RTEMS 5.3
Global BSP definitions. More...
#include <bspopts.h>#include <libcpu/powerpc-utility.h>#include <rtems.h>#include <bsp/i2cdrv.h>#include <bsp/irq.h>#include <bsp/vectors.h>#include <bsp/u-boot.h>#include <bsp/default-initial-extension.h>Go to the source code of this file.
| #define | NEED_LOW_LEVEL_INIT |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_mpc5200_fec_driver_attach_detach |
| #define | RTEMS_BSP_HAS_IDE_DRIVER |
| #define | ATA_USE_INT |
| #define | IPB_CLOCK 33000000 /* 33 MHz */ |
| #define | XLB_CLOCK 66000000 /* 66 MHz */ |
| #define | G2_CLOCK 231000000 /* 231 MHz */ |
| #define | GEN5200_CONSOLE_BAUD 115200 |
| #define | BSP_Convert_decrementer(_value) (int) (((_value) * 4000) / (XLB_CLOCK/10000)) |
| #define | USE_SLICETIMER_0 TRUE |
| #define | USE_SLICETIMER_1 FALSE |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| LINKER_SYMBOL (bsp_ram_start) | |
| LINKER_SYMBOL (bsp_ram_end) | |
| LINKER_SYMBOL (bsp_ram_size) | |
| LINKER_SYMBOL (bsp_rom_start) | |
| LINKER_SYMBOL (bsp_rom_end) | |
| LINKER_SYMBOL (bsp_rom_size) | |
| LINKER_SYMBOL (bsp_dpram_start) | |
| LINKER_SYMBOL (bsp_dpram_end) | |
| LINKER_SYMBOL (bsp_dpram_size) | |
| LINKER_SYMBOL (bsp_section_text_start) | |
| LINKER_SYMBOL (bsp_section_text_end) | |
| LINKER_SYMBOL (bsp_section_text_size) | |
| LINKER_SYMBOL (bsp_section_data_start) | |
| LINKER_SYMBOL (bsp_section_data_end) | |
| LINKER_SYMBOL (bsp_section_data_size) | |
| LINKER_SYMBOL (bsp_section_bss_start) | |
| LINKER_SYMBOL (bsp_section_bss_end) | |
| LINKER_SYMBOL (bsp_section_bss_size) | |
| LINKER_SYMBOL (bsp_work_area_start) | |
| LINKER_SYMBOL (MBAR) | |
| int | rtems_mpc5200_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. More... | |
| void | BSP_IRQ_Benchmarking_Reset (void) |
| void | BSP_IRQ_Benchmarking_Report (void) |
| void | cpu_init (void) |
| int | mpc5200_eth_mii_read (int phyAddr, void *arg, unsigned regAddr, uint32_t *retVal) |
