RTEMS  5.1
xdma_hardware_interface.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _XDMAD_IF_H
31 #define _XDMAD_IF_H
32
33 /*----------------------------------------------------------------------------
34  * Includes
35  *----------------------------------------------------------------------------*/
36
37 #include "chip.h"
38 /*----------------------------------------------------------------------------
39  * Types
40  *----------------------------------------------------------------------------*/
41
43 typedef struct _XdmaHardwareInterface {
44  uint8_t bXdmac;
45  uint32_t bPeriphID;
46  uint8_t bTransfer;
47  uint8_t bIfID;
49
50 /*----------------------------------------------------------------------------
51  * Exported functions
52  *----------------------------------------------------------------------------*/
53
54 extern uint8_t XDMAIF_IsValidatedPeripherOnDma(uint8_t bPeriphID);
55 extern uint8_t XDMAIF_Get_ChannelNumber (uint8_t bPeriphID, uint8_t bTransfer);
56
57 #endif //#ifndef _XDMAD_IF_H
58
Check if the given DMAC has associated peripheral identifier coded by the given peripheral.
Definition: xdma_hardware_interface.c:143
uint8_t bIfID
Definition: xdma_hardware_interface.h:47
uint32_t bPeriphID
Definition: xdma_hardware_interface.h:45
uint8_t bTransfer
Definition: xdma_hardware_interface.h:46
uint8_t bXdmac
Definition: xdma_hardware_interface.h:44
uint8_t XDMAIF_Get_ChannelNumber(uint8_t bPeriphID, uint8_t bTransfer)
Get peripheral identifier coded for hardware handshaking interface.
Definition: xdma_hardware_interface.c:119
Definition: xdma_hardware_interface.h:43
