9.1. Release Process
The release process creates an RTEMS release. The process has a number of stages that happen before a release can be made, during the creation of the release procedure and after the release has been made.
9.1.1. Releases
RTEMS is released as a collection of ready to use source code and built documentation. Releases are publicly available on the RTEMS servers under https://ftp.rtems.org/pub/rtems/releases.
Releases are group under the major version number as a collection of directories consisting of the version number. This is termed a release series. A release may also contain release snapshots.
All releases must have a three digit version number and this can be optionally followed by a dash character (-) and an identifier, e.g. 5.1.0-acme-1.
The RTEMS Project reserves releases with only the three digit version number, e.g. 5.1.0. This identifies an RTEMS Project release.
9.1.1.1. Release Layout
  • All released source archives are XZ compressed tar files.
  • Top level contains:
README.txt:
A set of brief release instructions.
contrib:
Contributed sources. For example the release scripts used to create the release.
docs:
Compressed documentation build in HTML, Single page HTML and PDF formats. Provide compressed files for each document and a single archive of all the documentation. Provide an SHA512 check sum file.
rtems-<VERSION>-release-notes.pdf:
RTEMS Release notes document the changes in a release. This is a capture of the Trac report for the release’s milestone in PDF format.
sha512sum.txt:
SHA512 checksum of all files in this directory.
sources:
All source code referenced by the release.
9.1.1.2. Release Version Numbering
The release numbering scheme changed with RTEMS 5.
The master branch has the version N.0.0 with N being the next major release number. The release branch in a repository will be just the major number.
The first release of this series will have the version number N.1.0. The first bugfix release (minor release) of this series will have the version number N.2.0.
The release branch will have the version number N.M.1 with M being the last minor release of this series. Tools will use N as the version number and must be compatible with all releases and the release branch of the N series.
Examples:
  • 5.0.0 is the version number of the development master for the 5 series
  • 5.1.0 is the first release of the 5 series
  • 5.1.1 is the version number of the 5 series release branch right after the 5.1.0 release until 5.2.0 is released
  • 5.2.0 is the first bugfix release of the 5 series
  • 5.2.1 is the version number of the 5 series release branch right after the 5.2.0 release until 5.3.0 is released
  • 6.0.0 is the version number of the development master for the 6 series
9.1.1.3. Release Scripts
  • The release scripts are held in the top level repository https://git.rtems.org/rtems-release.git.
  • The scripts are written for FreeBSD and can run on FreeBSD 10 through FreeBSD 12. No other host operating system is supported for the release scripts. Updates are welcome if the changes do not affect the operation on FreeBSD.
  • A Python virutalenv environment is required for a working Sphinx documentation building environment. Follow the procedure in the rtems-docs.git top level README file.
  • Building a standard release requires you provide the release major number and the release’s remaining version string including any additional identifiers:
    ./rtems-release 5 1.0
    To create a release snapshot:
    ./rtems-release 5 0.0-m2003
  • A 3rd option of a release URL can be provided to create a test or deployable release. The URL is a base path the RSB uses to download the release source files from:
    ./rtems-release \
        -u https://ftp.rtems.org/pub/rtems/people/chrisj/releases \
        5 0.0-m2003-2
  • Building the release notes requires the Web Toolkit HTML to PDF converter be installed. The FreeBSD package is wkhtmltopdf.
9.1.1.4. Release Snapshots
  • Release snapshots are only created for the current development version of RTEMS. For example RTEMS 5 snapshot path is 5/5.0.0/5.0.0-m2003.
  • Release snapshots are based on the development sources and may be unstable or not suitable for use in production.
  • A release snapshot is created each month and is named as <major>/<version>/<version>-<YYMM> where YY is the last two digits of the current year and MM is the month as a two digit number.
  • In the lead up to a release more than one snapshot can be created by appending -<count> to the snapshot version string where <count> is incremented starting from 1. The first snapshot without a count is considered number 0.
  • Release snapshots maybe removed from the RTEMS servers at the discretion of the RTEMS project
9.1.2. Release Repositories
The following are the repositories that a release effects. Any repository action is to be performed in the following repositories:
  1. rtems.git
  2. rtems-docs.git
  3. rtems-examples.git
  4. rtems-libbsd.git
  5. rtems-source-builder.git
  6. rtems-tools
  7. rtems_waf
9.1.3. Pre-Release Procedure
  • All tickets must be resolved, closed or moved to a later milestone.
  • The following BSP must build using the RSB:
    • arm/beagleboneblack
  • Branch labels are the major number as branch releases increment the minor number. A branch is only created when the first major release is made.
    The commands to set a remote branch for a release in a repository are:
    git checkout -b <VERSION> origin/master
    git push origin <VERSION>
    Example:
    git clone ssh://chrisj@dispatch.rtems.org/data/git/rtems.git rtems.git
    cd rtems.git
    git checkout -b 5 origin/master
    git push origin 5
9.1.4. Release Procedure
The release procedure can be performed on any FreeBSD machine and uploaded to the RTEMS FTP server. You will need ssh access to the RTEMS server dispatch.rtems.org and suitable permissions to write into the FTP release path on the RTEMS server.
  1. To create the RTEMS release run the release script:
    ./rtems-release <VERSION> <REVISION>
    Example:
    cd
    mkdir -p development/rtems/releases
    cd development/rtems/releases
    git clone git://git.rtems.org/rtems-release.git rtems-release.git
    cd rtems-release.git
  2. Copy the release to the RTEMS FTP server:
    ssh <user>@dispatch.rtems.org mkdir -p /data/ftp/pub/rtems/releases/<VERSION>
    scp -r <VERSION>.<REVISION> <user>@dispatch.rtems.org:/data/ftp/pub/rtems/releases/<VERSION>/.
    Example:
    ssh chrisj@dispatch.rtems.org mkdir -p /data/ftp/pub/rtems/releases/5
    scp -r 5.1.0 chrisj@dispatch.rtems.org:/data/ftp/pub/rtems/releases/5/.
  3. Verify the release has been uploaded by checking the link:
    https://ftp.rtems.org/pub/rtems/releases/<VERSION>/<VERSION>.<REVISION>
  4. Tag the release repositories with the following command:
    git checkout -b origin/<VERSION>
    git tag <TAG>
    git push origin <TAG>
    Example:
    cd rtems.git
    git checkout -b origin/5
    git tag 5.1.0
    git push origin 5.1.0
9.1.5. Post-Release Procedure
The following procedures are performed after a release has been created.
  1. TBD
