RTEMS  5.1
z8036.h
1
13 /*
14  * COPYRIGHT (c) 1989-2011.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef _RTEMS_ZILOG_Z8036_H
23 #define _RTEMS_ZILOG_Z8036_H
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 /* macros */
30
31 #define Z8036( ptr ) ((volatile struct z8036_map *)(ptr))
32
33 #define Z8x36_STATE0 ( z8036 ) \
34  { /*char *garbage = *(Z8036(z8036))->???; */ }
35
36
37 #define Z8x36_WRITE( z8036, reg, data ) \
38  (Z8036(z8036))->reg = (data)
39
40
41 #define Z8x36_READ( z8036, reg, data ) \
42  (Z8036(z8036))->reg = (data)
43
44 /* structures */
45
46 struct z8036_map {
47 /* MAIN CONTROL REGISTERS (0x00-0x07) */
48  uint8_t MASTER_INTR; /* Master Interrupt Ctl Reg */
49  uint8_t MASTER_CFG; /* Master Configuration Ctl Reg */
50  uint8_t PORTA_VECTOR; /* Port A - Interrupt Vector */
51  uint8_t PORTB_VECTOR; /* Port B - Interrupt Vector */
52  uint8_t CNT_TMR_VECTOR; /* Counter/Timer Interrupt Vector */
53  uint8_t PORTC_DATA_POLARITY; /* Port C - Data Path Polarity */
54  uint8_t PORTC_DIRECTION; /* Port C - Data Direction */
55  uint8_t PORTC_SPECIAL_IO_CTL; /* Port C - Special IO Control */
56 /* MOST OFTEN ACCESSED REGISTERS (0x08 - 0x0f) */
57  uint8_t PORTA_CMD_STATUS; /* Port A - Command Status Reg */
58  uint8_t PORTB_CMD_STATUS; /* Port B - Command Status Reg */
59  uint8_t CT1_CMD_STATUS; /* Ctr/Timer 1 - Command Status Reg */
60  uint8_t CT2_CMD_STATUS; /* Ctr/Timer 2 - Command Status Reg */
61  uint8_t CT3_CMD_STATUS; /* Ctr/Timer 3 - Command Status Reg */
62  uint8_t PORTA_DATA; /* Port A - Data */
63  uint8_t PORTB_DATA; /* Port B - Data */
64  uint8_t PORTC_DATA; /* Port C - Data */
65 /* COUNTER/TIMER RELATED REGISTERS (0x10-0x1f) */
66  uint8_t CT1_CUR_CNT_MSB; /* Ctr/Timer 1 - Current Count (MSB) */
67  uint8_t CT1_CUR_CNT_LSB; /* Ctr/Timer 1 - Current Count (LSB) */
68  uint8_t CT2_CUR_CNT_MSB; /* Ctr/Timer 2 - Current Count (MSB) */
69  uint8_t CT2_CUR_CNT_LSB; /* Ctr/Timer 2 - Current Count (LSB) */
70  uint8_t CT3_CUR_CNT_MSB; /* Ctr/Timer 3 - Current Count (MSB) */
71  uint8_t CT3_CUR_CNT_LSB; /* Ctr/Timer 3 - Current Count (LSB) */
72  uint8_t CT1_TIME_CONST_MSB; /* Ctr/Timer 1 - Time Constant (MSB) */
73  uint8_t CT1_TIME_CONST_LSB; /* Ctr/Timer 1 - Time Constant (LSB) */
74  uint8_t CT2_TIME_CONST_MSB; /* Ctr/Timer 2 - Time Constant (MSB) */
75  uint8_t CT2_TIME_CONST_LSB; /* Ctr/Timer 2 - Time Constant (LSB) */
76  uint8_t CT3_TIME_CONST_MSB; /* Ctr/Timer 3 - Time Constant (MSB) */
77  uint8_t CT3_TIME_CONST_LSB; /* Ctr/Timer 3 - Time Constant (LSB) */
78  uint8_t CT1_MODE_SPEC; /* Ctr/Timer 1 - Mode Specification */
79  uint8_t CT2_MODE_SPEC; /* Ctr/Timer 2 - Mode Specification */
80  uint8_t CT3_MODE_SPEC; /* Ctr/Timer 3 - Mode Specification */
81  uint8_t CURRENT_VECTOR; /* Current Vector */
82 /* PORT A SPECIFICATION REGISTERS (0x20 -0x27) */
83  uint8_t PORTA_MODE; /* Port A - Mode Specification */
84  uint8_t PORTA_HANDSHAKE; /* Port A - Handshake Specification */
85  uint8_t PORTA_DATA_POLARITY; /* Port A - Data Path Polarity */
86  uint8_t PORTA_DIRECTION; /* Port A - Data Direction */
87  uint8_t PORTA_SPECIAL_IO_CTL; /* Port A - Special IO Control */
88  uint8_t PORTA_PATT_POLARITY; /* Port A - Pattern Polarity */
89  uint8_t PORTA_PATT_TRANS; /* Port A - Pattern Transition */
90  uint8_t PORTA_PATT_MASK; /* Port A - Pattern Mask */
91 /* PORT B SPECIFICATION REGISTERS (0x28-0x2f) */
92  uint8_t PORTB_MODE; /* Port B - Mode Specification */
93  uint8_t PORTB_HANDSHAKE; /* Port B - Handshake Specification */
94  uint8_t PORTB_DATA_POLARITY; /* Port B - Data Path Polarity */
95  uint8_t PORTB_DIRECTION; /* Port B - Data Direction */
96  uint8_t PORTB_SPECIAL_IO_CTL; /* Port B - Special IO Control */
97  uint8_t PORTB_PATT_POLARITY; /* Port B - Pattern Polarity */
98  uint8_t PORTB_PATT_TRANS; /* Port B - Pattern Transition */
99  uint8_t PORTB_PATT_MASK; /* Port B - Pattern Mask */
100 };
101
102 #ifdef __cplusplus
103 }
104 #endif
105
106 #endif
Definition: z8036.h:46
