RTEMS
5.1-rc2
Public Types | |
| enum | { METHOD, FLAG, BLOCKS, CHECK4, CHECK3, CHECK2, CHECK1, DONE, BAD } |
Data Fields | |
| enum internal_state:: { ... } | mode |
| union { | |
| uInt method | |
| struct { | |
| uLong was | |
| uLong need | |
| } check | |
| uInt marker | |
| } | sub |
| int | nowrap |
| uInt | wbits |
| inflate_blocks_statef * | blocks |
| int | dummy |
| z_streamp | strm |
| int | status |
| Bytef * | pending_buf |
| ulg | pending_buf_size |
| Bytef * | pending_out |
| uInt | pending |
| int | wrap |
| gz_headerp | gzhead |
| uInt | gzindex |
| Byte | method |
| int | last_flush |
| uInt | w_size |
| uInt | w_bits |
| uInt | w_mask |
| Bytef * | window |
| ulg | window_size |
| Posf * | prev |
| Posf * | head |
| uInt | ins_h |
| uInt | hash_size |
| uInt | hash_bits |
| uInt | hash_mask |
| uInt | hash_shift |
| long | block_start |
| uInt | match_length |
| IPos | prev_match |
| int | match_available |
| uInt | strstart |
| uInt | match_start |
| uInt | lookahead |
| uInt | prev_length |
| uInt | max_chain_length |
| uInt | max_lazy_match |
| int | level |
| int | strategy |
| uInt | good_match |
| int | nice_match |
| struct ct_data_s | dyn_ltree [HEAP_SIZE] |
| struct ct_data_s | dyn_dtree [2 *D_CODES+1] |
| struct ct_data_s | bl_tree [2 *BL_CODES+1] |
| struct tree_desc_s | l_desc |
| struct tree_desc_s | d_desc |
| struct tree_desc_s | bl_desc |
| ush | bl_count [MAX_BITS+1] |
| int | heap [2 *L_CODES+1] |
| int | heap_len |
| int | heap_max |
| uch | depth [2 *L_CODES+1] |
| uchf * | l_buf |
| uInt | lit_bufsize |
| uInt | last_lit |
| ushf * | d_buf |
| ulg | opt_len |
| ulg | static_len |
| uInt | matches |
| int | last_eob_len |
| ush | bi_buf |
| int | bi_valid |
| ulg | high_water |
1.8.15
