RTEMS
5.1-rc2
| #define | MCAN_PROG_CLK_PRESCALER 1 /* /1 to /256 */ |
| #define | MCAN_PROG_CLK_SELECT PMC_PCK_CSS_MCK |
| #define | MCAN_PROG_CLK_FREQ_HZ ((float) 150000000 / (float) MCAN_PROG_CLK_PRESCALER) |
| #define | MCAN0_BIT_RATE_BPS 500000 |
| #define | MCAN0_PROP_SEG 2 |
| #define | MCAN0_PHASE_SEG1 11 |
| #define | MCAN0_PHASE_SEG2 11 |
| #define | MCAN0_SYNC_JUMP 4 |
| #define | MCAN0_FAST_BIT_RATE_BPS 2000000 |
| #define | MCAN0_FAST_PROP_SEG 2 |
| #define | MCAN0_FAST_PHASE_SEG1 4 |
| #define | MCAN0_FAST_PHASE_SEG2 4 |
| #define | MCAN0_FAST_SYNC_JUMP 2 |
| #define | MCAN0_NMBR_STD_FLTS 8 /* 128 max filters */ |
| #define | MCAN0_NMBR_EXT_FLTS 8 /* 64 max filters */ |
| #define | MCAN0_NMBR_RX_FIFO0_ELMTS 0 /* # of elements, 64 elements max */ |
| #define | MCAN0_NMBR_RX_FIFO1_ELMTS 0 /* # of elements, 64 elements max */ |
| #define | MCAN0_NMBR_RX_DED_BUF_ELMTS 16 /* # of elements, 64 elements max */ |
| #define | MCAN0_NMBR_TX_EVT_FIFO_ELMTS 0 /* # of elements, 32 elements max */ |
| #define | MCAN0_NMBR_TX_DED_BUF_ELMTS 4 /* # of elements, 32 elements max */ |
| #define | MCAN0_NMBR_TX_FIFO_Q_ELMTS 0 /* # of elements, 32 elements max */ |
| #define | MCAN0_RX_FIFO0_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN0_RX_FIFO1_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN0_RX_BUF_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN0_TX_BUF_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN1_BIT_RATE_BPS 500000 |
| #define | MCAN1_PROP_SEG 2 |
| #define | MCAN1_PHASE_SEG1 11 |
| #define | MCAN1_PHASE_SEG2 11 |
| #define | MCAN1_SYNC_JUMP 4 |
| #define | MCAN1_FAST_BIT_RATE_BPS 2000000 |
| #define | MCAN1_FAST_PROP_SEG 2 |
| #define | MCAN1_FAST_PHASE_SEG1 4 |
| #define | MCAN1_FAST_PHASE_SEG2 4 |
| #define | MCAN1_FAST_SYNC_JUMP 2 |
| #define | MCAN1_NMBR_STD_FLTS 8 /* 128 max filters */ |
| #define | MCAN1_NMBR_EXT_FLTS 8 /* 64 max filters */ |
| #define | MCAN1_NMBR_RX_FIFO0_ELMTS 12 /* # of elements, 64 elements max */ |
| #define | MCAN1_NMBR_RX_FIFO1_ELMTS 0 /* # of elements, 64 elements max */ |
| #define | MCAN1_NMBR_RX_DED_BUF_ELMTS 4 /* # of elements, 64 elements max */ |
| #define | MCAN1_NMBR_TX_EVT_FIFO_ELMTS 0 /* # of elements, 32 elements max */ |
| #define | MCAN1_NMBR_TX_DED_BUF_ELMTS 4 /* # of elements, 32 elements max */ |
| #define | MCAN1_NMBR_TX_FIFO_Q_ELMTS 4 /* # of elements, 32 elements max */ |
| #define | MCAN1_RX_FIFO0_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN1_RX_FIFO1_ELMT_SZ 8 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN1_RX_BUF_ELMT_SZ 64 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
| #define | MCAN1_TX_BUF_ELMT_SZ 32 /* 8, 12, 16, 20, 24, 32, 48, 64 bytes */ |
Interface for configuring and using Timer Counter (TC) peripherals.
1.8.15
