RTEMS  5.1
xiltemac.h
1 /*
2  * Driver for plb inteface of the xilinx temac 3.00a
3  *
4  * Author: Keith Robertson <kjrobert@alumni.uwaterloo.ca>
5  * Copyright (c) 2007 Linn Products Ltd, Scotland.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  *
11  */
12
13 #ifndef _XILINX_TEMAC_
14 #define _XILINX_TEMAC_
15 #include <rtems/irq.h>
16
17
18 #define XILTEMAC_DRIVER_PREFIX "xiltemac"
19
20 #define DRIVER_PREFIX XILTEMAC_DRIVER_PREFIX
21
22
25 #define XTE_DISR_OFFSET 0x00000000
26 #define XTE_DIPR_OFFSET 0x00000004
27 #define XTE_DIER_OFFSET 0x00000008
28 #define XTE_DIIR_OFFSET 0x00000018
29 #define XTE_DGIE_OFFSET 0x0000001C
30 #define XTE_IPISR_OFFSET 0x00000020
31 #define XTE_IPIER_OFFSET 0x00000028
32 #define XTE_DSR_OFFSET 0x00000040
36 #define XTE_PFIFO_TX_BASE_OFFSET 0x00002000
37 #define XTE_PFIFO_TX_VACANCY_OFFSET 0x00002004
38 #define XTE_PFIFO_TX_DATA_OFFSET 0x00002100
42 #define XTE_PFIFO_RX_BASE_OFFSET 0x00002010
43 #define XTE_PFIFO_RX_VACANCY_OFFSET 0x00002014
44 #define XTE_PFIFO_RX_DATA_OFFSET 0x00002200
48 #define XTE_PFIFO_COUNT_MASK 0x00FFFFFF
49
52 #define XTE_DMA_SEND_OFFSET 0x00002300
53 #define XTE_DMA_RECV_OFFSET 0x00002340
57 #define XTE_CR_OFFSET 0x00001000
58 #define XTE_TPLR_OFFSET 0x00001004
59 #define XTE_TSR_OFFSET 0x00001008
60 #define XTE_RPLR_OFFSET 0x0000100C
61 #define XTE_RSR_OFFSET 0x00001010
62 #define XTE_IFGP_OFFSET 0x00001014
63 #define XTE_TPPR_OFFSET 0x00001018
71 #define XTE_HOST_IPIF_OFFSET 0x00003000
73 #define XTE_ERXC0_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000200)
74 #define XTE_ERXC1_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000240)
75 #define XTE_ETXC_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000280)
76 #define XTE_EFCC_OFFSET (XTE_HOST_IPIF_OFFSET + 0x000002C0)
77 #define XTE_ECFG_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000300)
78 #define XTE_EGMIC_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000320)
79 #define XTE_EMC_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000340)
80 #define XTE_EUAW0_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000380)
81 #define XTE_EUAW1_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000384)
82 #define XTE_EMAW0_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000388)
83 #define XTE_EMAW1_OFFSET (XTE_HOST_IPIF_OFFSET + 0x0000038C)
84 #define XTE_EAFM_OFFSET (XTE_HOST_IPIF_OFFSET + 0x00000390)
85 #define XTE_EIRS_OFFSET (XTE_HOST_IPIF_OFFSET + 0x000003A0)
86 #define XTE_EIREN_OFFSET (XTE_HOST_IPIF_OFFSET + 0x000003A4)
87 #define XTE_EMIID_OFFSET (XTE_HOST_IPIF_OFFSET + 0x000003B0)
88 #define XTE_EMIIC_OFFSET (XTE_HOST_IPIF_OFFSET + 0x000003B4)
90 /* Register masks. The following constants define bit locations of various
91  * control bits in the registers. Constants are not defined for those registers
92  * that have a single bit field representing all 32 bits. For further
93  * information on the meaning of the various bit masks, refer to the HW spec.
94  */
95
100 #define XTE_DXR_SEND_FIFO_MASK 0x00000040
101 #define XTE_DXR_RECV_FIFO_MASK 0x00000020
102 #define XTE_DXR_RECV_DMA_MASK 0x00000010
103 #define XTE_DXR_SEND_DMA_MASK 0x00000008
104 #define XTE_DXR_CORE_MASK 0x00000004
105 #define XTE_DXR_DPTO_MASK 0x00000002
106 #define XTE_DXR_TERR_MASK 0x00000001
112 #define XTE_IPXR_XMIT_DONE_MASK 0x00000001
113 #define XTE_IPXR_RECV_DONE_MASK 0x00000002
114 #define XTE_IPXR_AUTO_NEG_MASK 0x00000004
115 #define XTE_IPXR_RECV_REJECT_MASK 0x00000008
116 #define XTE_IPXR_XMIT_SFIFO_EMPTY_MASK 0x00000010
117 #define XTE_IPXR_RECV_LFIFO_EMPTY_MASK 0x00000020
118 #define XTE_IPXR_XMIT_LFIFO_FULL_MASK 0x00000040
119 #define XTE_IPXR_RECV_LFIFO_OVER_MASK 0x00000080
123 #define XTE_IPXR_RECV_LFIFO_UNDER_MASK 0x00000100
124 #define XTE_IPXR_XMIT_SFIFO_OVER_MASK 0x00000200
125 #define XTE_IPXR_XMIT_SFIFO_UNDER_MASK 0x00000400
126 #define XTE_IPXR_XMIT_LFIFO_OVER_MASK 0x00000800
127 #define XTE_IPXR_XMIT_LFIFO_UNDER_MASK 0x00001000
128 #define XTE_IPXR_RECV_PFIFO_ABORT_MASK 0x00002000
130 #define XTE_IPXR_RECV_LFIFO_ABORT_MASK 0x00004000
133 #define XTE_IPXR_RECV_DROPPED_MASK \
134  (XTE_IPXR_RECV_REJECT_MASK | \
135  XTE_IPXR_RECV_PFIFO_ABORT_MASK | \
136  XTE_IPXR_RECV_LFIFO_ABORT_MASK)
138 #define XTE_IPXR_XMIT_ERROR_MASK \
139  (XTE_IPXR_XMIT_SFIFO_OVER_MASK | \
140  XTE_IPXR_XMIT_SFIFO_UNDER_MASK | \
141  XTE_IPXR_XMIT_LFIFO_OVER_MASK | \
142  XTE_IPXR_XMIT_LFIFO_UNDER_MASK)
145 #define XTE_IPXR_RECV_ERROR_MASK \
146  (XTE_IPXR_RECV_DROPPED_MASK | \
147  XTE_IPXR_RECV_LFIFO_UNDER_MASK)
150 #define XTE_IPXR_FIFO_FATAL_ERROR_MASK \
151  (XTE_IPXR_XMIT_SFIFO_OVER_MASK | \
152  XTE_IPXR_XMIT_SFIFO_UNDER_MASK | \
153  XTE_IPXR_XMIT_LFIFO_OVER_MASK | \
154  XTE_IPXR_XMIT_LFIFO_UNDER_MASK | \
155  XTE_IPXR_RECV_LFIFO_UNDER_MASK)
163 #define XTE_DSR_RESET_MASK 0x0000000A
169 #define XTE_DGIE_ENABLE_MASK 0x80000000
175 #define XTE_CR_HTRST_MASK 0x00000008
176 #define XTE_CR_BCREJ_MASK 0x00000004
178 #define XTE_CR_MCREJ_MASK 0x00000002
180 #define XTE_CR_HDUPLEX_MASK 0x00000001
185 #define XTE_TPLR_TXPL_MASK 0x00003FFF
190 #define XTE_TSR_TXED_MASK 0x80000000
191 #define XTE_TSR_PFIFOU_MASK 0x40000000
192 #define XTE_TSR_TXA_MASK 0x3E000000
193 #define XTE_TSR_TXLC_MASK 0x01000000
194 #define XTE_TSR_TPCF_MASK 0x00000001
197 #define XTE_TSR_ERROR_MASK \
198  (XTE_TSR_TXED_MASK | \
199  XTE_TSR_PFIFOU_MASK | \
200  XTE_TSR_TXLC_MASK)
206 #define XTE_RPLR_RXPL_MASK 0x00003FFF
211 #define XTE_RSR_RPCF_MASK 0x00000001
216 #define XTE_IFG_IFGD_MASK 0x000000FF
221 #define XTE_TPPR_TPPD_MASK 0x0000FFFF
226 #define XTE_ERXC1_RXRST_MASK 0x80000000
227 #define XTE_ERXC1_RXJMBO_MASK 0x40000000
228 #define XTE_ERXC1_RXFCS_MASK 0x20000000
229 #define XTE_ERXC1_RXEN_MASK 0x10000000
230 #define XTE_ERXC1_RXVLAN_MASK 0x08000000
231 #define XTE_ERXC1_RXHD_MASK 0x04000000
232 #define XTE_ERXC1_RXLT_MASK 0x02000000
233 #define XTE_ERXC1_ERXC1_MASK 0x0000FFFF
241 #define XTE_ETXC_TXRST_MASK 0x80000000
242 #define XTE_ETXC_TXJMBO_MASK 0x40000000
243 #define XTE_ETXC_TXFCS_MASK 0x20000000
244 #define XTE_ETXC_TXEN_MASK 0x10000000
245 #define XTE_ETXC_TXVLAN_MASK 0x08000000
246 #define XTE_ETXC_TXHD_MASK 0x04000000
247 #define XTE_ETXC_TXIFG_MASK 0x02000000
252 #define XTE_EFCC_TXFLO_MASK 0x40000000
253 #define XTE_EFCC_RXFLO_MASK 0x20000000
258 #define XTE_ECFG_LINKSPD_MASK 0xC0000000
259 #define XTE_ECFG_RGMII_MASK 0x20000000
260 #define XTE_ECFG_SGMII_MASK 0x10000000
261 #define XTE_ECFG_1000BASEX_MASK 0x08000000
262 #define XTE_ECFG_HOSTEN_MASK 0x04000000
263 #define XTE_ECFG_TX16BIT 0x02000000
264 #define XTE_ECFG_RX16BIT 0x01000000
266 #define XTE_ECFG_LINKSPD_10 0x00000000
268 #define XTE_ECFG_LINKSPD_100 0x40000000
270 #define XTE_ECFG_LINKSPD_1000 0x80000000
275 #define XTE_EGMIC_RGLINKSPD_MASK 0xC0000000
276 #define XTE_EGMIC_SGLINKSPD_MASK 0x0000000C
277 #define XTE_EGMIC_RGSTATUS_MASK 0x00000002
278 #define XTE_EGMIC_RGHALFDUPLEX_MASK 0x00000001
280 #define XTE_EGMIC_RGLINKSPD_10 0x00000000
282 #define XTE_EGMIC_RGLINKSPD_100 0x40000000
284 #define XTE_EGMIC_RGLINKSPD_1000 0x80000000
286 #define XTE_EGMIC_SGLINKSPD_10 0x00000000
288 #define XTE_EGMIC_SGLINKSPD_100 0x00000004
290 #define XTE_EGMIC_SGLINKSPD_1000 0x00000008
295 #define XTE_EMC_MDIO_MASK 0x00000040
296 #define XTE_EMC_CLK_DVD_MAX 0x3F
301 #define XTE_EUAW1_MASK 0x0000FFFF
309 #define XTE_EMAW1_CAMRNW_MASK 0x00800000
310 #define XTE_EMAW1_CAMADDR_MASK 0x00030000
311 #define XTE_EUAW1_MASK 0x0000FFFF
315 #define XTE_EMAW1_CAMMADDR_SHIFT_MASK 16
322 #define XTE_EAFM_EPPRM_MASK 0x80000000
327 #define XTE_EMIID_MIIMWRDATA_MASK 0x0000FFFF
332 #define XTE_EMIID_MIIMDECADDR_MASK 0x0000FFFF
335 struct XilTemacStats
336 {
337  volatile uint32_t iInterrupts;
338
339  volatile uint32_t iRxInterrupts;
340  volatile uint32_t iRxRejectedInterrupts;
341  volatile uint32_t iRxRejectedInvalidFrame;
342  volatile uint32_t iRxRejectedDataFifoFull;
343  volatile uint32_t iRxRejectedLengthFifoFull;
344  volatile uint32_t iRxMaxDrained;
345  volatile uint32_t iRxStrayEvents;
346
347  volatile uint32_t iTxInterrupts;
348  volatile uint32_t iTxMaxDrained;
349 };
350
351 #define MAX_UNIT_BYTES 50
352
353 struct XilTemac
354 {
355  struct arpcom iArpcom;
356  struct XilTemacStats iStats;
357  struct ifnet* iIfp;
358
359  char iUnitName[MAX_UNIT_BYTES];
360
361  uint32_t iAddr;
362  rtems_event_set iIoEvent;
363
364  int iIsrVector;
365
366 #if PPC_HAS_CLASSIC_EXCEPTIONS
367  rtems_isr_entry iOldHandler;
368 #else
369  rtems_irq_connect_data iOldHandler;
370 #endif
371  int iIsPresent;
372 };
373
374
375 #endif /* _XILINX_EMAC_*/
Definition: xiltemac.h:376
uint32_t rtems_event_set
Integer type to hold an event set of up to 32 events represented as a bit field.
Definition: event.h:40
Definition: xiltemac.h:394
Definition: irq.h:45
