RTEMS
5.1-rc2
Classic Message Queue Manager API. More...
#include <rtems/rtems/attr.h>#include <rtems/rtems/options.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>Go to the source code of this file.
| rtems_status_code | rtems_message_queue_create (rtems_name name, uint32_t count, size_t max_message_size, rtems_attribute attribute_set, rtems_id *id) |
| RTEMS Create Message Queue. More... | |
| rtems_status_code | rtems_message_queue_ident (rtems_name name, uint32_t node, rtems_id *id) |
| RTEMS Message Queue Name to Id. More... | |
| rtems_status_code | rtems_message_queue_delete (rtems_id id) |
| RTEMS Delete Message Queue. More... | |
| rtems_status_code | rtems_message_queue_send (rtems_id id, const void *buffer, size_t size) |
| Sends a message to the message queue. More... | |
| rtems_status_code | rtems_message_queue_urgent (rtems_id id, const void *buffer, size_t size) |
| RTEMS Urgent Message Queue. More... | |
| rtems_status_code | rtems_message_queue_broadcast (rtems_id id, const void *buffer, size_t size, uint32_t *count) |
| RTEMS Broadcast Message Queue. More... | |
| rtems_status_code | rtems_message_queue_receive (rtems_id id, void *buffer, size_t *size, rtems_option option_set, rtems_interval timeout) |
| Receives a message from the message queue. More... | |
| rtems_status_code | rtems_message_queue_flush (rtems_id id, uint32_t *count) |
| rtems_message_queue_flush More... | |
| rtems_status_code | rtems_message_queue_get_number_pending (rtems_id id, uint32_t *count) |
| RTEMS Message Queue Get Number Pending. More... | |
1.8.15
