RTEMS
5.2-rc1
bsps
include
grlib
ahbstat.h
1
/* AHBSTAT driver interface
2
3
* COPYRIGHT (c) 2011.
4
* Cobham Gaisler AB.
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __AHBSTAT_H__
12
#define __AHBSTAT_H__
13
14
#include <stdint.h>
15
16
#ifdef __cplusplus
17
extern
"C"
18
#endif
19
20
/* AHBSTAT Registers layout */
21
struct
ahbstat_regs
22
volatile
uint32_t status;
23
volatile
uint32_t failing;
24
volatile
uint32_t status2;
25
volatile
uint32_t failing2;
26
27
28
/* AHB fail interrupt callback to user. This function is declared weak so that
29
* the user can define a function pointer variable containing the address
30
* responsible for handling errors
31
32
* minor Index of AHBSTAT hardware
33
* regs Register address of AHBSTAT
34
* status AHBSTAT status register at IRQ
35
* failing_address AHBSTAT Failing address register at IRQ
36
37
* * User return
38
* 0: print error onto terminal with printk and reenable AHBSTAT
39
* 1: just re-enable AHBSTAT
40
* 2: just print error
41
* 3: do nothing, let user do custom handling
42
43
extern
int (*ahbstat_error)(
44
int
minor,
45
struct
ahbstat_regs
*regs,
46
uint32_t status,
47
uint32_t failing_address);
48
49
/* Get Last received AHB Error
50
51
* \param minor Index used to indentify a specific AHBSTAT core
52
* \param status Status register at time of error IRQ was recevied
53
* \param address Failing address register at time of error IRQ
54
55
* Return
56
* 0: No error received
57
* 1: Error Received, last status and address stored into argument pointers
58
* -1: No such AHBSTAT device
59
60
extern
int
ahbstat_last_error(
int
minor, uint32_t *status, uint32_t *address);
61
62
/* Get AHBSTAT registers address from minor. Can also be used to check if
63
* AHBSTAT hardware is present.
64
65
* Return
66
* NULL returned if no such device
67
* non-zero Address to AHBSTAT register
68
69
extern
struct
ahbstat_regs
*ahbstat_get_regs(
int
minor);
70
71
/* Registers the AHBSTAT driver to the Driver Manager */
72
void
ahbstat_register_drv (
void
73
74
#ifdef __cplusplus
75
76
#endif
77
78
#endif
ahbstat_regs
Definition:
ahbstat.h:21
