RTEMS 5.2-rc1
Macros | Typedefs | Enumerations
alt_interrupt_common.h File Reference
#include "hwlib.h"
#include <stdbool.h>
#include <stddef.h>
#define ALT_INT_ICCIAR_CPUID_GET(icciar)   ((icciar >> 10) & 0x7)
#define ALT_INT_ICCIAR_ACKINTID_GET(icciar)   (icciar & 0x3FF)
typedef enum ALT_INT_INTERRUPT_e ALT_INT_INTERRUPT_t
typedef uint32_t alt_int_cpu_target_t
typedef enum ALT_INT_TRIGGER_e ALT_INT_TRIGGER_t
typedef enum ALT_INT_SGI_TARGET_e ALT_INT_SGI_TARGET_t
typedef void(* alt_int_callback_t) (uint32_t icciar, void *context)
enum  ALT_INT_INTERRUPT_e {
  ALT_INT_INTERRUPT_SGI0 = 0 , ALT_INT_INTERRUPT_SGI1 = 1 , ALT_INT_INTERRUPT_SGI2 = 2 , ALT_INT_INTERRUPT_SGI3 = 3 ,
  ALT_INT_INTERRUPT_SGI4 = 4 , ALT_INT_INTERRUPT_SGI5 = 5 , ALT_INT_INTERRUPT_SGI6 = 6 , ALT_INT_INTERRUPT_SGI7 = 7 ,
  ALT_INT_INTERRUPT_SGI8 = 8 , ALT_INT_INTERRUPT_SGI9 = 9 , ALT_INT_INTERRUPT_SGI10 = 10 , ALT_INT_INTERRUPT_SGI11 = 11 ,
  ALT_INT_INTERRUPT_SGI12 = 12 , ALT_INT_INTERRUPT_SGI13 = 13 , ALT_INT_INTERRUPT_SGI14 = 14 , ALT_INT_INTERRUPT_SGI15 = 15 ,
  ALT_INT_INTERRUPT_PPI_TIMER_GLOBAL = 27 , ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE = 29 , ALT_INT_INTERRUPT_PPI_TIMER_WATCHDOG = 30 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL = 32 ,
  ALT_INT_INTERRUPT_CPU0_PARITYFAIL_BTAC = 33 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_GHB = 34 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_TAG = 35 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_DATA = 36 ,
  ALT_INT_INTERRUPT_CPU0_PARITYFAIL_TLB = 37 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_OUTER = 38 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_TAG = 39 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_DATA = 40 ,
  ALT_INT_INTERRUPT_CPU0_DEFLAGS0 = 41 , ALT_INT_INTERRUPT_CPU0_DEFLAGS1 = 42 , ALT_INT_INTERRUPT_CPU0_DEFLAGS2 = 43 , ALT_INT_INTERRUPT_CPU0_DEFLAGS3 = 44 ,
  ALT_INT_INTERRUPT_CPU0_DEFLAGS4 = 45 , ALT_INT_INTERRUPT_CPU0_DEFLAGS5 = 46 , ALT_INT_INTERRUPT_CPU0_DEFLAGS6 = 47 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL = 48 ,
  ALT_INT_INTERRUPT_CPU1_PARITYFAIL_BTAC = 49 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_GHB = 50 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_TAG = 51 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_DATA = 52 ,
  ALT_INT_INTERRUPT_CPU1_PARITYFAIL_TLB = 53 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_OUTER = 54 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_TAG = 55 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_DATA = 56 ,
  ALT_INT_INTERRUPT_CPU1_DEFLAGS0 = 57 , ALT_INT_INTERRUPT_CPU1_DEFLAGS1 = 58 , ALT_INT_INTERRUPT_CPU1_DEFLAGS2 = 59 , ALT_INT_INTERRUPT_CPU1_DEFLAGS3 = 60 ,
  ALT_INT_INTERRUPT_CPU1_DEFLAGS4 = 61 , ALT_INT_INTERRUPT_CPU1_DEFLAGS5 = 62 , ALT_INT_INTERRUPT_CPU1_DEFLAGS6 = 63 , ALT_INT_INTERRUPT_SCU_PARITYFAIL0 = 64 ,
  ALT_INT_INTERRUPT_SCU_PARITYFAIL1 = 65 , ALT_INT_INTERRUPT_SCU_EV_ABORT = 66 , ALT_INT_INTERRUPT_L2_ECC_BYTE_WR_IRQ = 67 , ALT_INT_INTERRUPT_L2_ECC_CORRECTED_IRQ = 68 ,
  ALT_INT_INTERRUPT_L2_ECC_UNCORRECTED_IRQ = 69 , ALT_INT_INTERRUPT_L2_COMBINED_IRQ = 70 , ALT_INT_INTERRUPT_DDR_ECC_ERROR_IRQ = 71 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ0 = 72 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ1 = 73 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ2 = 74 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ3 = 75 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ4 = 76 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ5 = 77 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ6 = 78 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ7 = 79 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ8 = 80 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ9 = 81 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ10 = 82 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ11 = 83 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ12 = 84 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ13 = 85 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ14 = 86 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ15 = 87 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ16 = 88 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ17 = 89 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ18 = 90 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ19 = 91 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ20 = 92 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ21 = 93 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ22 = 94 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ23 = 95 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ24 = 96 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ25 = 97 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ26 = 98 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ27 = 99 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ28 = 100 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ29 = 101 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ30 = 102 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ31 = 103 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ32 = 104 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ33 = 105 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ34 = 106 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ35 = 107 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ36 = 108 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ37 = 109 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ38 = 110 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ39 = 111 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ40 = 112 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ41 = 113 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ42 = 114 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ43 = 115 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ44 = 116 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ45 = 117 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ46 = 118 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ47 = 119 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ48 = 120 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ49 = 121 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ50 = 122 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ51 = 123 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ52 = 124 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ53 = 125 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ54 = 126 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ55 = 127 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ56 = 128 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ57 = 129 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ58 = 130 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ59 = 131 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ60 = 132 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ61 = 133 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ62 = 134 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ63 = 135 , ALT_INT_INTERRUPT_DMA_IRQ0 = 136 ,
  ALT_INT_INTERRUPT_DMA_IRQ1 = 137 , ALT_INT_INTERRUPT_DMA_IRQ2 = 138 , ALT_INT_INTERRUPT_DMA_IRQ3 = 139 , ALT_INT_INTERRUPT_DMA_IRQ4 = 140 ,
  ALT_INT_INTERRUPT_DMA_IRQ5 = 141 , ALT_INT_INTERRUPT_DMA_IRQ6 = 142 , ALT_INT_INTERRUPT_DMA_IRQ7 = 143 , ALT_INT_INTERRUPT_DMA_IRQ_ABORT = 144 ,
  ALT_INT_INTERRUPT_DMA_ECC_CORRECTED_IRQ = 145 , ALT_INT_INTERRUPT_DMA_ECC_UNCORRECTED_IRQ = 146 , ALT_INT_INTERRUPT_EMAC0_IRQ = 147 , ALT_INT_INTERRUPT_EMAC0_TX_ECC_CORRECTED_IRQ = 148 ,
  ALT_INT_INTERRUPT_EMAC0_TX_ECC_UNCORRECTED_IRQ = 149 , ALT_INT_INTERRUPT_EMAC0_RX_ECC_CORRECTED_IRQ = 150 , ALT_INT_INTERRUPT_EMAC0_RX_ECC_UNCORRECTED_IRQ = 151 , ALT_INT_INTERRUPT_EMAC1_IRQ = 152 ,
  ALT_INT_INTERRUPT_EMAC1_TX_ECC_CORRECTED_IRQ = 153 , ALT_INT_INTERRUPT_EMAC1_TX_ECC_UNCORRECTED_IRQ = 154 , ALT_INT_INTERRUPT_EMAC1_RX_ECC_CORRECTED_IRQ = 155 , ALT_INT_INTERRUPT_EMAC1_RX_ECC_UNCORRECTED_IRQ = 156 ,
  ALT_INT_INTERRUPT_USB0_IRQ = 157 , ALT_INT_INTERRUPT_USB0_ECC_CORRECTED = 158 , ALT_INT_INTERRUPT_USB0_ECC_UNCORRECTED = 159 , ALT_INT_INTERRUPT_USB1_IRQ = 160 ,
  ALT_INT_INTERRUPT_USB1_ECC_CORRECTED = 161 , ALT_INT_INTERRUPT_USB1_ECC_UNCORRECTED = 162 , ALT_INT_INTERRUPT_CAN0_STS_IRQ = 163 , ALT_INT_INTERRUPT_CAN0_MO_IRQ = 164 ,
  ALT_INT_INTERRUPT_CAN0_ECC_CORRECTED_IRQ = 165 , ALT_INT_INTERRUPT_CAN0_ECC_UNCORRECTED_IRQ = 166 , ALT_INT_INTERRUPT_CAN1_STS_IRQ = 167 , ALT_INT_INTERRUPT_CAN1_MO_IRQ = 168 ,
  ALT_INT_INTERRUPT_CAN1_ECC_CORRECTED_IRQ = 169 , ALT_INT_INTERRUPT_CAN1_ECC_UNCORRECTED_IRQ = 170 , ALT_INT_INTERRUPT_SDMMC_IRQ = 171 , ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_CORRECTED = 172 ,
  ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_UNCORRECTED = 173 , ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_CORRECTED = 174 , ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_UNCORRECTED = 175 , ALT_INT_INTERRUPT_NAND_IRQ = 176 ,
  ALT_INT_INTERRUPT_NANDR_ECC_CORRECTED_IRQ = 177 , ALT_INT_INTERRUPT_NANDR_ECC_UNCORRECTED_IRQ = 178 , ALT_INT_INTERRUPT_NANDW_ECC_CORRECTED_IRQ = 179 , ALT_INT_INTERRUPT_NANDW_ECC_UNCORRECTED_IRQ = 180 ,
  ALT_INT_INTERRUPT_NANDE_ECC_CORRECTED_IRQ = 181 , ALT_INT_INTERRUPT_NANDE_ECC_UNCORRECTED_IRQ = 182 , ALT_INT_INTERRUPT_QSPI_IRQ = 183 , ALT_INT_INTERRUPT_QSPI_ECC_CORRECTED_IRQ = 184 ,
  ALT_INT_INTERRUPT_QSPI_ECC_UNCORRECTED_IRQ = 185 , ALT_INT_INTERRUPT_SPI0_IRQ = 186 , ALT_INT_INTERRUPT_SPI1_IRQ = 187 , ALT_INT_INTERRUPT_SPI2_IRQ = 188 ,
  ALT_INT_INTERRUPT_SPI3_IRQ = 189 , ALT_INT_INTERRUPT_I2C0_IRQ = 190 , ALT_INT_INTERRUPT_I2C1_IRQ = 191 , ALT_INT_INTERRUPT_I2C2_IRQ = 192 ,
  ALT_INT_INTERRUPT_I2C3_IRQ = 193 , ALT_INT_INTERRUPT_UART0 = 194 , ALT_INT_INTERRUPT_UART1 = 195 , ALT_INT_INTERRUPT_GPIO0 = 196 ,
  ALT_INT_INTERRUPT_GPIO1 = 197 , ALT_INT_INTERRUPT_GPIO2 = 198 , ALT_INT_INTERRUPT_TIMER_L4SP_0_IRQ = 199 , ALT_INT_INTERRUPT_TIMER_L4SP_1_IRQ = 200 ,
  ALT_INT_INTERRUPT_TIMER_OSC1_0_IRQ = 201 , ALT_INT_INTERRUPT_TIMER_OSC1_1_IRQ = 202 , ALT_INT_INTERRUPT_WDOG0_IRQ = 203 , ALT_INT_INTERRUPT_WDOG1_IRQ = 204 ,
  ALT_INT_INTERRUPT_CLKMGR_IRQ = 205 , ALT_INT_INTERRUPT_MPUWAKEUP_IRQ = 206 , ALT_INT_INTERRUPT_FPGA_MAN_IRQ = 207 , ALT_INT_INTERRUPT_NCTIIRQ0 = 208 ,
  ALT_INT_INTERRUPT_NCTIIRQ1 = 209 , ALT_INT_INTERRUPT_RAM_ECC_CORRECTED_IRQ = 210 , ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ = 211
enum  ALT_INT_TRIGGER_e {
  ALT_INT_TRIGGER_EDGE , ALT_INT_TRIGGER_LEVEL , ALT_INT_TRIGGER_SOFTWARE , ALT_INT_TRIGGER_AUTODETECT ,
  ALT_INT_TRIGGER_NA
enum  ALT_INT_SGI_TARGET_e { ALT_INT_SGI_TARGET_LIST , ALT_INT_SGI_TARGET_ALL_EXCL_SENDER , ALT_INT_SGI_TARGET_SENDER_ONLY }
