RTEMS
5.1
13 #define STDIN_BASEADDRESS 0x40600000 14 #define STDOUT_BASEADDRESS 0x40600000 19 #define XPAR_XPLBARB_NUM_INSTANCES 1 22 #define XPAR_PLB_BASEADDR 0x00000000 23 #define XPAR_PLB_HIGHADDR 0x00000000 24 #define XPAR_PLB_DEVICE_ID 0 25 #define XPAR_PLB_PLB_NUM_MASTERS 3 31 #define XPAR_XOPBARB_NUM_INSTANCES 1 34 #define XPAR_OPB_BASEADDR 0xFFFFFFFF 35 #define XPAR_OPB_HIGHADDR 0x00000000 36 #define XPAR_OPB_DEVICE_ID 0 37 #define XPAR_OPB_NUM_MASTERS 1 43 #define XPAR_XUARTLITE_NUM_INSTANCES 1 46 #define XPAR_CONSOLE_BASEADDR 0x40600000 47 #define XPAR_CONSOLE_HIGHADDR 0x4060FFFF 48 #define XPAR_CONSOLE_DEVICE_ID 0 49 #define XPAR_CONSOLE_BAUDRATE 115200 50 #define XPAR_CONSOLE_USE_PARITY 0 51 #define XPAR_CONSOLE_ODD_PARITY 0 52 #define XPAR_CONSOLE_DATA_BITS 8 58 #define XPAR_XGPIO_NUM_INSTANCES 3 61 #define XPAR_LEDS_BASEADDR 0x40000000 62 #define XPAR_LEDS_HIGHADDR 0x4000FFFF 63 #define XPAR_LEDS_DEVICE_ID 0 64 #define XPAR_LEDS_INTERRUPT_PRESENT 0 65 #define XPAR_LEDS_IS_DUAL 0 69 #define XPAR_PBLEDS_BASEADDR 0x40020000 70 #define XPAR_PBLEDS_HIGHADDR 0x4002FFFF 71 #define XPAR_PBLEDS_DEVICE_ID 1 72 #define XPAR_PBLEDS_INTERRUPT_PRESENT 0 73 #define XPAR_PBLEDS_IS_DUAL 0 77 #define XPAR_PUSHBUTTONS_BASEADDR 0x40040000 78 #define XPAR_PUSHBUTTONS_HIGHADDR 0x4004FFFF 79 #define XPAR_PUSHBUTTONS_DEVICE_ID 2 80 #define XPAR_PUSHBUTTONS_INTERRUPT_PRESENT 1 81 #define XPAR_PUSHBUTTONS_IS_DUAL 0 87 #define XPAR_XTMRCTR_NUM_INSTANCES 1 90 #define XPAR_OPBTIMER_BASEADDR 0x41C00000 91 #define XPAR_OPBTIMER_HIGHADDR 0x41C0FFFF 92 #define XPAR_OPBTIMER_DEVICE_ID 0 97 #define XPAR_INTC_MAX_NUM_INTR_INPUTS 3 98 #define XPAR_XINTC_HAS_IPR 1 99 #define XPAR_XINTC_USE_DCR 0 101 #define XPAR_XINTC_NUM_INSTANCES 1 104 #define XPAR_INTC_BASEADDR 0x41200000 105 #define XPAR_INTC_HIGHADDR 0x4120FFFF 106 #define XPAR_INTC_DEVICE_ID 0 107 #define XPAR_INTC_KIND_OF_INTR 0x00000000 112 #define XPAR_INTC_SINGLE_BASEADDR 0x41200000 113 #define XPAR_INTC_SINGLE_HIGHADDR 0x4120FFFF 114 #define XPAR_INTC_SINGLE_DEVICE_ID XPAR_INTC_DEVICE_ID 115 #define XPAR_OPBTIMER_INTERRUPT_MASK 0X000001 116 #define XPAR_INTC_OPBTIMER_INTERRUPT_INTR 0 117 #define XPAR_ETHERNET_IP2INTC_IRPT_MASK 0X000002 118 #define XPAR_INTC_ETHERNET_IP2INTC_IRPT_INTR 1 119 #define XPAR_PUSHBUTTONS_IP2INTC_IRPT_MASK 0X000004 120 #define XPAR_INTC_PUSHBUTTONS_IP2INTC_IRPT_INTR 2 125 #define XPAR_XDDR_NUM_INSTANCES 1 128 #define XPAR_DDR_SDRAM_64MX32_ECC_BASEADDR 0xFFFFFFFF 129 #define XPAR_DDR_SDRAM_64MX32_ECC_HIGHADDR 0x00000000 130 #define XPAR_DDR_SDRAM_64MX32_DEVICE_ID 0 131 #define XPAR_DDR_SDRAM_64MX32_INCLUDE_ECC_INTR 0 137 #define XPAR_DDR_SDRAM_64MX32_MEM0_BASEADDR 0x00000000 138 #define XPAR_DDR_SDRAM_64MX32_MEM0_HIGHADDR 0x03FFFFFF 144 #define XPAR_HARD_TEMAC_0_PHY_TYPE 1 150 #define XPAR_XTEMAC_NUM_INSTANCES 1 153 #define XPAR_ETHERNET_DEVICE_ID 0 154 #define XPAR_ETHERNET_BASEADDR 0x81200000 155 #define XPAR_ETHERNET_HIGHADDR 0x8120FFFF 156 #define XPAR_ETHERNET_RXFIFO_DEPTH 32768 157 #define XPAR_ETHERNET_TXFIFO_DEPTH 32768 158 #define XPAR_ETHERNET_MAC_FIFO_DEPTH 64 159 #define XPAR_ETHERNET_DMA_TYPE 1 160 #define XPAR_ETHERNET_TX_DRE_TYPE 0 161 #define XPAR_ETHERNET_RX_DRE_TYPE 0 162 #define XPAR_ETHERNET_INCLUDE_TX_CSUM 0 163 #define XPAR_ETHERNET_INCLUDE_RX_CSUM 0 170 #define XPAR_FLASH_NUM_BANKS_MEM 1 176 #define XPAR_FLASH_MEM0_BASEADDR 0x06000000 177 #define XPAR_FLASH_MEM0_HIGHADDR 0x067FFFFF 183 #define XPAR_PLB_BRAM_IF_CNTLR_1_BASEADDR 0xffff8000 184 #define XPAR_PLB_BRAM_IF_CNTLR_1_HIGHADDR 0xffffffff 189 #define XPAR_CPU_PPC405_CORE_CLOCK_FREQ_HZ 300000000
