RTEMS
5.1-rc2
Classic Partition Manager API. More...
| rtems_status_code | rtems_partition_create (rtems_name name, void *starting_address, uintptr_t length, size_t buffer_size, rtems_attribute attribute_set, rtems_id *id) |
| RTEMS Partition Create. More... | |
| rtems_status_code | rtems_partition_ident (rtems_name name, uint32_t node, rtems_id *id) |
| RTEMS Partition Ident. More... | |
| rtems_status_code | rtems_partition_delete (rtems_id id) |
| RTEMS Delete Partition. More... | |
| rtems_status_code | rtems_partition_get_buffer (rtems_id id, void **buffer) |
| RTEMS Get Partition Buffer. More... | |
| rtems_status_code | rtems_partition_return_buffer (rtems_id id, void *buffer) |
| rtems_partition_return_buffer More... | |
1.8.15
