RTEMS  5.1
z85c30_p.h
1 /*
2  * This include file contains all private driver definitions for the
3  * Zilog z85c30.
4  *
5  * COPYRIGHT (c) 1998 by Radstone Technology
6  *
7  *
8  * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
9  * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
10  * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
11  * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
12  *
13  * You are hereby granted permission to use, copy, modify, and distribute
14  * this file, provided that this notice, plus the above copyright notice
15  * and disclaimer, appears in all copies. Radstone Technology will provide
16  * no support for this code.
17  *
18  * COPYRIGHT (c) 1989-1997.
19  * On-Line Applications Research Corporation (OAR).
20  *
21  * The license and distribution terms for this file may in
22  * the file LICENSE in this distribution or at
23  * http://www.rtems.org/license/LICENSE.
24  */
25
26 #ifndef __Z85C30_P_H
27 #define __Z85C30_P_H
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
33 /*
34  * Define Z85C30_STATIC to nothing while debugging so the entry points
35  * will show up in the symbol table.
36  */
37
38 #define Z85C30_STATIC
39
40 /* #define Z85C30_STATIC static */
41
42 /* bit values for write register 0 */
43 /* command register */
44
45 #define SCC_WR0_SEL_WR0 0x00
46 #define SCC_WR0_SEL_WR1 0x01
47 #define SCC_WR0_SEL_WR2 0x02
48 #define SCC_WR0_SEL_WR3 0x03
49 #define SCC_WR0_SEL_WR4 0x04
50 #define SCC_WR0_SEL_WR5 0x05
51 #define SCC_WR0_SEL_WR6 0x06
52 #define SCC_WR0_SEL_WR7 0x07
53 #define SCC_WR0_SEL_WR8 0x08
54 #define SCC_WR0_SEL_WR9 0x09
55 #define SCC_WR0_SEL_WR10 0x0a
56 #define SCC_WR0_SEL_WR11 0x0b
57 #define SCC_WR0_SEL_WR12 0x0c
58 #define SCC_WR0_SEL_WR13 0x0d
59 #define SCC_WR0_SEL_WR14 0x0e
60 #define SCC_WR0_SEL_WR15 0x0f
61 #define SCC_WR0_SEL_RD0 0x00
62 #define SCC_WR0_SEL_RD1 0x01
63 #define SCC_WR0_SEL_RD2 0x02
64 #define SCC_WR0_SEL_RD3 0x03
65 #define SCC_WR0_SEL_RD4 0x04
66 #define SCC_WR0_SEL_RD5 0x05
67 #define SCC_WR0_SEL_RD6 0x06
68 #define SCC_WR0_SEL_RD7 0x07
69 #define SCC_WR0_SEL_RD8 0x08
70 #define SCC_WR0_SEL_RD9 0x09
71 #define SCC_WR0_SEL_RD10 0x0a
72 #define SCC_WR0_SEL_RD11 0x0b
73 #define SCC_WR0_SEL_RD12 0x0c
74 #define SCC_WR0_SEL_RD13 0x0d
75 #define SCC_WR0_SEL_RD14 0x0e
76 #define SCC_WR0_SEL_RD15 0x0f
77 #define SCC_WR0_NULL_CODE 0x00
78 #define SCC_WR0_RST_INT 0x10
79 #define SCC_WR0_SEND_ABORT 0x18
80 #define SCC_WR0_EN_INT_RX 0x20
81 #define SCC_WR0_RST_TX_INT 0x28
82 #define SCC_WR0_ERR_RST 0x30
83 #define SCC_WR0_RST_HI_IUS 0x38
84 #define SCC_WR0_RST_RX_CRC 0x40
85 #define SCC_WR0_RST_TX_CRC 0x80
86 #define SCC_WR0_RST_TX_UND 0xc0
87
88 /* write register 2 */
89 /* interrupt vector */
90
91 /* bit values for write register 1 */
92 /* tx/rx interrupt and data transfer mode definition */
93
94 #define SCC_WR1_EXT_INT_EN 0x01
95 #define SCC_WR1_TX_INT_EN 0x02
96 #define SCC_WR1_PARITY 0x04
97 #define SCC_WR1_RX_INT_DIS 0x00
98 #define SCC_WR1_RX_INT_FIR 0x08
99 #define SCC_WR1_INT_ALL_RX 0x10
100 #define SCC_WR1_RX_INT_SPE 0x18
101 #define SCC_WR1_RDMA_RECTR 0x20
102 #define SCC_WR1_RDMA_FUNC 0x40
103 #define SCC_WR1_RDMA_EN 0x80
104
105 #define SCC_ENABLE_ALL_INTR \
106  (SCC_WR1_EXT_INT_EN | SCC_WR1_TX_INT_EN | SCC_WR1_INT_ALL_RX)
107
108 #define SCC_DISABLE_ALL_INTR 0x00
109
110 #define SCC_ENABLE_ALL_INTR_EXCEPT_TX \
111  (SCC_WR1_EXT_INT_EN | SCC_WR1_INT_ALL_RX)
112
113 /* bit values for write register 3 */
114 /* receive parameters and control */
115
116 #define SCC_WR3_RX_EN 0x01
117 #define SCC_WR3_SYNC_CHAR 0x02
118 #define SCC_WR3_ADR_SEARCH 0x04
119 #define SCC_WR3_RX_CRC_EN 0x08
120 #define SCC_WR3_ENTER_HUNT 0x10
121 #define SCC_WR3_AUTO_EN 0x20
122 #define SCC_WR3_RX_5_BITS 0x00
123 #define SCC_WR3_RX_7_BITS 0x40
124 #define SCC_WR3_RX_6_BITS 0x80
125 #define SCC_WR3_RX_8_BITS 0xc0
126
127 /* bit values for write register 4 */
128 /* tx/rx misc parameters and modes */
129
130 #define SCC_WR4_PAR_EN 0x01
131 #define SCC_WR4_PAR_EVEN 0x02
132 #define SCC_WR4_SYNC_EN 0x00
133 #define SCC_WR4_1_STOP 0x04
134 #define SCC_WR4_2_STOP 0x0c
135 #define SCC_WR4_8_SYNC 0x00
136 #define SCC_WR4_16_SYNC 0x10
137 #define SCC_WR4_SDLC 0x20
138 #define SCC_WR4_EXT_SYNC 0x30
139 #define SCC_WR4_1_CLOCK 0x00
140 #define SCC_WR4_16_CLOCK 0x40
141 #define SCC_WR4_32_CLOCK 0x80
142 #define SCC_WR4_64_CLOCK 0xc0
143
144 /* bit values for write register 5 */
145 /* transmit parameter and controls */
146
147 #define SCC_WR5_TX_CRC_EN 0x01
148 #define SCC_WR5_RTS 0x02
149 #define SCC_WR5_SDLC 0x04
150 #define SCC_WR5_TX_EN 0x08
151 #define SCC_WR5_SEND_BRK 0x10
152
153 #define SCC_WR5_TX_5_BITS 0x00
154 #define SCC_WR5_TX_7_BITS 0x20
155 #define SCC_WR5_TX_6_BITS 0x40
156 #define SCC_WR5_TX_8_BITS 0x60
157 #define SCC_WR5_DTR 0x80
158
159 /* write register 6 */
160 /* sync chars or sdlc address field */
161
162 /* write register 7 */
163 /* sync char or sdlc flag */
164
165 /* write register 8 */
166 /* transmit buffer */
167
168 /* bit values for write register 9 */
169 /* master interrupt control */
170
171 #define SCC_WR9_VIS 0x01
172 #define SCC_WR9_NV 0x02
173 #define SCC_WR9_DLC 0x04
174 #define SCC_WR9_MIE 0x08
175 #define SCC_WR9_STATUS_HI 0x10
176 #define SCC_WR9_NO_RST 0x00
177 #define SCC_WR9_CH_B_RST 0x40
178 #define SCC_WR9_CH_A_RST 0x80
179 #define SCC_WR9_HDWR_RST 0xc0
180
181 /* bit values for write register 10 */
182 /* misc tx/rx control bits */
183
184 #define SCC_WR10_6_BIT_SYNC 0x01
185 #define SCC_WR10_LOOP_MODE 0x02
186 #define SCC_WR10_ABORT_UND 0x04
187 #define SCC_WR10_MARK_IDLE 0x08
188 #define SCC_WR10_ACT_POLL 0x10
189 #define SCC_WR10_NRZ 0x00
190 #define SCC_WR10_NRZI 0x20
191 #define SCC_WR10_FM1 0x40
192 #define SCC_WR10_FM0 0x60
193 #define SCC_WR10_CRC_PRESET 0x80
194
195 /* bit values for write register 11 */
196 /* clock mode control */
197
198 #define SCC_WR11_OUT_XTAL 0x00
199 #define SCC_WR11_OUT_TX_CLK 0x01
200 #define SCC_WR11_OUT_BR_GEN 0x02
201 #define SCC_WR11_OUT_DPLL 0x03
202 #define SCC_WR11_TRXC_OI 0x04
203 #define SCC_WR11_TX_RTXC 0x00
204 #define SCC_WR11_TX_TRXC 0x08
205 #define SCC_WR11_TX_BR_GEN 0x10
206 #define SCC_WR11_TX_DPLL 0x18
207 #define SCC_WR11_RX_RTXC 0x00
208 #define SCC_WR11_RX_TRXC 0x20
209 #define SCC_WR11_RX_BR_GEN 0x40
210 #define SCC_WR11_RX_DPLL 0x60
211 #define SCC_WR11_RTXC_XTAL 0x80
212
213 /* write register 12 */
214 /* lower byte of baud rate generator time constant */
215
216 /* write register 13 */
217 /* upper byte of baud rate generator time constant */
218
219 /* bit values for write register 14 */
220 /* misc control bits */
221
222 #define SCC_WR14_BR_EN 0x01
223 #define SCC_WR14_BR_SRC 0x02
224 #define SCC_WR14_DTR_FUNC 0x04
225 #define SCC_WR14_AUTO_ECHO 0x08
226 #define SCC_WR14_LCL_LOOP 0x10
227 #define SCC_WR14_NULL 0x00
228 #define SCC_WR14_SEARCH 0x20
229 #define SCC_WR14_RST_CLK 0x40
230 #define SCC_WR14_DIS_DPLL 0x60
231 #define SCC_WR14_SRC_BR 0x80
232 #define SCC_WR14_SRC_RTXC 0xa0
233 #define SCC_WR14_FM_MODE 0xc0
234 #define SCC_WR14_NRZI 0xe0
235
236 /* bit values for write register 15 */
237 /* external/status interrupt control */
238
239 #define SCC_WR15_ZERO_CNT 0x02
240 #define SCC_WR15_CD_IE 0x08
241 #define SCC_WR15_SYNC_IE 0x10
242 #define SCC_WR15_CTS_IE 0x20
243 #define SCC_WR15_TX_UND_IE 0x40
244 #define SCC_WR15_BREAK_IE 0x80
245
246 /* bit values for read register 0 */
247 /* tx/rx buffer status and external status */
248
249 #define SCC_RR0_RX_AVAIL 0x01
250 #define SCC_RR0_ZERO_CNT 0x02
251 #define SCC_RR0_TX_EMPTY 0x04
252 #define SCC_RR0_CD 0x08
253 #define SCC_RR0_SYNC 0x10
254 #define SCC_RR0_CTS 0x20
255 #define SCC_RR0_TX_UND 0x40
256 #define SCC_RR0_BREAK 0x80
257
258 /* bit values for read register 1 */
259
260 #define SCC_RR1_ALL_SENT 0x01
261 #define SCC_RR1_RES_CD_2 0x02
262 #define SCC_RR1_RES_CD_1 0x01
263 #define SCC_RR1_RES_CD_0 0x08
264 #define SCC_RR1_PAR_ERR 0x10
265 #define SCC_RR1_RX_OV_ERR 0x20
266 #define SCC_RR1_CRC_ERR 0x40
267 #define SCC_RR1_END_FRAME 0x80
268
269 /* read register 2 */
270 /* interrupt vector */
271
272 /* bit values for read register 3 */
273 /* interrupt pending register */
274
275 #define SCC_RR3_B_EXT_IP 0x01
276 #define SCC_RR3_B_TX_IP 0x02
277 #define SCC_RR3_B_RX_IP 0x04
278 #define SCC_RR3_A_EXT_IP 0x08
279 #define SCC_RR3_A_TX_IP 0x10
280 #define SCC_RR3_A_RX_IP 0x20
281
282 /* read register 8 */
283 /* receive data register */
284
285 /* bit values for read register 10 */
286 /* misc status bits */
287
288 #define SCC_RR10_ON_LOOP 0x02
289 #define SCC_RR10_LOOP_SEND 0x10
290 #define SCC_RR10_2_CLK_MIS 0x40
291 #define SCC_RR10_1_CLK_MIS 0x80
292
293 /* read register 12 */
294 /* lower byte of time constant */
295
296 /* read register 13 */
297 /* upper byte of time constant */
298
299 /* bit values for read register 15 */
300 /* external/status ie bits */
301
302 #define SCC_RR15_ZERO_CNT 0x02
303 #define SCC_RR15_CD_IE 0x08
304 #define SCC_RR15_SYNC_IE 0x10
305 #define SCC_RR15_CTS_IE 0x20
306 #define SCC_RR15_TX_UND_IE 0x40
307 #define SCC_RR15_BREAK_IE 0x80
308
309 typedef struct _z85c30_context
310 {
311  uint8_t ucModemCtrl;
313
314 /*
315  * The following macro calculates the Baud constant. For the Z85C30 chip.
316  *
317  * Note: baud constant = ((clock frequency / Clock_X) / (2 * Baud Rate)) - 2
318  * eg ((10,000,000 / 16) / (2 * Baud Rate)) - 2
319  */
320
321 #define Z85C30_Baud( _clock, _baud_rate ) \
322  ( ((_clock) /( 16 * 2 * _baud_rate)) - 2)
323
324 #define Z85C30_Status_Is_RX_character_available(_status) \
325  ((_status) & SCC_RR0_RX_AVAIL)
326
327 #define Z85C30_Status_Is_TX_buffer_empty(_status) \
328  ((_status) & SCC_RR0_TX_EMPTY)
329
330 #define Z85C30_Status_Is_CTS_asserted(_status) \
331  ((_status) & SCC_RR0_CTS)
332
333 #define Z85C30_Status_Is_break_abort(_status) \
334  ((_status) & SCC_RR0_BREAK)
335
336 /*
337  * Private routines
338  */
339
340 Z85C30_STATIC void z85c30_initialize_port(
341  int minor
342 );
343
344 Z85C30_STATIC void z85c30_init(int minor);
345
346 Z85C30_STATIC int z85c30_set_attributes(
347  int minor,
348  const struct termios *t
349 );
350
351 Z85C30_STATIC int z85c30_open(
352  int major,
353  int minor,
354  void * arg
355 );
356
357 Z85C30_STATIC int z85c30_close(
358  int major,
359  int minor,
360  void * arg
361 );
362
363 Z85C30_STATIC void z85c30_write_polled(
364  int minor,
365  char cChar
366 );
367
368 Z85C30_STATIC int z85c30_assert_RTS(
369  int minor
370 );
371
372 Z85C30_STATIC int z85c30_negate_RTS(
373  int minor
374 );
375
376 Z85C30_STATIC int z85c30_assert_DTR(
377  int minor
378 );
379
380 Z85C30_STATIC int z85c30_negate_DTR(
381  int minor
382 );
383
384 Z85C30_STATIC void z85c30_initialize_interrupts(int minor);
385
386 Z85C30_STATIC ssize_t z85c30_write_support_int(
387  int minor,
388  const char *buf,
389  size_t len
390 );
391
392 Z85C30_STATIC ssize_t z85c30_write_support_polled(
393  int minor,
394  const char *buf,
395  size_t len
396 );
397
398 Z85C30_STATIC int z85c30_inbyte_nonblocking_polled(
399  int minor
400 );
401
402 Z85C30_STATIC void z85c30_enable_interrupts(
403  int minor,
404  int interrupt_mask
405 );
406
407 Z85C30_STATIC void z85c30_process(
408  int minor,
409  uint8_t ucIntPend
410 );
411
412 Z85C30_STATIC rtems_isr z85c30_isr(
413  rtems_vector_number vector
414 );
415
416 #ifdef __cplusplus
417 }
418 #endif
419
420 #endif
Definition: z85c30_p.h:309
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
