RTEMS
5.1-rc2
ISR Locks. More...
| struct | ISR_lock_Control |
| ISR lock control. More... | |
| struct | ISR_lock_Context |
| Local ISR lock context for acquire and release pairs. More... | |
| #define | ISR_LOCK_MEMBER(_designator) |
| Defines an ISR lock member. More... | |
| #define | ISR_LOCK_DECLARE(_qualifier, _designator) |
| Declares an ISR lock variable. More... | |
| #define | ISR_LOCK_DEFINE(_qualifier, _designator, _name) |
| Defines an ISR lock variable. More... | |
| #define | ISR_LOCK_REFERENCE(_designator, _target) |
| Defines an ISR lock variable reference. More... | |
| #define | ISR_LOCK_INITIALIZER(_name) { } |
| Initializer for static initialization of ISR locks. More... | |
| #define | _ISR_lock_Initialize(_lock, _name) |
| Initializes an ISR lock. More... | |
| #define | _ISR_lock_Destroy(_lock) |
| Destroys an ISR lock. More... | |
| #define | _ISR_lock_Set_name(_lock, _name) |
| Sets the name of an ISR lock. More... | |
| #define | _ISR_lock_ISR_disable_and_acquire(_lock, _context) _ISR_Local_disable( ( _context )->isr_level ) |
| Acquires an ISR lock. More... | |
| #define | _ISR_lock_Release_and_ISR_enable(_lock, _context) _ISR_Local_enable( ( _context )->isr_level ) |
| Releases an ISR lock. More... | |
| #define | _ISR_lock_Acquire(_lock, _context) do { (void) _context; } while ( 0 ) |
| Acquires an ISR lock inside an ISR disabled section. More... | |
| #define | _ISR_lock_Release(_lock, _context) do { (void) _context; } while ( 0 ) |
| Releases an ISR lock inside an ISR disabled section. More... | |
| #define | _ISR_lock_Acquire_inline(_lock, _context) do { (void) _context; } while ( 0 ) |
| Acquires an ISR lock inside an ISR disabled section (inline). More... | |
| #define | _ISR_lock_Release_inline(_lock, _context) do { (void) _context; } while ( 0 ) |
| Releases an ISR lock inside an ISR disabled section (inline). More... | |
| #define | _ISR_lock_ISR_disable_profile(_context) |
| #define | _ISR_lock_ISR_disable(_context) |
| Disables interrupts and saves the previous interrupt state in the ISR lock context. More... | |
| #define | _ISR_lock_ISR_enable(_context) _ISR_Local_enable( ( _context )->isr_level ) |
| Restores the saved interrupt state of the ISR lock context. More... | |
| RTEMS_INLINE_ROUTINE void | _ISR_lock_Context_set_level (ISR_lock_Context *context, ISR_Level level) |
| Sets the ISR level in the ISR lock context. More... | |
ISR Locks.
1.8.15
