_RSTMGR_CTL_ETRSTALLREQ_WIDTH   1
#define ALT_RSTMGR_CTL_ETRSTALLREQ_SET_MSK   0x00200000
#define ALT_RSTMGR_CTL_ETRSTALLREQ_CLR_MSK   0xffdfffff
#define ALT_RSTMGR_CTL_ETRSTALLREQ_RESET   0x0
#define ALT_RSTMGR_CTL_ETRSTALLREQ_GET(value)   (((value) & 0x00200000) >> 21)
#define ALT_RSTMGR_CTL_ETRSTALLREQ_SET(value)   (((value) << 21) & 0x00200000)
#define ALT_RSTMGR_CTL_ETRSTALLACK_LSB   22
#define ALT_RSTMGR_CTL_ETRSTALLACK_MSB   22
#define ALT_RSTMGR_CTL_ETRSTALLACK_WIDTH   1
#define ALT_RSTMGR_CTL_ETRSTALLACK_SET_MSK   0x00400000
#define ALT_RSTMGR_CTL_ETRSTALLACK_CLR_MSK   0xffbfffff
#define ALT_RSTMGR_CTL_ETRSTALLACK_RESET   0x0
#define ALT_RSTMGR_CTL_ETRSTALLACK_GET(value)   (((value) & 0x00400000) >> 22)
#define ALT_RSTMGR_CTL_ETRSTALLACK_SET(value)   (((value) << 22) & 0x00400000)
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_LSB   23
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_MSB   23
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_WIDTH   1
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_SET_MSK   0x00800000
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_CLR_MSK   0xff7fffff
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_RESET   0x0
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_GET(value)   (((value) & 0x00800000) >> 23)
#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_SET(value)   (((value) << 23) & 0x00800000)
#define ALT_RSTMGR_CTL_OFST   0x4
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_LSB   0
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_MSB   7
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_WIDTH   8
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_SET_MSK   0x000000ff
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_CLR_MSK   0xffffff00
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_RESET   0x80
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_GET(value)   (((value) & 0x000000ff) >> 0)
#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_SET(value)   (((value) << 0) & 0x000000ff)
#define ALT_RSTMGR_COUNTS_NRSTCNT_LSB   8
#define ALT_RSTMGR_COUNTS_NRSTCNT_MSB   27
#define ALT_RSTMGR_COUNTS_NRSTCNT_WIDTH   20
#define ALT_RSTMGR_COUNTS_NRSTCNT_SET_MSK   0x0fffff00
#define ALT_RSTMGR_COUNTS_NRSTCNT_CLR_MSK   0xf00000ff
#define ALT_RSTMGR_COUNTS_NRSTCNT_RESET   0x800
#define ALT_RSTMGR_COUNTS_NRSTCNT_GET(value)   (((value) & 0x0fffff00) >> 8)
#define ALT_RSTMGR_COUNTS_NRSTCNT_SET(value)   (((value) << 8) & 0x0fffff00)
#define ALT_RSTMGR_COUNTS_OFST   0x8
#define ALT_RSTMGR_MPUMODRST_CPU0_LSB   0
#define ALT_RSTMGR_MPUMODRST_CPU0_MSB   0
#define ALT_RSTMGR_MPUMODRST_CPU0_WIDTH   1
#define ALT_RSTMGR_MPUMODRST_CPU0_SET_MSK   0x00000001
#define ALT_RSTMGR_MPUMODRST_CPU0_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_MPUMODRST_CPU0_RESET   0x0
#define ALT_RSTMGR_MPUMODRST_CPU0_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_MPUMODRST_CPU0_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_MPUMODRST_CPU1_LSB   1
#define ALT_RSTMGR_MPUMODRST_CPU1_MSB   1
#define ALT_RSTMGR_MPUMODRST_CPU1_WIDTH   1
#define ALT_RSTMGR_MPUMODRST_CPU1_SET_MSK   0x00000002
#define ALT_RSTMGR_MPUMODRST_CPU1_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_MPUMODRST_CPU1_RESET   0x1
#define ALT_RSTMGR_MPUMODRST_CPU1_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_MPUMODRST_CPU1_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_MPUMODRST_WDS_LSB   2
#define ALT_RSTMGR_MPUMODRST_WDS_MSB   2
#define ALT_RSTMGR_MPUMODRST_WDS_WIDTH   1
#define ALT_RSTMGR_MPUMODRST_WDS_SET_MSK   0x00000004
#define ALT_RSTMGR_MPUMODRST_WDS_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_MPUMODRST_WDS_RESET   0x0
#define ALT_RSTMGR_MPUMODRST_WDS_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_MPUMODRST_WDS_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_MPUMODRST_SCUPER_LSB   3
#define ALT_RSTMGR_MPUMODRST_SCUPER_MSB   3
#define ALT_RSTMGR_MPUMODRST_SCUPER_WIDTH   1
#define ALT_RSTMGR_MPUMODRST_SCUPER_SET_MSK   0x00000008
#define ALT_RSTMGR_MPUMODRST_SCUPER_CLR_MSK   0xfffffff7
#define ALT_RSTMGR_MPUMODRST_SCUPER_RESET   0x0
#define ALT_RSTMGR_MPUMODRST_SCUPER_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_RSTMGR_MPUMODRST_SCUPER_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_RSTMGR_MPUMODRST_L2_LSB   4
#define ALT_RSTMGR_MPUMODRST_L2_MSB   4
#define ALT_RSTMGR_MPUMODRST_L2_WIDTH   1
#define ALT_RSTMGR_MPUMODRST_L2_SET_MSK   0x00000010
#define ALT_RSTMGR_MPUMODRST_L2_CLR_MSK   0xffffffef
#define ALT_RSTMGR_MPUMODRST_L2_RESET   0x0
#define ALT_RSTMGR_MPUMODRST_L2_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_MPUMODRST_L2_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_MPUMODRST_OFST   0x10
#define ALT_RSTMGR_PERMODRST_EMAC0_LSB   0
#define ALT_RSTMGR_PERMODRST_EMAC0_MSB   0
#define ALT_RSTMGR_PERMODRST_EMAC0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_EMAC0_SET_MSK   0x00000001
#define ALT_RSTMGR_PERMODRST_EMAC0_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_PERMODRST_EMAC0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_EMAC0_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_PERMODRST_EMAC0_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_PERMODRST_EMAC1_LSB   1
#define ALT_RSTMGR_PERMODRST_EMAC1_MSB   1
#define ALT_RSTMGR_PERMODRST_EMAC1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_EMAC1_SET_MSK   0x00000002
#define ALT_RSTMGR_PERMODRST_EMAC1_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_PERMODRST_EMAC1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_EMAC1_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_PERMODRST_EMAC1_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_PERMODRST_USB0_LSB   2
#define ALT_RSTMGR_PERMODRST_USB0_MSB   2
#define ALT_RSTMGR_PERMODRST_USB0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_USB0_SET_MSK   0x00000004
#define ALT_RSTMGR_PERMODRST_USB0_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_PERMODRST_USB0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_USB0_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_PERMODRST_USB0_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_PERMODRST_USB1_LSB   3
#define ALT_RSTMGR_PERMODRST_USB1_MSB   3
#define ALT_RSTMGR_PERMODRST_USB1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_USB1_SET_MSK   0x00000008
#define ALT_RSTMGR_PERMODRST_USB1_CLR_MSK   0xfffffff7
#define ALT_RSTMGR_PERMODRST_USB1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_USB1_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_RSTMGR_PERMODRST_USB1_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_RSTMGR_PERMODRST_NAND_LSB   4
#define ALT_RSTMGR_PERMODRST_NAND_MSB   4
#define ALT_RSTMGR_PERMODRST_NAND_WIDTH   1
#define ALT_RSTMGR_PERMODRST_NAND_SET_MSK   0x00000010
#define ALT_RSTMGR_PERMODRST_NAND_CLR_MSK   0xffffffef
#define ALT_RSTMGR_PERMODRST_NAND_RESET   0x1
#define ALT_RSTMGR_PERMODRST_NAND_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_PERMODRST_NAND_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_PERMODRST_QSPI_LSB   5
#define ALT_RSTMGR_PERMODRST_QSPI_MSB   5
#define ALT_RSTMGR_PERMODRST_QSPI_WIDTH   1
#define ALT_RSTMGR_PERMODRST_QSPI_SET_MSK   0x00000020
#define ALT_RSTMGR_PERMODRST_QSPI_CLR_MSK   0xffffffdf
#define ALT_RSTMGR_PERMODRST_QSPI_RESET   0x1
#define ALT_RSTMGR_PERMODRST_QSPI_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_RSTMGR_PERMODRST_QSPI_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_RSTMGR_PERMODRST_L4WD0_LSB   6
#define ALT_RSTMGR_PERMODRST_L4WD0_MSB   6
#define ALT_RSTMGR_PERMODRST_L4WD0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_L4WD0_SET_MSK   0x00000040
#define ALT_RSTMGR_PERMODRST_L4WD0_CLR_MSK   0xffffffbf
#define ALT_RSTMGR_PERMODRST_L4WD0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_L4WD0_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_RSTMGR_PERMODRST_L4WD0_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_RSTMGR_PERMODRST_L4WD1_LSB   7
#define ALT_RSTMGR_PERMODRST_L4WD1_MSB   7
#define ALT_RSTMGR_PERMODRST_L4WD1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_L4WD1_SET_MSK   0x00000080
#define ALT_RSTMGR_PERMODRST_L4WD1_CLR_MSK   0xffffff7f
#define ALT_RSTMGR_PERMODRST_L4WD1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_L4WD1_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_RSTMGR_PERMODRST_L4WD1_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_LSB   8
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_MSB   8
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_SET_MSK   0x00000100
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_CLR_MSK   0xfffffeff
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_RSTMGR_PERMODRST_OSC1TMR0_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_LSB   9
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_MSB   9
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_SET_MSK   0x00000200
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_CLR_MSK   0xfffffdff
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_RSTMGR_PERMODRST_OSC1TMR1_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_RSTMGR_PERMODRST_SPTMR0_LSB   10
#define ALT_RSTMGR_PERMODRST_SPTMR0_MSB   10
#define ALT_RSTMGR_PERMODRST_SPTMR0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPTMR0_SET_MSK   0x00000400
#define ALT_RSTMGR_PERMODRST_SPTMR0_CLR_MSK   0xfffffbff
#define ALT_RSTMGR_PERMODRST_SPTMR0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPTMR0_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_RSTMGR_PERMODRST_SPTMR0_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_RSTMGR_PERMODRST_SPTMR1_LSB   11
#define ALT_RSTMGR_PERMODRST_SPTMR1_MSB   11
#define ALT_RSTMGR_PERMODRST_SPTMR1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPTMR1_SET_MSK   0x00000800
#define ALT_RSTMGR_PERMODRST_SPTMR1_CLR_MSK   0xfffff7ff
#define ALT_RSTMGR_PERMODRST_SPTMR1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPTMR1_GET(value)   (((value) & 0x00000800) >> 11)
#define ALT_RSTMGR_PERMODRST_SPTMR1_SET(value)   (((value) << 11) & 0x00000800)
#define ALT_RSTMGR_PERMODRST_I2C0_LSB   12
#define ALT_RSTMGR_PERMODRST_I2C0_MSB   12
#define ALT_RSTMGR_PERMODRST_I2C0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_I2C0_SET_MSK   0x00001000
#define ALT_RSTMGR_PERMODRST_I2C0_CLR_MSK   0xffffefff
#define ALT_RSTMGR_PERMODRST_I2C0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_I2C0_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_RSTMGR_PERMODRST_I2C0_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_RSTMGR_PERMODRST_I2C1_LSB   13
#define ALT_RSTMGR_PERMODRST_I2C1_MSB   13
#define ALT_RSTMGR_PERMODRST_I2C1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_I2C1_SET_MSK   0x00002000
#define ALT_RSTMGR_PERMODRST_I2C1_CLR_MSK   0xffffdfff
#define ALT_RSTMGR_PERMODRST_I2C1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_I2C1_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_RSTMGR_PERMODRST_I2C1_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_RSTMGR_PERMODRST_I2C2_LSB   14
#define ALT_RSTMGR_PERMODRST_I2C2_MSB   14
#define ALT_RSTMGR_PERMODRST_I2C2_WIDTH   1
#define ALT_RSTMGR_PERMODRST_I2C2_SET_MSK   0x00004000
#define ALT_RSTMGR_PERMODRST_I2C2_CLR_MSK   0xffffbfff
#define ALT_RSTMGR_PERMODRST_I2C2_RESET   0x1
#define ALT_RSTMGR_PERMODRST_I2C2_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_RSTMGR_PERMODRST_I2C2_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_RSTMGR_PERMODRST_I2C3_LSB   15
#define ALT_RSTMGR_PERMODRST_I2C3_MSB   15
#define ALT_RSTMGR_PERMODRST_I2C3_WIDTH   1
#define ALT_RSTMGR_PERMODRST_I2C3_SET_MSK   0x00008000
#define ALT_RSTMGR_PERMODRST_I2C3_CLR_MSK   0xffff7fff
#define ALT_RSTMGR_PERMODRST_I2C3_RESET   0x1
#define ALT_RSTMGR_PERMODRST_I2C3_GET(value)   (((value) & 0x00008000) >> 15)
#define ALT_RSTMGR_PERMODRST_I2C3_SET(value)   (((value) << 15) & 0x00008000)
#define ALT_RSTMGR_PERMODRST_UART0_LSB   16
#define ALT_RSTMGR_PERMODRST_UART0_MSB   16
#define ALT_RSTMGR_PERMODRST_UART0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_UART0_SET_MSK   0x00010000
#define ALT_RSTMGR_PERMODRST_UART0_CLR_MSK   0xfffeffff
#define ALT_RSTMGR_PERMODRST_UART0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_UART0_GET(value)   (((value) & 0x00010000) >> 16)
#define ALT_RSTMGR_PERMODRST_UART0_SET(value)   (((value) << 16) & 0x00010000)
#define ALT_RSTMGR_PERMODRST_UART1_LSB   17
#define ALT_RSTMGR_PERMODRST_UART1_MSB   17
#define ALT_RSTMGR_PERMODRST_UART1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_UART1_SET_MSK   0x00020000
#define ALT_RSTMGR_PERMODRST_UART1_CLR_MSK   0xfffdffff
#define ALT_RSTMGR_PERMODRST_UART1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_UART1_GET(value)   (((value) & 0x00020000) >> 17)
#define ALT_RSTMGR_PERMODRST_UART1_SET(value)   (((value) << 17) & 0x00020000)
#define ALT_RSTMGR_PERMODRST_SPIM0_LSB   18
#define ALT_RSTMGR_PERMODRST_SPIM0_MSB   18
#define ALT_RSTMGR_PERMODRST_SPIM0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPIM0_SET_MSK   0x00040000
#define ALT_RSTMGR_PERMODRST_SPIM0_CLR_MSK   0xfffbffff
#define ALT_RSTMGR_PERMODRST_SPIM0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPIM0_GET(value)   (((value) & 0x00040000) >> 18)
#define ALT_RSTMGR_PERMODRST_SPIM0_SET(value)   (((value) << 18) & 0x00040000)
#define ALT_RSTMGR_PERMODRST_SPIM1_LSB   19
#define ALT_RSTMGR_PERMODRST_SPIM1_MSB   19
#define ALT_RSTMGR_PERMODRST_SPIM1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPIM1_SET_MSK   0x00080000
#define ALT_RSTMGR_PERMODRST_SPIM1_CLR_MSK   0xfff7ffff
#define ALT_RSTMGR_PERMODRST_SPIM1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPIM1_GET(value)   (((value) & 0x00080000) >> 19)
#define ALT_RSTMGR_PERMODRST_SPIM1_SET(value)   (((value) << 19) & 0x00080000)
#define ALT_RSTMGR_PERMODRST_SPIS0_LSB   20
#define ALT_RSTMGR_PERMODRST_SPIS0_MSB   20
#define ALT_RSTMGR_PERMODRST_SPIS0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPIS0_SET_MSK   0x00100000
#define ALT_RSTMGR_PERMODRST_SPIS0_CLR_MSK   0xffefffff
#define ALT_RSTMGR_PERMODRST_SPIS0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPIS0_GET(value)   (((value) & 0x00100000) >> 20)
#define ALT_RSTMGR_PERMODRST_SPIS0_SET(value)   (((value) << 20) & 0x00100000)
#define ALT_RSTMGR_PERMODRST_SPIS1_LSB   21
#define ALT_RSTMGR_PERMODRST_SPIS1_MSB   21
#define ALT_RSTMGR_PERMODRST_SPIS1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SPIS1_SET_MSK   0x00200000
#define ALT_RSTMGR_PERMODRST_SPIS1_CLR_MSK   0xffdfffff
#define ALT_RSTMGR_PERMODRST_SPIS1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SPIS1_GET(value)   (((value) & 0x00200000) >> 21)
#define ALT_RSTMGR_PERMODRST_SPIS1_SET(value)   (((value) << 21) & 0x00200000)
#define ALT_RSTMGR_PERMODRST_SDMMC_LSB   22
#define ALT_RSTMGR_PERMODRST_SDMMC_MSB   22
#define ALT_RSTMGR_PERMODRST_SDMMC_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SDMMC_SET_MSK   0x00400000
#define ALT_RSTMGR_PERMODRST_SDMMC_CLR_MSK   0xffbfffff
#define ALT_RSTMGR_PERMODRST_SDMMC_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SDMMC_GET(value)   (((value) & 0x00400000) >> 22)
#define ALT_RSTMGR_PERMODRST_SDMMC_SET(value)   (((value) << 22) & 0x00400000)
#define ALT_RSTMGR_PERMODRST_CAN0_LSB   23
#define ALT_RSTMGR_PERMODRST_CAN0_MSB   23
#define ALT_RSTMGR_PERMODRST_CAN0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_CAN0_SET_MSK   0x00800000
#define ALT_RSTMGR_PERMODRST_CAN0_CLR_MSK   0xff7fffff
#define ALT_RSTMGR_PERMODRST_CAN0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_CAN0_GET(value)   (((value) & 0x00800000) >> 23)
#define ALT_RSTMGR_PERMODRST_CAN0_SET(value)   (((value) << 23) & 0x00800000)
#define ALT_RSTMGR_PERMODRST_CAN1_LSB   24
#define ALT_RSTMGR_PERMODRST_CAN1_MSB   24
#define ALT_RSTMGR_PERMODRST_CAN1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_CAN1_SET_MSK   0x01000000
#define ALT_RSTMGR_PERMODRST_CAN1_CLR_MSK   0xfeffffff
#define ALT_RSTMGR_PERMODRST_CAN1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_CAN1_GET(value)   (((value) & 0x01000000) >> 24)
#define ALT_RSTMGR_PERMODRST_CAN1_SET(value)   (((value) << 24) & 0x01000000)
#define ALT_RSTMGR_PERMODRST_GPIO0_LSB   25
#define ALT_RSTMGR_PERMODRST_GPIO0_MSB   25
#define ALT_RSTMGR_PERMODRST_GPIO0_WIDTH   1
#define ALT_RSTMGR_PERMODRST_GPIO0_SET_MSK   0x02000000
#define ALT_RSTMGR_PERMODRST_GPIO0_CLR_MSK   0xfdffffff
#define ALT_RSTMGR_PERMODRST_GPIO0_RESET   0x1
#define ALT_RSTMGR_PERMODRST_GPIO0_GET(value)   (((value) & 0x02000000) >> 25)
#define ALT_RSTMGR_PERMODRST_GPIO0_SET(value)   (((value) << 25) & 0x02000000)
#define ALT_RSTMGR_PERMODRST_GPIO1_LSB   26
#define ALT_RSTMGR_PERMODRST_GPIO1_MSB   26
#define ALT_RSTMGR_PERMODRST_GPIO1_WIDTH   1
#define ALT_RSTMGR_PERMODRST_GPIO1_SET_MSK   0x04000000
#define ALT_RSTMGR_PERMODRST_GPIO1_CLR_MSK   0xfbffffff
#define ALT_RSTMGR_PERMODRST_GPIO1_RESET   0x1
#define ALT_RSTMGR_PERMODRST_GPIO1_GET(value)   (((value) & 0x04000000) >> 26)
#define ALT_RSTMGR_PERMODRST_GPIO1_SET(value)   (((value) << 26) & 0x04000000)
#define ALT_RSTMGR_PERMODRST_GPIO2_LSB   27
#define ALT_RSTMGR_PERMODRST_GPIO2_MSB   27
#define ALT_RSTMGR_PERMODRST_GPIO2_WIDTH   1
#define ALT_RSTMGR_PERMODRST_GPIO2_SET_MSK   0x08000000
#define ALT_RSTMGR_PERMODRST_GPIO2_CLR_MSK   0xf7ffffff
#define ALT_RSTMGR_PERMODRST_GPIO2_RESET   0x1
#define ALT_RSTMGR_PERMODRST_GPIO2_GET(value)   (((value) & 0x08000000) >> 27)
#define ALT_RSTMGR_PERMODRST_GPIO2_SET(value)   (((value) << 27) & 0x08000000)
#define ALT_RSTMGR_PERMODRST_DMA_LSB   28
#define ALT_RSTMGR_PERMODRST_DMA_MSB   28
#define ALT_RSTMGR_PERMODRST_DMA_WIDTH   1
#define ALT_RSTMGR_PERMODRST_DMA_SET_MSK   0x10000000
#define ALT_RSTMGR_PERMODRST_DMA_CLR_MSK   0xefffffff
#define ALT_RSTMGR_PERMODRST_DMA_RESET   0x1
#define ALT_RSTMGR_PERMODRST_DMA_GET(value)   (((value) & 0x10000000) >> 28)
#define ALT_RSTMGR_PERMODRST_DMA_SET(value)   (((value) << 28) & 0x10000000)
#define ALT_RSTMGR_PERMODRST_SDR_LSB   29
#define ALT_RSTMGR_PERMODRST_SDR_MSB   29
#define ALT_RSTMGR_PERMODRST_SDR_WIDTH   1
#define ALT_RSTMGR_PERMODRST_SDR_SET_MSK   0x20000000
#define ALT_RSTMGR_PERMODRST_SDR_CLR_MSK   0xdfffffff
#define ALT_RSTMGR_PERMODRST_SDR_RESET   0x1
#define ALT_RSTMGR_PERMODRST_SDR_GET(value)   (((value) & 0x20000000) >> 29)
#define ALT_RSTMGR_PERMODRST_SDR_SET(value)   (((value) << 29) & 0x20000000)
#define ALT_RSTMGR_PERMODRST_OFST   0x14
#define ALT_RSTMGR_PER2MODRST_DMAIF0_LSB   0
#define ALT_RSTMGR_PER2MODRST_DMAIF0_MSB   0
#define ALT_RSTMGR_PER2MODRST_DMAIF0_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF0_SET_MSK   0x00000001
#define ALT_RSTMGR_PER2MODRST_DMAIF0_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_PER2MODRST_DMAIF0_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF0_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_PER2MODRST_DMAIF0_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_PER2MODRST_DMAIF1_LSB   1
#define ALT_RSTMGR_PER2MODRST_DMAIF1_MSB   1
#define ALT_RSTMGR_PER2MODRST_DMAIF1_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF1_SET_MSK   0x00000002
#define ALT_RSTMGR_PER2MODRST_DMAIF1_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_PER2MODRST_DMAIF1_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF1_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_PER2MODRST_DMAIF1_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_PER2MODRST_DMAIF2_LSB   2
#define ALT_RSTMGR_PER2MODRST_DMAIF2_MSB   2
#define ALT_RSTMGR_PER2MODRST_DMAIF2_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF2_SET_MSK   0x00000004
#define ALT_RSTMGR_PER2MODRST_DMAIF2_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_PER2MODRST_DMAIF2_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF2_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_PER2MODRST_DMAIF2_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_PER2MODRST_DMAIF3_LSB   3
#define ALT_RSTMGR_PER2MODRST_DMAIF3_MSB   3
#define ALT_RSTMGR_PER2MODRST_DMAIF3_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF3_SET_MSK   0x00000008
#define ALT_RSTMGR_PER2MODRST_DMAIF3_CLR_MSK   0xfffffff7
#define ALT_RSTMGR_PER2MODRST_DMAIF3_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF3_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_RSTMGR_PER2MODRST_DMAIF3_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_RSTMGR_PER2MODRST_DMAIF4_LSB   4
#define ALT_RSTMGR_PER2MODRST_DMAIF4_MSB   4
#define ALT_RSTMGR_PER2MODRST_DMAIF4_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF4_SET_MSK   0x00000010
#define ALT_RSTMGR_PER2MODRST_DMAIF4_CLR_MSK   0xffffffef
#define ALT_RSTMGR_PER2MODRST_DMAIF4_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF4_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_PER2MODRST_DMAIF4_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_PER2MODRST_DMAIF5_LSB   5
#define ALT_RSTMGR_PER2MODRST_DMAIF5_MSB   5
#define ALT_RSTMGR_PER2MODRST_DMAIF5_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF5_SET_MSK   0x00000020
#define ALT_RSTMGR_PER2MODRST_DMAIF5_CLR_MSK   0xffffffdf
#define ALT_RSTMGR_PER2MODRST_DMAIF5_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF5_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_RSTMGR_PER2MODRST_DMAIF5_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_RSTMGR_PER2MODRST_DMAIF6_LSB   6
#define ALT_RSTMGR_PER2MODRST_DMAIF6_MSB   6
#define ALT_RSTMGR_PER2MODRST_DMAIF6_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF6_SET_MSK   0x00000040
#define ALT_RSTMGR_PER2MODRST_DMAIF6_CLR_MSK   0xffffffbf
#define ALT_RSTMGR_PER2MODRST_DMAIF6_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF6_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_RSTMGR_PER2MODRST_DMAIF6_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_RSTMGR_PER2MODRST_DMAIF7_LSB   7
#define ALT_RSTMGR_PER2MODRST_DMAIF7_MSB   7
#define ALT_RSTMGR_PER2MODRST_DMAIF7_WIDTH   1
#define ALT_RSTMGR_PER2MODRST_DMAIF7_SET_MSK   0x00000080
#define ALT_RSTMGR_PER2MODRST_DMAIF7_CLR_MSK   0xffffff7f
#define ALT_RSTMGR_PER2MODRST_DMAIF7_RESET   0x1
#define ALT_RSTMGR_PER2MODRST_DMAIF7_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_RSTMGR_PER2MODRST_DMAIF7_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_RSTMGR_PER2MODRST_OFST   0x18
#define ALT_RSTMGR_BRGMODRST_H2F_LSB   0
#define ALT_RSTMGR_BRGMODRST_H2F_MSB   0
#define ALT_RSTMGR_BRGMODRST_H2F_WIDTH   1
#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK   0x00000001
#define ALT_RSTMGR_BRGMODRST_H2F_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_BRGMODRST_H2F_RESET   0x1
#define ALT_RSTMGR_BRGMODRST_H2F_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_BRGMODRST_H2F_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_BRGMODRST_LWH2F_LSB   1
#define ALT_RSTMGR_BRGMODRST_LWH2F_MSB   1
#define ALT_RSTMGR_BRGMODRST_LWH2F_WIDTH   1
#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK   0x00000002
#define ALT_RSTMGR_BRGMODRST_LWH2F_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_BRGMODRST_LWH2F_RESET   0x1
#define ALT_RSTMGR_BRGMODRST_LWH2F_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_BRGMODRST_LWH2F_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_BRGMODRST_F2H_LSB   2
#define ALT_RSTMGR_BRGMODRST_F2H_MSB   2
#define ALT_RSTMGR_BRGMODRST_F2H_WIDTH   1
#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK   0x00000004
#define ALT_RSTMGR_BRGMODRST_F2H_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_BRGMODRST_F2H_RESET   0x1
#define ALT_RSTMGR_BRGMODRST_F2H_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_BRGMODRST_F2H_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_BRGMODRST_OFST   0x1c
#define ALT_RSTMGR_MISCMODRST_ROM_LSB   0
#define ALT_RSTMGR_MISCMODRST_ROM_MSB   0
#define ALT_RSTMGR_MISCMODRST_ROM_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_ROM_SET_MSK   0x00000001
#define ALT_RSTMGR_MISCMODRST_ROM_CLR_MSK   0xfffffffe
#define ALT_RSTMGR_MISCMODRST_ROM_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_ROM_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_RSTMGR_MISCMODRST_ROM_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_RSTMGR_MISCMODRST_OCRAM_LSB   1
#define ALT_RSTMGR_MISCMODRST_OCRAM_MSB   1
#define ALT_RSTMGR_MISCMODRST_OCRAM_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_OCRAM_SET_MSK   0x00000002
#define ALT_RSTMGR_MISCMODRST_OCRAM_CLR_MSK   0xfffffffd
#define ALT_RSTMGR_MISCMODRST_OCRAM_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_OCRAM_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_RSTMGR_MISCMODRST_OCRAM_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_RSTMGR_MISCMODRST_SYSMGR_LSB   2
#define ALT_RSTMGR_MISCMODRST_SYSMGR_MSB   2
#define ALT_RSTMGR_MISCMODRST_SYSMGR_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_SYSMGR_SET_MSK   0x00000004
#define ALT_RSTMGR_MISCMODRST_SYSMGR_CLR_MSK   0xfffffffb
#define ALT_RSTMGR_MISCMODRST_SYSMGR_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_SYSMGR_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_RSTMGR_MISCMODRST_SYSMGR_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_LSB   3
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_MSB   3
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_SET_MSK   0x00000008
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_CLR_MSK   0xfffffff7
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_LSB   4
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_MSB   4
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_SET_MSK   0x00000010
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_CLR_MSK   0xffffffef
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_RSTMGR_MISCMODRST_FPGAMGR_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_LSB   5
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_MSB   5
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_SET_MSK   0x00000020
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_CLR_MSK   0xffffffdf
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_RSTMGR_MISCMODRST_S2F_LSB   6
#define ALT_RSTMGR_MISCMODRST_S2F_MSB   6
#define ALT_RSTMGR_MISCMODRST_S2F_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_S2F_SET_MSK   0x00000040
#define ALT_RSTMGR_MISCMODRST_S2F_CLR_MSK   0xffffffbf
#define ALT_RSTMGR_MISCMODRST_S2F_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_S2F_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_RSTMGR_MISCMODRST_S2F_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_LSB   7
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_MSB   7
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_SET_MSK   0x00000080
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_CLR_MSK   0xffffff7f
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_RSTMGR_MISCMODRST_S2FCOLD_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_LSB   8
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_MSB   8
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_SET_MSK   0x00000100
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_CLR_MSK   0xfffffeff
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_RSTMGR_MISCMODRST_NRSTPIN_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_RSTMGR_MISCMODRST_TSCOLD_LSB   9
#define ALT_RSTMGR_MISCMODRST_TSCOLD_MSB   9
#define ALT_RSTMGR_MISCMODRST_TSCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_TSCOLD_SET_MSK   0x00000200
#define ALT_RSTMGR_MISCMODRST_TSCOLD_CLR_MSK   0xfffffdff
#define ALT_RSTMGR_MISCMODRST_TSCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_TSCOLD_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_RSTMGR_MISCMODRST_TSCOLD_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_LSB   10
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_MSB   10
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_SET_MSK   0x00000400
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_CLR_MSK   0xfffffbff
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_RSTMGR_MISCMODRST_SCANMGR_LSB   11
#define ALT_RSTMGR_MISCMODRST_SCANMGR_MSB   11
#define ALT_RSTMGR_MISCMODRST_SCANMGR_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_SCANMGR_SET_MSK   0x00000800
#define ALT_RSTMGR_MISCMODRST_SCANMGR_CLR_MSK   0xfffff7ff
#define ALT_RSTMGR_MISCMODRST_SCANMGR_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_SCANMGR_GET(value)   (((value) & 0x00000800) >> 11)
#define ALT_RSTMGR_MISCMODRST_SCANMGR_SET(value)   (((value) << 11) & 0x00000800)
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_LSB   12
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_MSB   12
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_SET_MSK   0x00001000
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_CLR_MSK   0xffffefff
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_RSTMGR_MISCMODRST_SYSDBG_LSB   13
#define ALT_RSTMGR_MISCMODRST_SYSDBG_MSB   13
#define ALT_RSTMGR_MISCMODRST_SYSDBG_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_SYSDBG_SET_MSK   0x00002000
#define ALT_RSTMGR_MISCMODRST_SYSDBG_CLR_MSK   0xffffdfff
#define ALT_RSTMGR_MISCMODRST_SYSDBG_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_SYSDBG_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_RSTMGR_MISCMODRST_SYSDBG_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_RSTMGR_MISCMODRST_DBG_LSB   14
#define ALT_RSTMGR_MISCMODRST_DBG_MSB   14
#define ALT_RSTMGR_MISCMODRST_DBG_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_DBG_SET_MSK   0x00004000
#define ALT_RSTMGR_MISCMODRST_DBG_CLR_MSK   0xffffbfff
#define ALT_RSTMGR_MISCMODRST_DBG_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_DBG_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_RSTMGR_MISCMODRST_DBG_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_LSB   15
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_MSB   15
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_SET_MSK   0x00008000
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_CLR_MSK   0xffff7fff
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_GET(value)   (((value) & 0x00008000) >> 15)
#define ALT_RSTMGR_MISCMODRST_TAPCOLD_SET(value)   (((value) << 15) & 0x00008000)
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_LSB   16
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_MSB   16
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_WIDTH   1
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_SET_MSK   0x00010000
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_CLR_MSK   0xfffeffff
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_RESET   0x0
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_GET(value)   (((value) & 0x00010000) >> 16)
#define ALT_RSTMGR_MISCMODRST_SDRCOLD_SET(value)   (((value) << 16) & 0x00010000)
#define ALT_RSTMGR_MISCMODRST_OFST   0x20
typedef volatile struct ALT_RSTMGR_STAT_s ALT_RSTMGR_STAT_t
typedef volatile struct ALT_RSTMGR_CTL_s ALT_RSTMGR_CTL_t
typedef volatile struct ALT_RSTMGR_COUNTS_s ALT_RSTMGR_COUNTS_t
typedef volatile struct ALT_RSTMGR_MPUMODRST_s ALT_RSTMGR_MPUMODRST_t
typedef volatile struct ALT_RSTMGR_PERMODRST_s ALT_RSTMGR_PERMODRST_t
typedef volatile struct ALT_RSTMGR_PER2MODRST_s ALT_RSTMGR_PER2MODRST_t
typedef volatile struct ALT_RSTMGR_BRGMODRST_s ALT_RSTMGR_BRGMODRST_t
typedef volatile struct ALT_RSTMGR_MISCMODRST_s ALT_RSTMGR_MISCMODRST_t
typedef volatile struct ALT_RSTMGR_s ALT_RSTMGR_t
typedef volatile struct ALT_RSTMGR_raw_s ALT_RSTMGR_raw_t
