RTEMS  5.1
zynq-uart-regs.h
1
7 /*
8  * SPDX-License-Identifier: BSD-2-Clause
9  *
10  * Copyright (C) 2013 embedded brains GmbH
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  * POSSIBILITY OF SUCH DAMAGE.
32  */
33
41 #ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_REGS_H
42 #define LIBBSP_ARM_XILINX_ZYNQ_UART_REGS_H
43
44 #include <bsp/utility.h>
45
46 #define ZYNQ_UART_FIFO_DEPTH 64
47
48 typedef struct zynq_uart {
49  uint32_t control;
50 #define ZYNQ_UART_CONTROL_STPBRK BSP_BIT32(8)
51 #define ZYNQ_UART_CONTROL_STTBRK BSP_BIT32(7)
52 #define ZYNQ_UART_CONTROL_RSTTO BSP_BIT32(6)
53 #define ZYNQ_UART_CONTROL_TXDIS BSP_BIT32(5)
54 #define ZYNQ_UART_CONTROL_TXEN BSP_BIT32(4)
55 #define ZYNQ_UART_CONTROL_RXDIS BSP_BIT32(3)
56 #define ZYNQ_UART_CONTROL_RXEN BSP_BIT32(2)
57 #define ZYNQ_UART_CONTROL_TXRES BSP_BIT32(1)
58 #define ZYNQ_UART_CONTROL_RXRES BSP_BIT32(0)
59  uint32_t mode;
60 #define ZYNQ_UART_MODE_CHMODE(val) BSP_FLD32(val, 8, 9)
61 #define ZYNQ_UART_MODE_CHMODE_GET(reg) BSP_FLD32GET(reg, 8, 9)
62 #define ZYNQ_UART_MODE_CHMODE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 9)
63 #define ZYNQ_UART_MODE_CHMODE_NORMAL 0x00U
64 #define ZYNQ_UART_MODE_CHMODE_AUTO_ECHO 0x01U
65 #define ZYNQ_UART_MODE_CHMODE_LOCAL_LOOPBACK 0x02U
66 #define ZYNQ_UART_MODE_CHMODE_REMOTE_LOOPBACK 0x03U
67 #define ZYNQ_UART_MODE_NBSTOP(val) BSP_FLD32(val, 6, 7)
68 #define ZYNQ_UART_MODE_NBSTOP_GET(reg) BSP_FLD32GET(reg, 6, 7)
69 #define ZYNQ_UART_MODE_NBSTOP_SET(reg, val) BSP_FLD32SET(reg, val, 6, 7)
70 #define ZYNQ_UART_MODE_NBSTOP_STOP_1 0x00U
71 #define ZYNQ_UART_MODE_NBSTOP_STOP_1_5 0x01U
72 #define ZYNQ_UART_MODE_NBSTOP_STOP_2 0x02U
73 #define ZYNQ_UART_MODE_PAR(val) BSP_FLD32(val, 3, 5)
74 #define ZYNQ_UART_MODE_PAR_GET(reg) BSP_FLD32GET(reg, 3, 5)
75 #define ZYNQ_UART_MODE_PAR_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
76 #define ZYNQ_UART_MODE_PAR_EVEN 0x00U
77 #define ZYNQ_UART_MODE_PAR_ODD 0x01U
78 #define ZYNQ_UART_MODE_PAR_SPACE 0x02U
79 #define ZYNQ_UART_MODE_PAR_MARK 0x03U
80 #define ZYNQ_UART_MODE_PAR_NONE 0x04U
81 #define ZYNQ_UART_MODE_CHRL(val) BSP_FLD32(val, 1, 2)
82 #define ZYNQ_UART_MODE_CHRL_GET(reg) BSP_FLD32GET(reg, 1, 2)
83 #define ZYNQ_UART_MODE_CHRL_SET(reg, val) BSP_FLD32SET(reg, val, 1, 2)
84 #define ZYNQ_UART_MODE_CHRL_8 0x00U
85 #define ZYNQ_UART_MODE_CHRL_7 0x02U
86 #define ZYNQ_UART_MODE_CHRL_6 0x03U
87 #define ZYNQ_UART_MODE_CLKS BSP_BIT32(0)
88  uint32_t irq_en;
89  uint32_t irq_dis;
90  uint32_t irq_mask;
91  uint32_t irq_sts;
92 #define ZYNQ_UART_TOVR BSP_BIT32(12)
93 #define ZYNQ_UART_TNFUL BSP_BIT32(11)
94 #define ZYNQ_UART_TTRIG BSP_BIT32(10)
95 #define ZYNQ_UART_DMSI BSP_BIT32(9)
96 #define ZYNQ_UART_TIMEOUT BSP_BIT32(8)
97 #define ZYNQ_UART_PARE BSP_BIT32(7)
98 #define ZYNQ_UART_FRAME BSP_BIT32(6)
99 #define ZYNQ_UART_ROVR BSP_BIT32(5)
100 #define ZYNQ_UART_TFUL BSP_BIT32(4)
101 #define ZYNQ_UART_TEMPTY BSP_BIT32(3)
102 #define ZYNQ_UART_RFUL BSP_BIT32(2)
103 #define ZYNQ_UART_REMPTY BSP_BIT32(1)
104 #define ZYNQ_UART_RTRIG BSP_BIT32(0)
105  uint32_t baud_rate_gen;
106 #define ZYNQ_UART_BAUD_RATE_GEN_CD(val) BSP_FLD32(val, 0, 15)
107 #define ZYNQ_UART_BAUD_RATE_GEN_CD_GET(reg) BSP_FLD32GET(reg, 0, 15)
108 #define ZYNQ_UART_BAUD_RATE_GEN_CD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
109  uint32_t rx_timeout;
110 #define ZYNQ_UART_RX_TIMEOUT_RTO(val) BSP_FLD32(val, 0, 7)
111 #define ZYNQ_UART_RX_TIMEOUT_RTO_GET(reg) BSP_FLD32GET(reg, 0, 7)
112 #define ZYNQ_UART_RX_TIMEOUT_RTO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
113  uint32_t rx_fifo_trg_lvl;
114 #define ZYNQ_UART_RX_FIFO_TRG_LVL_RTRIG(val) BSP_FLD32(val, 0, 5)
115 #define ZYNQ_UART_RX_FIFO_TRG_LVL_RTRIG_GET(reg) BSP_FLD32GET(reg, 0, 5)
116 #define ZYNQ_UART_RX_FIFO_TRG_LVL_RTRIG_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
117  uint32_t modem_ctrl;
118 #define ZYNQ_UART_MODEM_CTRL_FCM BSP_BIT32(5)
119 #define ZYNQ_UART_MODEM_CTRL_RTS BSP_BIT32(1)
120 #define ZYNQ_UART_MODEM_CTRL_DTR BSP_BIT32(0)
121  uint32_t modem_sts;
122 #define ZYNQ_UART_MODEM_STS_FCMS BSP_BIT32(8)
123 #define ZYNQ_UART_MODEM_STS_DCD BSP_BIT32(7)
124 #define ZYNQ_UART_MODEM_STS_RI BSP_BIT32(6)
125 #define ZYNQ_UART_MODEM_STS_DSR BSP_BIT32(5)
126 #define ZYNQ_UART_MODEM_STS_CTS BSP_BIT32(4)
127 #define ZYNQ_UART_MODEM_STS_DDCD BSP_BIT32(3)
128 #define ZYNQ_UART_MODEM_STS_TERI BSP_BIT32(2)
129 #define ZYNQ_UART_MODEM_STS_DDSR BSP_BIT32(1)
130 #define ZYNQ_UART_MODEM_STS_DCTS BSP_BIT32(0)
131  uint32_t channel_sts;
132 #define ZYNQ_UART_CHANNEL_STS_TNFUL BSP_BIT32(14)
133 #define ZYNQ_UART_CHANNEL_STS_TTRIG BSP_BIT32(13)
134 #define ZYNQ_UART_CHANNEL_STS_FDELT BSP_BIT32(12)
135 #define ZYNQ_UART_CHANNEL_STS_TACTIVE BSP_BIT32(11)
136 #define ZYNQ_UART_CHANNEL_STS_RACTIVE BSP_BIT32(10)
137 #define ZYNQ_UART_CHANNEL_STS_TFUL BSP_BIT32(4)
138 #define ZYNQ_UART_CHANNEL_STS_TEMPTY BSP_BIT32(3)
139 #define ZYNQ_UART_CHANNEL_STS_RFUL BSP_BIT32(2)
140 #define ZYNQ_UART_CHANNEL_STS_REMPTY BSP_BIT32(1)
141 #define ZYNQ_UART_CHANNEL_STS_RTRIG BSP_BIT32(0)
142  uint32_t tx_rx_fifo;
143 #define ZYNQ_UART_TX_RX_FIFO_FIFO(val) BSP_FLD32(val, 0, 7)
144 #define ZYNQ_UART_TX_RX_FIFO_FIFO_GET(reg) BSP_FLD32GET(reg, 0, 7)
145 #define ZYNQ_UART_TX_RX_FIFO_FIFO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
146  uint32_t baud_rate_div;
147 #define ZYNQ_UART_BAUD_RATE_DIV_BDIV(val) BSP_FLD32(val, 0, 7)
148 #define ZYNQ_UART_BAUD_RATE_DIV_BDIV_GET(reg) BSP_FLD32GET(reg, 0, 7)
149 #define ZYNQ_UART_BAUD_RATE_DIV_BDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
150  uint32_t flow_delay;
151 #define ZYNQ_UART_FLOW_DELAY_FDEL(val) BSP_FLD32(val, 0, 5)
152 #define ZYNQ_UART_FLOW_DELAY_FDEL_GET(reg) BSP_FLD32GET(reg, 0, 5)
153 #define ZYNQ_UART_FLOW_DELAY_FDEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
154  uint32_t reserved_3c[2];
155  uint32_t tx_fifo_trg_lvl;
156 #define ZYNQ_UART_TX_FIFO_TRG_LVL_TTRIG(val) BSP_FLD32(val, 0, 5)
157 #define ZYNQ_UART_TX_FIFO_TRG_LVL_TTRIG_GET(reg) BSP_FLD32GET(reg, 0, 5)
158 #define ZYNQ_UART_TX_FIFO_TRG_LVL_TTRIG_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
159 } zynq_uart;
160
163 #endif /* LIBBSP_ARM_XILINX_ZYNQ_UART_REGS_H */
Definition: zynq-uart-regs.h:48
Utility macros.
Definition: intercom.c:74
