RTEMS
5.1-rc2
Object Handler Data Structures. More...
| struct | Objects_Control |
| struct | Objects_Information |
| The information structure used to manage each API class of objects. More... | |
| #define | OBJECTS_NO_STRING_NAME 0 |
| Constant for the object information string name length to indicate that this object class has no string names. | |
| #define | OBJECTS_INFORMATION_MP(name, extract) |
| #define | OBJECTS_INFORMATION_DEFINE_ZERO(name, api, cls, nl) |
| Statically initializes an objects information. More... | |
| #define | OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex) |
Typedefs | |
| typedef struct Objects_Information | Objects_Information |
Enumerations | |
| enum | Objects_Internal_API { OBJECTS_INTERNAL_NO_CLASS = 0, OBJECTS_INTERNAL_THREADS = 1 } |
| enum | Objects_Classic_API { OBJECTS_CLASSIC_NO_CLASS = 0, OBJECTS_RTEMS_TASKS = 1, OBJECTS_RTEMS_TIMERS, OBJECTS_RTEMS_SEMAPHORES, OBJECTS_RTEMS_MESSAGE_QUEUES, OBJECTS_RTEMS_PARTITIONS, OBJECTS_RTEMS_REGIONS, OBJECTS_RTEMS_PORTS, OBJECTS_RTEMS_PERIODS, OBJECTS_RTEMS_EXTENSIONS, OBJECTS_RTEMS_BARRIERS } |
| enum | Objects_POSIX_API { OBJECTS_POSIX_NO_CLASS = 0, OBJECTS_POSIX_THREADS = 1, OBJECTS_POSIX_KEYS, OBJECTS_POSIX_MESSAGE_QUEUES, OBJECTS_POSIX_SEMAPHORES, OBJECTS_POSIX_TIMERS, OBJECTS_POSIX_SHMS } |
| Objects_Control * | _Objects_Allocate_none (Objects_Information *information) |
| Always return NULL. More... | |
| Objects_Control * | _Objects_Allocate_static (Objects_Information *information) |
| Return an inactive object or NULL. More... | |
| Objects_Control * | _Objects_Allocate_unlimited (Objects_Information *information) |
| void | _Objects_Free_static (Objects_Information *information, Objects_Control *the_object) |
| Free the object. More... | |
| void | _Objects_Free_unlimited (Objects_Information *information, Objects_Control *the_object) |
1.8.15
