RTEMS
5.1-rc2
The RTEMS Test Framework helps you to write tests. More...
Modules | |
| Boolean Checks | |
| Checks for boolean expressions. | |
| Character Checks | |
| Checks for characters (char). | |
| Destructors | |
| Support to run destructors at the end of a test case. | |
| Generic Checks | |
| Checks for data types with an equality or inequality operator. | |
| Memory Area Checks | |
| Checks for memory areas. | |
| POSIX Status and Error Number Checks | |
| Checks for POSIX status and error numbers. | |
| Pointer Checks | |
| Checks for pointers. | |
| RTEMS Test Framework Implementation | |
| Implementation details. | |
| Runtime Measurements | |
| Support to measure the runtime of code fragments. | |
| Signed 16-Bit Integer Checks | |
| Checks for signed 16-bit integers (int16_t). | |
| Signed 32-Bit Integer Checks | |
| Checks for signed 32-bit integers (int32_t). | |
| Signed 64-Bit Integer Checks | |
| Checks for signed 64-bit integers (int64_t). | |
| Signed 8-Bit Integer Checks | |
| Checks for signed 8-bit integers (int8_t). | |
| Signed Character Checks | |
| Checks for signed characters (signed char). | |
| Signed Integer Checks | |
| Checks for signed integers (int). | |
| Signed Long Integer Checks | |
| Checks for signed long integers (long). | |
| Signed Pointer Value Checks | |
| Checks for signed pointer values (intptr_t). | |
| Signed Short Integer Checks | |
| Checks for signed short integers (short). | |
| Signed Size Checks | |
| Checks for signed sizes (ssize_t). | |
| Size Checks | |
| Checks for sizes (size_t). | |
| String Checks | |
| Checks for strings. | |
| Time Services | |
| Time service functions. | |
| Unsigned 16-Bit Integer Checks | |
| Checks for unsigned 16-bit integers (uint16_t). | |
| Unsigned 32-Bit Integer Checks | |
| Checks for unsigned 32-bit integers (uint32_t). | |
| Unsigned 64-Bit Integer Checks | |
| Checks for unsigned 64-bit integers (uint64_t). | |
| Unsigned 8-Bit Integer Checks | |
| Checks for unsigned 8-bit integers (uint8_t). | |
| Unsigned Character Checks | |
| Checks for unsigned characters (unsigned char). | |
| Unsigned Integer Checks | |
| Checks for unsigned integers (unsigned int). | |
| Unsigned Long Integer Checks | |
| Checks for unsigned long integers (unsigned long). | |
| Unsigned Long Long Integer Checks | |
| Checks for unsigned long long integers (unsigned long long). | |
| Unsigned Pointer Value Checks | |
| Checks for unsigned pointer values (uintptr_t). | |
| Unsigned Short Integer Checks | |
| Checks for unsigned short integers (unsigned short). | |
| struct | T_fixture |
| #define | T_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0])) |
| #define | T_FILE_NAME __FILE__ |
Typedefs | |
| typedef struct T_fixture | T_fixture |
Enumerations | |
| enum | T_verbosity { T_QUIET, T_NORMAL, T_VERBOSE } |
1.8.15
