RTEMS
5.1-rc2
Classic Partition Manager Implementation. More...
#include <rtems/rtems/partdata.h>#include <rtems/score/address.h>#include <rtems/score/chainimpl.h>#include <rtems/score/objectimpl.h>Go to the source code of this file.
| RTEMS_INLINE_ROUTINE void * | _Partition_Allocate_buffer (Partition_Control *the_partition) |
| Allocate a buffer from the_partition. More... | |
| RTEMS_INLINE_ROUTINE void | _Partition_Free_buffer (Partition_Control *the_partition, Chain_Node *the_buffer) |
| Frees the_buffer to the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_on_boundary (void *the_buffer, Partition_Control *the_partition) |
| Checks whether is on a valid buffer boundary for the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_valid (Chain_Node *the_buffer, Partition_Control *the_partition) |
| Checks whether the_buffer is a valid buffer from the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_size_aligned (uint32_t buffer_size) |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_area_aligned (const void *starting_address) |
| RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Allocate (void) |
| Allocates a partition control block from the inactive chain of free partition control blocks. More... | |
| RTEMS_INLINE_ROUTINE void | _Partition_Initialize (Partition_Control *the_partition, void *starting_address, uint32_t length, uint32_t buffer_size, rtems_attribute attribute_set) |
| RTEMS_INLINE_ROUTINE void | _Partition_Destroy (Partition_Control *the_partition) |
| RTEMS_INLINE_ROUTINE void | _Partition_Free (Partition_Control *the_partition) |
| Frees a partition control block to the inactive chain of free partition control blocks. More... | |
| RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Get (Objects_Id id, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Partition_Acquire_critical (Partition_Control *the_partition, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Partition_Release (Partition_Control *the_partition, ISR_lock_Context *lock_context) |
1.8.15
