RTEMS  5.1
xz.h
1 /*
2  * XZ decompressor
3  *
4  * Authors: Lasse Collin <lasse.collin@tukaani.org>
5  * Igor Pavlov <http://7-zip.org/>
6  *
7  * This file has been put into the public domain.
8  * You can do whatever you want with this file.
9  */
10
11 #ifndef XZ_H
12 #define XZ_H
13
14 #ifdef __KERNEL__
15 # include <linux/stddef.h>
16 # include <linux/types.h>
17 #else
18 # include <stddef.h>
19 # include <stdint.h>
20 #endif
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 /* In Linux, this is used to make extern functions static when needed. */
27 #ifndef XZ_EXTERN
28 # define XZ_EXTERN extern
29 #endif
30
56 enum xz_mode {
57  XZ_SINGLE,
58  XZ_PREALLOC,
59  XZ_DYNALLOC
60 };
61
112 enum xz_ret {
113  XZ_OK,
114  XZ_STREAM_END,
115  XZ_UNSUPPORTED_CHECK,
116  XZ_MEM_ERROR,
117  XZ_MEMLIMIT_ERROR,
118  XZ_FORMAT_ERROR,
119  XZ_OPTIONS_ERROR,
120  XZ_DATA_ERROR,
121  XZ_BUF_ERROR
122 };
123
140 struct xz_buf {
141  const uint8_t *in;
142  size_t in_pos;
143  size_t in_size;
144
145  uint8_t *out;
146  size_t out_pos;
147  size_t out_size;
148 };
149
153 struct xz_dec;
154
198 XZ_EXTERN struct xz_dec *xz_dec_init(enum xz_mode mode, uint32_t dict_max);
199
218 XZ_EXTERN enum xz_ret xz_dec_run(struct xz_dec *s, struct xz_buf *b);
219
231 XZ_EXTERN void xz_dec_reset(struct xz_dec *s);
232
238 XZ_EXTERN void xz_dec_end(struct xz_dec *s);
239
240 /*
241  * Standalone build (userspace build or in-kernel build for boot time use)
242  * needs a CRC32 implementation. For normal in-kernel use, kernel's own
243  * CRC32 module is used instead, and users of this module don't need to
244  * care about the functions below.
245  */
246 #ifndef XZ_INTERNAL_CRC32
247 # ifdef __KERNEL__
248 # define XZ_INTERNAL_CRC32 0
249 # else
250 # define XZ_INTERNAL_CRC32 1
251 # endif
252 #endif
253
254 /*
255  * If CRC64 support has been enabled with XZ_USE_CRC64, a CRC64
256  * implementation is needed too.
257  */
258 #ifndef XZ_USE_CRC64
259 # undef XZ_INTERNAL_CRC64
260 # define XZ_INTERNAL_CRC64 0
261 #endif
262 #ifndef XZ_INTERNAL_CRC64
263 # ifdef __KERNEL__
264 # error Using CRC64 in the kernel has not been implemented.
265 # else
266 # define XZ_INTERNAL_CRC64 1
267 # endif
268 #endif
269
270 #if XZ_INTERNAL_CRC32
271 /*
272  * This must be called before any other xz_* function to initialize
273  * the CRC32 lookup table.
274  */
275 XZ_EXTERN void xz_crc32_init(void);
276
277 /*
278  * Update CRC32 value using the polynomial from IEEE-802.3. To start a new
279  * calculation, the third argument must be zero. To continue the calculation,
280  * the previously returned value is passed as the third argument.
281  */
282 XZ_EXTERN uint32_t xz_crc32(const uint8_t *buf, size_t size, uint32_t crc);
283 #endif
284
285 #if XZ_INTERNAL_CRC64
286 /*
287  * This must be called before any other xz_* function (except xz_crc32_init())
288  * to initialize the CRC64 lookup table.
289  */
290 XZ_EXTERN void xz_crc64_init(void);
291
292 /*
293  * Update CRC64 value using the polynomial from ECMA-182. To start a new
294  * calculation, the third argument must be zero. To continue the calculation,
295  * the previously returned value is passed as the third argument.
296  */
297 XZ_EXTERN uint64_t xz_crc64(const uint8_t *buf, size_t size, uint64_t crc);
298 #endif
299
300 #ifdef __cplusplus
301 }
302 #endif
303
304 #endif
Definition: xz.h:140
Definition: xz_dec_stream.c:26
unsigned size
Definition: tte.h:74
