RTEMS  5.1
vmeUniverse.h
1
9 #ifndef VME_UNIVERSE_UTIL_H
10 #define VME_UNIVERSE_UTIL_H
11
12 /*
13  * Authorship
14  * ----------
15  * This software was created by
16  * Till Straumann <strauman@slac.stanford.edu>, 2000-2007,
17  * Stanford Linear Accelerator Center, Stanford University.
18  *
19  * Acknowledgement of sponsorship
20  * ------------------------------
21  * This software was produced by
22  * the Stanford Linear Accelerator Center, Stanford University,
23  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
24  *
25  * Government disclaimer of liability
26  * ----------------------------------
27  * Neither the United States nor the United States Department of Energy,
28  * nor any of their employees, makes any warranty, express or implied, or
29  * assumes any legal liability or responsibility for the accuracy,
30  * completeness, or usefulness of any data, apparatus, product, or process
31  * disclosed, or represents that its use would not infringe privately owned
32  * rights.
33  *
34  * Stanford disclaimer of liability
35  * --------------------------------
36  * Stanford University makes no representations or warranties, express or
37  * implied, nor assumes any liability for the use of this software.
38  *
39  * Stanford disclaimer of copyright
40  * --------------------------------
41  * Stanford University, owner of the copyright, hereby disclaims its
42  * copyright and all other rights in this software. Hence, anyone may
43  * freely use it for any purpose without restriction.
44  *
45  * Maintenance of notices
46  * ----------------------
47  * In the interest of clarity regarding the origin and status of this
48  * SLAC software, this and all the preceding Stanford University notices
49  * are to remain affixed to any copy or derivative of this software made
50  * or distributed by the recipient and are to be affixed to any copy of
51  * software made or distributed by the recipient that contains a copy or
52  * derivative of this software.
53  *
54  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
55  */
56
65 #ifdef __vxworks
66 #include <vme.h>
67 #else
68
69 #include <bsp/vme_am_defs.h>
70
71 #endif
72
73 /* These bits can be or'ed with the address-modifier when calling
74  * the 'XlateAddr' routine below to further qualify the
75  * search criteria.
76  */
77 #define VME_MODE_MATCH_MASK (3<<30)
78 #define VME_MODE_EXACT_MATCH (2<<30) /* all bits must match */
79 #define VME_MODE_AS_MATCH (1<<30) /* only A16/24/32 must match */
80
81
82 typedef unsigned long LERegister; /* emphasize contents are little endian */
83
84 /****** NOTE: USE OF VmeUniverseDMAPacket IS DEPRECATED *********
85  ****** USE API IN VMEDMA.h INSTEAD *********/
86
87 /* NOTE: DMA packet descriptors MUST be 32 byte aligned */
88 typedef struct VmeUniverseDMAPacketRec_ {
89  LERegister dctl __attribute__((aligned(32)));
90  LERegister dtbc __attribute__((packed));
91  LERegister dla __attribute__((packed));
92  LERegister dummy1 __attribute__((packed));
93  LERegister dva __attribute__((packed));
94  LERegister dummy2 __attribute__((packed));
95  LERegister dcpp __attribute__((packed));
96  LERegister dummy3 __attribute__((packed));
98
99 /* PCI CSR register */
100 #define UNIV_REGOFF_PCI_CSR 0x4
101 # define UNIV_PCI_CSR_D_PE (1<<31) /* detected parity error; write 1 to clear */
102 # define UNIV_PCI_CSR_S_SERR (1<<30) /* SERR (signalled error) asserted; write 1 to clear */
103 # define UNIV_PCI_CSR_R_MA (1<<29) /* received master abort; write 1 to clear */
104 # define UNIV_PCI_CSR_R_TA (1<<28) /* received target abort; write 1 to clear */
105 # define UNIV_PCI_CSR_S_TA (1<<27) /* signalled target abort; write 1 to clear */
106 # define UNIV_PCI_CSR_DEVSEL_MASK (3<<25) /* device select timing (RO) */
107 # define UNIV_PCI_CSR_DP_D (1<<24) /* data parity error detected; write 1 to clear */
108 # define UNIV_PCI_CSR_TFBBC (1<<23) /* target fast back to back capable (RO) */
109 # define UNIV_PCI_CSR_MFBBC (1<<9) /* master fast back to back capable (RO) */
110 # define UNIV_PCI_CSR_SERR_EN (1<<8) /* enable SERR driver */
111 # define UNIV_PCI_CSR_WAIT (1<<7) /* wait cycle control (RO) */
112 # define UNIV_PCI_CSR_PERESP (1<<6) /* parity error response enable */
113 # define UNIV_PCI_CSR_VGAPS (1<<5) /* VGA palette snoop (RO) */
114 # define UNIV_PCI_CSR_MWI_EN (1<<4) /* Memory write and invalidate enable (RO) */
115 # define UNIV_PCI_CSR_SC (1<<3) /* special cycles (RO) */
116 # define UNIV_PCI_CSR_BM (1<<2) /* master enable (MUST SET TO ENABLE VME SLAVES) */
117 # define UNIV_PCI_CSR_MS (1<<1) /* target memory enable */
118 # define UNIV_PCI_CSR_IOS (1<<0) /* target IO enable */
119
120 /* Special cycle (ADOH, RMW) control register */
121 #define UNIV_REGOFF_SCYC_CTL 0x170 /* write 0 to disable */
122 # define UNIV_SCYC_CTL_LAS_IO (1<<2) /* PCI address space (1: IO, 0: mem) */
123 # define UNIV_SCYC_CTL_SCYC_RMW (1<<0) /* do a RMW cycle when reading PCI address */
124 # define UNIV_SCYC_CTL_SCYC_ADOH (2<<0) /* do a ADOH cycle when reading/writing PCI address */
125
126 /* Special cycle address register */
127 #define UNIV_REGOFF_SCYC_ADDR 0x174 /* PCI address (must be long word aligned) */
128
129 /* Special cycle Swap/Compare/Enable */
130 #define UNIV_REGOFF_SCYC_EN 0x178 /* mask determining the bits involved in the compare and swap operations for VME RMW cycles */
131
132 /* Special cycle compare data register */
133 #define UNIV_REGOFF_SCYC_CMP 0x17c /* data to compare with word returned from VME RMW read */
134
135 /* Special cycle swap data register */
136 #define UNIV_REGOFF_SCYC_SWP 0x180 /* If enabled bits of CMP match, corresponding SWP bits are written back to VME (under control of EN) */
137
138 /* PCI miscellaneous register */
139 #define UNIV_REGOFF_LMISC 0x184
140 # define UNIV_LMISC_CRT_MASK (7<<28) /* Univ. I only, not used on II */
141 # define UNIV_LMISC_CRT_INF (0<<28) /* Coupled Request Timeout */
142 # define UNIV_LMISC_CRT_128_US (1<<28) /* Coupled Request Timeout */
143 # define UNIV_LMISC_CRT_256_US (2<<28) /* Coupled Request Timeout */
144 # define UNIV_LMISC_CRT_512_US (3<<28) /* Coupled Request Timeout */
145 # define UNIV_LMISC_CRT_1024_US (4<<28) /* Coupled Request Timeout */
146 # define UNIV_LMISC_CRT_2048_US (5<<28) /* Coupled Request Timeout */
147 # define UNIV_LMISC_CRT_4096_US (6<<28) /* Coupled Request Timeout */
148
149 # define UNIV_LMISC_CWT_MASK (7<<24) /* coupled window timer */
150 # define UNIV_LMISC_CWT_DISABLE 0 /* disabled (release VME after 1 coupled xaction) */
151 # define UNIV_LMISC_CWT_16 (1<<24) /* 16 PCI clock cycles */
152 # define UNIV_LMISC_CWT_32 (2<<24) /* 32 PCI clock cycles */
153 # define UNIV_LMISC_CWT_64 (3<<24) /* 64 PCI clock cycles */
154 # define UNIV_LMISC_CWT_128 (4<<24) /* 128 PCI clock cycles */
155 # define UNIV_LMISC_CWT_256 (5<<24) /* 256 PCI clock cycles */
156 # define UNIV_LMISC_CWT_512 (6<<24) /* 512 PCI clock cycles */
157
158 /* PCI Command Error Log Register */
159 #define UNIV_REGOFF_L_CMDERR 0x18c
160 # define UNIV_L_CMDERR_CMDERR(reg) (((reg)>>28)&0xf) /* extract PCI cmd error log */
161 # define UNIV_L_CMDERR_M_ERR (1<<27) /* multiple errors have occurred */
162 # define UNIV_L_CMDERR_L_STAT (1<<23) /* PCI error log status valid (write 1 to clear and enable logging) */
163
164 /* PCI Address Error Log */
165 #define UNIV_REGOFF_LAERR 0x190 /* PCI fault address (if L_CMDERR_L_STAT valid) */
166 /* DMA Xfer Control Register */
167 #define UNIV_REGOFF_DCTL 0x200
168 # define UNIV_DCTL_L2V (1<<31) /* PCI->VME if set */
169 # define UNIV_DCTL_VDW_MSK (3<<22) /* VME max. width mask 0x00c00000 */
170 # define UNIV_DCTL_VDW_8 (0<<22) /* VME max. width 8 */
171 # define UNIV_DCTL_VDW_16 (1<<22) /* VME max. width 16 */
172 # define UNIV_DCTL_VDW_32 (2<<22) /* VME max. width 32 */
173 # define UNIV_DCTL_VDW_64 (3<<22) /* VME max. width 64 */
174 # define UNIV_DCTL_VAS_MSK (7<<16) /* VME AS mask 0x00070000 */
175 # define UNIV_DCTL_VAS_A16 (0<<16) /* VME A16 */
176 # define UNIV_DCTL_VAS_A24 (1<<16) /* VME A24 */
177 # define UNIV_DCTL_VAS_A32 (2<<16) /* VME A32 */
178 # define UNIV_DCTL_PGM_MSK (3<<14) /* VME PGM/DATA mask 0x0000c000 */
179 # define UNIV_DCTL_PGM (1<<14) /* VME PGM(1)/DATA(0) */
180 # define UNIV_DCTL_SUPER_MSK (3<<12) /* VME SUPER/USR mask 0x00003000 */
181 # define UNIV_DCTL_SUPER (1<<12) /* VME SUPER(1)/USR(0) */
182 # define UNIV_DCTL_NO_VINC (1<<9) /* VME no VME address increment [Universe IIa/b ONLY */
183 # define UNIV_DCTL_VCT (1<<8) /* VME enable BLT */
184 # define UNIV_DCTL_LD64EN (1<<7) /* PCI 64 enable */
185
186 /* DMA Xfer byte count register (is updated by DMA) */
187 #define UNIV_REGOFF_DTBC 0x204
188 /* DMA Xfer local (PCI) address (direction is set in DCTL) */
189 #define UNIV_REGOFF_DLA 0x208
190 /* DMA Xfer VME address (direction is set in DCTL)
191  * NOTE: (*UNIV_DVA) & ~7 == (*UNIV_DLA) & ~7 MUST HOLD
192  */
193 #define UNIV_REGOFF_DVA 0x210
194
195 /* DMA Xfer VME command packet pointer
196  * NOTE: The address stored here MUST be 32-byte aligned
197  */
198 #define UNIV_REGOFF_DCPP 0x218
199 /* these bits are only used in linked lists */
200 # define UNIV_DCPP_IMG_NULL (1<<0) /* last packet in list */
201 # define UNIV_DCPP_IMG_PROCESSED (1<<1) /* packet processed */
202
203 /* DMA Xfer General Control/Status register */
204 #define UNIV_REGOFF_DGCS 0x220
205 # define UNIV_DGCS_GO (1<<31) /* start xfer */
206 # define UNIV_DGCS_STOP_REQ (1<<30) /* stop xfer (immediate abort) */
207 # define UNIV_DGCS_HALT_REQ (1<<29) /* halt xfer (abort after current packet) */
208 # define UNIV_DGCS_CHAIN (1<<27) /* enable linked list mode */
209 # define UNIV_DGCS_VON_MSK (7<<20) /* VON mask */
210 # define UNIV_DGCS_VON_DONE (0<<20) /* VON counter disabled (do until done) */
211 # define UNIV_DGCS_VON_256 (1<<20) /* VON yield bus after 256 bytes */
212 # define UNIV_DGCS_VON_512 (2<<20) /* VON yield bus after 512 bytes */
213 # define UNIV_DGCS_VON_1024 (3<<20) /* VON yield bus after 1024 bytes */
214 # define UNIV_DGCS_VON_2048 (4<<20) /* VON yield bus after 2048 bytes */
215 # define UNIV_DGCS_VON_4096 (5<<20) /* VON yield bus after 4096 bytes */
216 # define UNIV_DGCS_VON_8192 (6<<20) /* VON yield bus after 8192 bytes */
217 # define UNIV_DGCS_VON_16384 (7<<20) /* VON yield bus after 16384 bytes */
218 # define UNIV_DGCS_VOFF_MSK (15<<16) /* VOFF mask */
219 # define UNIV_DGCS_VOFF_0_US (0<<16) /* re-request VME master after 0 us */
220 # define UNIV_DGCS_VOFF_2_US (8<<16) /* re-request VME master after 2 us */
221 # define UNIV_DGCS_VOFF_4_US (9<<16) /* re-request VME master after 4 us */
222 # define UNIV_DGCS_VOFF_8_US (10<<16)/* re-request VME master after 8 us */
223 # define UNIV_DGCS_VOFF_16_US (1<<16) /* re-request VME master after 16 us */
224 # define UNIV_DGCS_VOFF_32_US (2<<16) /* re-request VME master after 32 us */
225 # define UNIV_DGCS_VOFF_64_US (3<<16) /* re-request VME master after 64 us */
226 # define UNIV_DGCS_VOFF_128_US (4<<16) /* re-request VME master after 128 us */
227 # define UNIV_DGCS_VOFF_256_US (5<<16) /* re-request VME master after 256 us */
228 # define UNIV_DGCS_VOFF_512_US (6<<16) /* re-request VME master after 512 us */
229 # define UNIV_DGCS_VOFF_1024_US (7<<16) /* re-request VME master after 1024 us */
230 /* Status Bits (write 1 to clear) */
231 # define UNIV_DGCS_ACT (1<<15) /* DMA active */
232 # define UNIV_DGCS_STOP (1<<14) /* DMA stopped */
233 # define UNIV_DGCS_HALT (1<<13) /* DMA halted */
234 # define UNIV_DGCS_DONE (1<<11) /* DMA done (OK) */
235 # define UNIV_DGCS_LERR (1<<10) /* PCI bus error */
236 # define UNIV_DGCS_VERR (1<<9) /* VME bus error */
237 # define UNIV_DGCS_P_ERR (1<<8) /* programming protocol error (e.g. PCI master disabled) */
238 # define UNIV_DGCS_STATUS_CLEAR\
239  (UNIV_DGCS_ACT|UNIV_DGCS_STOP|UNIV_DGCS_HALT|\
240  UNIV_DGCS_DONE|UNIV_DGCS_LERR|UNIV_DGCS_VERR|UNIV_DGCS_P_ERR)
241 # define UNIV_DGCS_P_ERR (1<<8) /* programming protocol error (e.g. PCI master disabled) */
242 /* Interrupt Mask Bits */
243 # define UNIV_DGCS_INT_STOP (1<<6) /* interrupt when stopped */
244 # define UNIV_DGCS_INT_HALT (1<<5) /* interrupt when halted */
245 # define UNIV_DGCS_INT_DONE (1<<3) /* interrupt when done */
246 # define UNIV_DGCS_INT_LERR (1<<2) /* interrupt on LERR */
247 # define UNIV_DGCS_INT_VERR (1<<1) /* interrupt on VERR */
248 # define UNIV_DGCS_INT_P_ERR (1<<0) /* interrupt on P_ERR */
249 # define UNIV_DGCS_INT_MSK (0x0000006f) /* interrupt mask */
250
251 /* DMA Linked List Update Enable Register */
252 #define UNIV_REGOFF_D_LLUE 0x224
253 # define UNIV_D_LLUE_UPDATE (1<<31)
254
255
256 /* PCI (local) interrupt enable register */
257 #define UNIV_REGOFF_LINT_EN 0x300
258 # define UNIV_LINT_EN_LM3 (1<<23) /* location monitor 3 mask */
259 # define UNIV_LINT_EN_LM2 (1<<22) /* location monitor 2 mask */
260 # define UNIV_LINT_EN_LM1 (1<<21) /* location monitor 1 mask */
261 # define UNIV_LINT_EN_LM0 (1<<20) /* location monitor 0 mask */
262 # define UNIV_LINT_EN_MBOX3 (1<<19) /* mailbox 3 mask */
263 # define UNIV_LINT_EN_MBOX2 (1<<18) /* mailbox 2 mask */
264 # define UNIV_LINT_EN_MBOX1 (1<<17) /* mailbox 1 mask */
265 # define UNIV_LINT_EN_MBOX0 (1<<16) /* mailbox 0 mask */
266 # define UNIV_LINT_EN_ACFAIL (1<<15) /* ACFAIL irq mask */
267 # define UNIV_LINT_EN_SYSFAIL (1<<14) /* SYSFAIL irq mask */
268 # define UNIV_LINT_EN_SW_INT (1<<13) /* PCI (local) software irq */
269 # define UNIV_LINT_EN_SW_IACK (1<<12) /* VME software IACK mask */
270 # define UNIV_LINT_EN_VERR (1<<10) /* PCI VERR irq mask */
271 # define UNIV_LINT_EN_LERR (1<<9) /* PCI LERR irq mask */
272 # define UNIV_LINT_EN_DMA (1<<8) /* PCI DMA irq mask */
273 # define UNIV_LINT_EN_VIRQ7 (1<<7) /* VIRQ7 mask (universe does IACK automatically) */
274 # define UNIV_LINT_EN_VIRQ6 (1<<6) /* VIRQ6 mask */
275 # define UNIV_LINT_EN_VIRQ5 (1<<5) /* VIRQ5 mask */
276 # define UNIV_LINT_EN_VIRQ4 (1<<4) /* VIRQ4 mask */
277 # define UNIV_LINT_EN_VIRQ3 (1<<3) /* VIRQ3 mask */
278 # define UNIV_LINT_EN_VIRQ2 (1<<2) /* VIRQ2 mask */
279 # define UNIV_LINT_EN_VIRQ1 (1<<1) /* VIRQ1 mask */
280 # define UNIV_LINT_EN_VOWN (1<<0) /* VOWN mask */
281
282 /* PCI (local) interrupt status register */
283 #define UNIV_REGOFF_LINT_STAT 0x304
284 # define UNIV_LINT_STAT_LM3 (1<<23) /* location monitor 3 status */
285 # define UNIV_LINT_STAT_LM2 (1<<22) /* location monitor 2 status */
286 # define UNIV_LINT_STAT_LM1 (1<<21) /* location monitor 1 status */
287 # define UNIV_LINT_STAT_LM0 (1<<20) /* location monitor 0 status */
288 # define UNIV_LINT_STAT_MBOX3 (1<<19) /* mailbox 3 status */
289 # define UNIV_LINT_STAT_MBOX2 (1<<18) /* mailbox 2 status */
290 # define UNIV_LINT_STAT_MBOX1 (1<<17) /* mailbox 1 status */
291 # define UNIV_LINT_STAT_MBOX0 (1<<16) /* mailbox 0 status */
292 # define UNIV_LINT_STAT_ACFAIL (1<<15) /* ACFAIL irq status */
293 # define UNIV_LINT_STAT_SYSFAIL (1<<14) /* SYSFAIL irq status */
294 # define UNIV_LINT_STAT_SW_INT (1<<13) /* PCI (local) software irq */
295 # define UNIV_LINT_STAT_SW_IACK (1<<12) /* VME software IACK status */
296 # define UNIV_LINT_STAT_VERR (1<<10) /* PCI VERR irq status */
297 # define UNIV_LINT_STAT_LERR (1<<9) /* PCI LERR irq status */
298 # define UNIV_LINT_STAT_DMA (1<<8) /* PCI DMA irq status */
299 # define UNIV_LINT_STAT_VIRQ7 (1<<7) /* VIRQ7 status */
300 # define UNIV_LINT_STAT_VIRQ6 (1<<6) /* VIRQ6 status */
301 # define UNIV_LINT_STAT_VIRQ5 (1<<5) /* VIRQ5 status */
302 # define UNIV_LINT_STAT_VIRQ4 (1<<4) /* VIRQ4 status */
303 # define UNIV_LINT_STAT_VIRQ3 (1<<3) /* VIRQ3 status */
304 # define UNIV_LINT_STAT_VIRQ2 (1<<2) /* VIRQ2 status */
305 # define UNIV_LINT_STAT_VIRQ1 (1<<1) /* VIRQ1 status */
306 # define UNIV_LINT_STAT_VOWN (1<<0) /* VOWN status */
307 # define UNIV_LINT_STAT_CLR (0xfff7ff)/* Clear all status bits */
308
309 /* PCI (local) interrupt map 0 register */
310 #define UNIV_REGOFF_LINT_MAP0 0x308 /* mapping of VME IRQ sources to PCI irqs */
311 # define UNIV_LINT_MAP0_VIRQ7(lint) (((lint)&0x7)<<(7*4))
312 # define UNIV_LINT_MAP0_VIRQ6(lint) (((lint)&0x7)<<(6*4))
313 # define UNIV_LINT_MAP0_VIRQ5(lint) (((lint)&0x7)<<(5*4))
314 # define UNIV_LINT_MAP0_VIRQ4(lint) (((lint)&0x7)<<(4*4))
315 # define UNIV_LINT_MAP0_VIRQ3(lint) (((lint)&0x7)<<(3*4))
316 # define UNIV_LINT_MAP0_VIRQ2(lint) (((lint)&0x7)<<(2*4))
317 # define UNIV_LINT_MAP0_VIRQ1(lint) (((lint)&0x7)<<(1*4))
318 # define UNIV_LINT_MAP0_VOWN(lint) (((lint)&0x7)<<(0*4))
319
320 #define UNIV_REGOFF_LINT_MAP1 0x30c /* mapping of internal / VME IRQ sources to PCI irqs */
321 # define UNIV_LINT_MAP1_ACFAIL(lint) (((lint)&0x7)<<(7*4))
322 # define UNIV_LINT_MAP1_SYSFAIL(lint) (((lint)&0x7)<<(6*4))
323 # define UNIV_LINT_MAP1_SW_INT(lint) (((lint)&0x7)<<(5*4))
324 # define UNIV_LINT_MAP1_SW_IACK(lint) (((lint)&0x7)<<(4*4))
325 # define UNIV_LINT_MAP1_VERR(lint) (((lint)&0x7)<<(2*4))
326 # define UNIV_LINT_MAP1_LERR(lint) (((lint)&0x7)<<(1*4))
327 # define UNIV_LINT_MAP1_DMA(lint) (((lint)&0x7)<<(0*4))
328
329 /* enabling of generation of VME bus IRQs, TODO */
330 #define UNIV_REGOFF_VINT_EN 0x310
331 # define UNIV_VINT_EN_DISABLE_ALL 0
332 # define UNIV_VINT_EN_SWINT (1<<12)
333 # define UNIV_VINT_EN_SWINT_LVL(l) (1<<(((l)&7)+24)) /* universe II only */
334
335
336 /* status of generation of VME bus IRQs */
337 #define UNIV_REGOFF_VINT_STAT 0x314
338 # define UNIV_VINT_STAT_LINT(lint) (1<<((lint)&7))
339 # define UNIV_VINT_STAT_LINT_MASK (0xff)
340 # define UNIV_VINT_STAT_CLR (0xfe0f17ff)
341 # define UNIV_VINT_STAT_SWINT(l) (1<<(((l)&7)+24))
342
343 #define UNIV_REGOFF_VINT_MAP0 0x318 /* VME destination of PCI IRQ source, TODO */
344
345 #define UNIV_REGOFF_VINT_MAP1 0x31c /* VME destination of PCI IRQ source, TODO */
346 # define UNIV_VINT_MAP1_SWINT(level) (((level)&0x7)<<16)
347
348 /* NOTE: The universe seems to always set LSB (which has a special purpose in
349  * the STATID register: enable raising a SW_INT on IACK) on the
350  * vector it puts out on the bus...
351  */
352 #define UNIV_REGOFF_VINT_STATID 0x320 /* our status/id response to IACK, TODO */
353 # define UNIV_VINT_STATID(id) ((id)<<24)
354
355 #define UNIV_REGOFF_VIRQ1_STATID 0x324 /* status/id of VME IRQ level 1 */
356 #define UNIV_REGOFF_VIRQ2_STATID 0x328 /* status/id of VME IRQ level 2 */
357 #define UNIV_REGOFF_VIRQ3_STATID 0x32c /* status/id of VME IRQ level 3 */
358 #define UNIV_REGOFF_VIRQ4_STATID 0x330 /* status/id of VME IRQ level 4 */
359 #define UNIV_REGOFF_VIRQ5_STATID 0x334 /* status/id of VME IRQ level 5 */
360 #define UNIV_REGOFF_VIRQ6_STATID 0x338 /* status/id of VME IRQ level 6 */
361 #define UNIV_REGOFF_VIRQ7_STATID 0x33c /* status/id of VME IRQ level 7 */
362 # define UNIV_VIRQ_ERR (1<<8) /* set if universe encountered a bus error when doing IACK */
363 # define UNIV_VIRQ_STATID_MASK (0xff)
364
365 #define UNIV_REGOFF_LINT_MAP2 0x340 /* mapping of internal sources to PCI irqs */
366 # define UNIV_LINT_MAP2_LM3(lint) (((lint)&0x7)<<7*4) /* location monitor 3 */
367 # define UNIV_LINT_MAP2_LM2(lint) (((lint)&0x7)<<6*4) /* location monitor 2 */
368 # define UNIV_LINT_MAP2_LM1(lint) (((lint)&0x7)<<5*4) /* location monitor 1 */
369 # define UNIV_LINT_MAP2_LM0(lint) (((lint)&0x7)<<4*4) /* location monitor 0 */
370 # define UNIV_LINT_MAP2_MBOX3(lint) (((lint)&0x7)<<3*4) /* mailbox 3 */
371 # define UNIV_LINT_MAP2_MBOX2(lint) (((lint)&0x7)<<2*4) /* mailbox 2 */
372 # define UNIV_LINT_MAP2_MBOX1(lint) (((lint)&0x7)<<1*4) /* mailbox 1 */
373 # define UNIV_LINT_MAP2_MBOX0(lint) (((lint)&0x7)<<0*4) /* mailbox 0 */
374
375 #define UNIV_REGOFF_VINT_MAP2 0x344 /* mapping of internal sources to VME irqs */
376 # define UNIV_VINT_MAP2_MBOX3(vint) (((vint)&0x7)<<3*4) /* mailbox 3 */
377 # define UNIV_VINT_MAP2_MBOX2(vint) (((vint)&0x7)<<2*4) /* mailbox 2 */
378 # define UNIV_VINT_MAP2_MBOX1(vint) (((vint)&0x7)<<1*4) /* mailbox 1 */
379 # define UNIV_VINT_MAP2_MBOX0(vint) (((vint)&0x7)<<0*4) /* mailbox 0 */
380
381 #define UNIV_REGOFF_MBOX0 0x348 /* mailbox 0 */
382 #define UNIV_REGOFF_MBOX1 0x34c /* mailbox 1 */
383 #define UNIV_REGOFF_MBOX2 0x350 /* mailbox 2 */
384 #define UNIV_REGOFF_MBOX3 0x354 /* mailbox 3 */
385
386 #define UNIV_REGOFF_SEMA0 0x358 /* semaphore 0 */
387 #define UNIV_REGOFF_SEMA1 0x35c /* semaphore 0 */
388 /* TODO define semaphore register bits */
389
390 #define UNIV_REGOFF_MAST_CTL 0x400 /* master control register */
391 # define UNIV_MAST_CTL_MAXRTRY(val) (((val)&0xf)<<7*4) /* max # of pci master retries */
392 # define UNIV_MAST_CTL_PWON(val) (((val)&0xf)<<6*4) /* posted write xfer count */
393 # define UNIV_MAST_CTL_VRL(val) (((val)&0x3)<<22) /* VME bus request level */
394 # define UNIV_MAST_CTL_VRM (1<<21) /* bus request mode (demand = 0, fair = 1) */
395 # define UNIV_MAST_CTL_VREL (1<<20) /* bus release mode (when done = 0, on request = 1) */
396 # define UNIV_MAST_CTL_VOWN (1<<19) /* bus ownership (release = 0, acquire/hold = 1) */
397 # define UNIV_MAST_CTL_VOWN_ACK (1<<18) /* bus ownership (not owned = 0, acquired/held = 1) */
398 # define UNIV_MAST_CTL_PABS(val) (((val)&0x3)<<3*4) /* PCI aligned burst size (32,64,128 byte / 0x3 is reserved) */
399 # define UNIV_MAST_CTL_BUS_NO(val) (((val)&0xff)<<0*4) /* PCI bus number */
400
401 #define UNIV_REGOFF_MISC_CTL 0x404 /* misc control register */
402 # define UNIV_MISC_CTL_VBTO(val) (((val)&0x7)<<7*4) /* VME bus timeout (0=disable, 16*2^(val-1) us) */
403 # define UNIV_MISC_CTL_VARB (1<<26) /* VME bus arbitration mode (0=round robin, 1= priority) */
404 # define UNIV_MISC_CTL_VARBTO(val) (((val)&0x3)<<6*4) /* arbitration time out: disable, 16us, 256us, reserved */
405 # define UNIV_MISC_CTL_SW_LRST (1<<23) /* software PCI reset */
406 # define UNIV_MISC_CTL_SW_SYSRST (1<<22) /* software VME reset */
407 # define UNIV_MISC_CTL_BI (1<<20) /* BI mode */
408 # define UNIV_MISC_CTL_ENGBI (1<<19) /* enable global BI mode initiator */
409 # define UNIV_MISC_CTL_SYSCON (1<<17) /* (R/W) 1:universe is system controller */
410 # define UNIV_MISC_CTL_V64AUTO (1<<16) /* (R/W) 1:initiate VME64 auto id slave participation */
411
412 /* U2SPEC described in VGM manual */
413 /* NOTE: the Joerger vtr10012_8 needs the timing to be tweaked!!!! READt27 must be _no_delay_
414  */
415 #define UNIV_REGOFF_U2SPEC 0x4fc
416 # define UNIV_U2SPEC_DTKFLTR (1<<12) /* DTAck filter: 0: slow, better filter; 1: fast, poorer filter */
417 # define UNIV_U2SPEC_MASt11 (1<<10) /* Master parameter t11 (DS hi time during BLT and MBLTs) */
418 # define UNIV_U2SPEC_READt27_DEFAULT (0<<8) /* VME master parameter t27: (latch data after DTAck + 25ns) */
419 # define UNIV_U2SPEC_READt27_FAST (1<<8) /* VME master parameter t27: (latch data faster than 25ns) */
420 # define UNIV_U2SPEC_READt27_NODELAY (2<<8) /* VME master parameter t27: (latch data without any delay) */
421 # define UNIV_U2SPEC_POSt28_FAST (1<<2) /* VME slave parameter t28: (faster time of DS to DTAck for posted write) */
422 # define UNIV_U2SPEC_PREt28_FAST (1<<0) /* VME slave parameter t28: (faster time of DS to DTAck for prefetch read) */
423
424 /* Location Monitor control register */
425 #define UNIV_REGOFF_LM_CTL 0xf64
426 # define UNIV_LM_CTL_EN (1<<31) /* image enable */
427 # define UNIV_LM_CTL_PGM (1<<23) /* program AM */
428 # define UNIV_LM_CTL_DATA (1<<22) /* data AM */
429 # define UNIV_LM_CTL_SUPER (1<<21) /* supervisor AM */
430 # define UNIV_LM_CTL_USER (1<<20) /* user AM */
431 # define UNIV_LM_CTL_VAS_A16 (0<<16) /* A16 */
432 # define UNIV_LM_CTL_VAS_A24 (1<<16) /* A16 */
433 # define UNIV_LM_CTL_VAS_A32 (2<<16) /* A16 */
434
435 /* Location Monitor base address */
436 #define UNIV_REGOFF_LM_BS 0xf68
437
438 /* VMEbus register access image control register */
439 #define UNIV_REGOFF_VRAI_CTL 0xf70
440 # define UNIV_VRAI_CTL_EN (1<<31) /* image enable */
441 # define UNIV_VRAI_CTL_PGM (1<<23) /* program AM */
442 # define UNIV_VRAI_CTL_DATA (1<<22) /* data AM */
443 # define UNIV_VRAI_CTL_SUPER (1<<21) /* supervisor AM */
444 # define UNIV_VRAI_CTL_USER (1<<20) /* user AM */
445 # define UNIV_VRAI_CTL_VAS_A16 (0<<16) /* A16 */
446 # define UNIV_VRAI_CTL_VAS_A24 (1<<16) /* A14 */
447 # define UNIV_VRAI_CTL_VAS_A32 (2<<16) /* A32 */
448 # define UNIV_VRAI_CTL_VAS_MSK (3<<16)
449
450 /* VMEbus register acces image base address register */
451 #define UNIV_REGOFF_VRAI_BS 0xf74
452
453 /* VMEbus CSR control register */
454 #define UNIV_REGOFF_VCSR_CTL 0xf80
455 # define UNIV_VCSR_CTL_EN (1<<31) /* image enable */
456 # define UNIV_VCSR_CTL_LAS_PCI_MEM (0<<0) /* pci mem space */
457 # define UNIV_VCSR_CTL_LAS_PCI_IO (1<<0) /* pci IO space */
458 # define UNIV_VCSR_CTL_LAS_PCI_CFG (2<<0) /* pci config space */
459
460 /* VMEbus CSR translation offset */
461 #define UNIV_REGOFF_VCSR_TO 0xf84
462
463 /* VMEbus AM code error log */
464 #define UNIV_REGOFF_V_AMERR 0xf88
465 # define UNIV_V_AMERR_AMERR(reg) (((reg)>>26)&0x3f) /* extract error log code */
466 # define UNIV_V_AMERR_IACK (1<<25) /* VMEbus IACK signal */
467 # define UNIV_V_AMERR_M_ERR (1<<24) /* multiple errors occurred */
468 # define UNIV_V_AMERR_V_STAT (1<<23) /* log status valid (write 1 to clear) */
469
470 /* VMEbus address error log */
471 #define UNIV_REGOFF_VAERR 0xf8c /* address of fault address (if MERR_V_STAT valid) */
472
473 /* VMEbus CSR bit clear register */
474 #define UNIV_REGOFF_VCSR_CLR 0xff4
475 # define UNIV_VCSR_CLR_RESET (1<<31) /* read/negate LRST (can only be written from VME bus */
476 # define UNIV_VCSR_CLR_SYSFAIL (1<<30) /* read/negate SYSFAIL */
477 # define UNIV_VCSR_CLR_FAIL (1<<29) /* read: board has failed */
478
479 /* VMEbus CSR bit set register */
480 #define UNIV_REGOFF_VCSR_SET (0xff8)
481 # define UNIV_VCSR_SET_RESET (1<<31) /* read/assert LRST (can only be written from VME bus */
482 # define UNIV_VCSR_SET_SYSFAIL (1<<30) /* read/assert SYSFAIL */
483 # define UNIV_VCSR_SET_FAIL (1<<29) /* read: board has failed */
484
485 /* VMEbus CSR base address register */
486 #define UNIV_REGOFF_VCSR_BS 0xffc
487 #define UNIV_VCSR_BS_MASK (0xf8000000)
488
489 /* offset of universe registers in VME-CSR slot */
490 #define UNIV_CSR_OFFSET 0x7f000
491
492 #ifdef __cplusplus
493 extern "C" {
494 #endif
495
496 /* base address and IRQ line of 1st universe bridge
497  * NOTE: vmeUniverseInit() must be called before
498  * these may be used.
499  */
500 extern volatile LERegister *vmeUniverse0BaseAddr;
501 extern int vmeUniverse0PciIrqLine;
502
503
504 /* Initialize the driver */
505 int
506 vmeUniverseInit(void);
507
508 /* setup the universe chip, i.e. disable most of its
509  * mappings, reset interrupts etc.
510  */
511 void
512 vmeUniverseReset(void);
513
514 /* avoid pulling stdio.h into this header.
515  * Applications that want a declaration of the
516  * following routines should
517  * #include <stdio.h>
518  * #define _VME_UNIVERSE_DECLARE_SHOW_ROUTINES
519  * #include <vmeUniverse.h>
520  */
521 /* print the current configuration of all master ports to
522  * f (stderr if NULL)
523  */
524 void
525 vmeUniverseMasterPortsShow(FILE *f);
526
527 /* print the current configuration of all slave ports to
528  * f (stderr if NULL)
529  */
530 void
531 vmeUniverseSlavePortsShow(FILE *f);
532
533 /* disable all master or slave ports, respectively */
534 void
535 vmeUniverseDisableAllMasters(void);
536
537 void
538 vmeUniverseDisableAllSlaves(void);
539
540 /* configure a master port
541  *
542  * port: port number 0..3 (0..7 for a UniverseII)
543  *
544  * address_space: vxWorks compliant addressing mode identifier
545  * (see vme.h). The most important are:
546  * 0x0d - A32, Sup, Data
547  * 0x3d - A24, Sup, Data
548  * 0x2d - A16, Sup, Data
549  * additionally, the value 0 is accepted; it will
550  * disable this port.
551  * vme_address: address on the vme_bus of this port.
552  * local_address: address on the pci_bus of this port.
553  * length: size of this port.
554  *
555  * NOTE: the addresses and length parameters must be aligned on a
556  * 2^16 byte (0x10000) boundary, except for port 4 (only available
557  * on a UniverseII), where the alignment can be 4k (4096).
558  *
559  * RETURNS: 0 on success, -1 on failure. Error messages printed to stderr.
560  */
561
562 int
563 vmeUniverseMasterPortCfg(
564  unsigned long port,
565  unsigned long address_space,
566  unsigned long vme_address,
567  unsigned long local_address,
568  unsigned long length);
569
570 /* translate an address through the bridge
571  *
572  * vmeUniverseXlateAddr(0,0,as,addr,&result)
573  * yields a VME a address that reflects
574  * a local memory location as seen from the VME bus through the universe
575  * VME slave.
576  *
577  * likewise does vmeUniverseXlateAddr(1,0,as,addr,&result)
578  * translate a VME bus addr (through the VME master) to the
579  * PCI side of the bridge.
580  *
581  * a valid address space modifier must be specified.
582  *
583  * The 'reverse' parameter may be used to find a reverse
584  * mapping, i.e. the pci address in a master window can be
585  * found if the respective vme address is known etc.
586  *
587  * RETURNS: translated address in *pbusAdrs / *plocalAdrs
588  *
589  * 0: success
590  * -1: address/modifier not found in any bridge port
591  * -2: invalid modifier
592  */
593 int
594 vmeUniverseXlateAddr(
595  int master, /* look in the master windows */
596  int reverse, /* reverse mapping; for masters: map local to VME */
597  unsigned long as, /* address space */
598  unsigned long addr, /* address to look up */
599  unsigned long *paOut/* where to put result */
600  );
601
602 /* configure a VME slave (PCI master) port */
603 int
604 vmeUniverseSlavePortCfg(
605  unsigned long port,
606  unsigned long address_space,
607  unsigned long vme_address,
608  unsigned long local_address,
609  unsigned long length);
610
611 /****** NOTE: USE OF vmeUniverseStartDMA IS DEPRECATED *********
612  ****** USE API IN VMEDMA.h/vmeUniverseDMA.h INSTEAD *********/
613
614 /* start a (direct, not linked) DMA transfer
615  *
616  * NOTE: DCTL and DGCS must be set up
617  * prior to calling this routine
618  */
619 int
620 vmeUniverseStartDMA(
621  unsigned long local_addr,
622  unsigned long vme_addr,
623  unsigned long count); /* DEPRECATED */
624
625 int
626 vmeUniverseStartDMAXX(
627  volatile LERegister *ubase,
628  unsigned long local_addr,
629  unsigned long vme_addr,
630  unsigned long count); /* DEPRECATED */
631
632
633 /* read a register in PCI memory space
634  * (offset being one of the declared constants)
635  */
636 unsigned long
637 vmeUniverseReadReg(unsigned long offset);
638
639 /* write a register in PCI memory space */
640 void
641 vmeUniverseWriteReg(unsigned long value, unsigned long offset);
642
643 /* convert an array of unsigned long values to LE (as needed
644  * when the universe reads e.g. DMA descriptors from PCI)
645  */
646 void
647 vmeUniverseCvtToLE(unsigned long *ptr, unsigned long num);
648
649 /* reset the VME bus */
650 void
651 vmeUniverseResetBus(void);
652
653 /* The ...XX routines take the universe base address as an additional
654  * argument - this allows for programming secondary devices.
655  */
656
657 unsigned long
658 vmeUniverseReadRegXX(volatile LERegister *ubase, unsigned long offset);
659
660 void
661 vmeUniverseWriteRegXX(volatile LERegister *ubase, unsigned long value, unsigned long offset);
662
663 int
664 vmeUniverseXlateAddrXX(
665  volatile LERegister *ubase,
666  int master,
667  int reverse,
668  unsigned long as,
669  unsigned long addr,
670  unsigned long *paOut
671  );
672
673 int
674 vmeUniverseMasterPortCfgXX(
675  volatile LERegister *ubase,
676  unsigned long port,
677  unsigned long address_space,
678  unsigned long vme_address,
679  unsigned long local_address,
680  unsigned long length);
681
682 int
683 vmeUniverseSlavePortCfgXX(
684  volatile LERegister *ubase,
685  unsigned long port,
686  unsigned long address_space,
687  unsigned long vme_address,
688  unsigned long local_address,
689  unsigned long length);
690
691 void
692 vmeUniverseDisableAllMastersXX(volatile LERegister *ubase);
693
694 void
695 vmeUniverseDisableAllSlavesXX(volatile LERegister *ubase);
696
697 /* print the current configuration of all master ports to
698  * f (stderr if NULL)
699  */
700 void
701 vmeUniverseMasterPortsShowXX(
702  volatile LERegister *ubase,FILE *f);
703
704 /* print the current configuration of all slave ports to
705  * f (stderr if NULL)
706  */
707 void
708 vmeUniverseSlavePortsShowXX(
709  volatile LERegister *ubase,FILE *f);
710
711 /* Raise a VME Interrupt at 'level' and respond with 'vector' to a
712  * handler on the VME bus. (The handler could be a different board
713  * or the universe itself - [only works with universe II]).
714  *
715  * Note that you could install a interrupt handler at UNIV_VME_SW_IACK_INT_VEC
716  * to be notified of an IACK cycle having completed.
717  *
718  * This routine is mainly FOR TESTING.
719  *
720  * NOTES:
721  * - several registers are modified: the vector is written to VINT_STATID
722  * and (universe 1 chip only) the level is written to the SW_INT bits
723  * int VINT_MAP1
724  * - NO MUTUAL EXCLUSION PROTECTION (reads VINT_EN, modifies then writes back).
725  * If several users need access to VINT_EN and/or VINT_STATID (and VINT_MAP1
726  * on the universe 1) it is their responsibility to serialize access.
727  *
728  * Arguments:
729  * 'level': interrupt level, 1..7
730  * 'vector': vector number (0..254) that the universe puts on the bus in response to
731  * an IACK cycle. NOTE: the vector number *must be even* (hardware restriction
732  * of the universe -- it always clears the LSB when the interrupter is
733  * a software interrupt).
734  *
735  * RETURNS:
736  * 0: Success
737  * -1: Invalid argument (level not 1..7, vector odd or >= 256)
738  * -2: Interrupt 'level' already asserted (maybe nobody handles it).
739  * You can manually clear it be writing the respective bit in
740  * VINT_STAT. Make sure really nobody responds to avoid spurious
741  * interrupts (consult universe docs).
742  */
743
744 int
745 vmeUniverseIntRaiseXX(volatile LERegister *base, int level, unsigned vector);
746
747 int
748 vmeUniverseIntRaise(int level, unsigned vector);
749
750 /* Map internal register block to VME.
751  *
752  * This routine is intended for BSP implementors. The registers can be
753  * made accessible from VME so that the interrupt handler can flush the
754  * bridge FIFO (see below). The preferred method is by accessing VME CSR,
755  * though, if these are mapped [and the BSP provides an outbound window].
756  * On the universe we can also disable posted writes in the 'ordinary'
757  * outbound windows.
758  *
759  * vme_base: VME address where the universe registers (4k) can be mapped.
760  * This VME address must fall into a range covered by
761  * any pre-configured outbound window.
762  * address_space: The desired VME address space.
763  * (all of SUP/USR/PGM/DATA are always accepted).
764  *
765  * See NOTES [vmeUniverseInstallIrqMgrAlt()] below for further information.
766  *
767  * RETURNS: 0 on success, nonzero on error. It is not possible (and results
768  * in a non-zero return code) to change the CRG VME address after
769  * initializing the interrupt manager as it uses the CRG.
770  */
771 int
772 vmeUniverseMapCRGXX(volatile LERegister *base, unsigned long vme_base, unsigned long address_space);
773
774 int
775 vmeUniverseMapCRG(unsigned long vme_base, unsigned long address_space);
776
777
778 #ifdef __rtems__
779
780 /* VME Interrupt Handler functionality */
781
782 /* we dont use the current RTEMS/BSP interrupt API for the
783  * following reasons:
784  *
785  * - RTEMS/BSP API does not pass an argument to the ISR :-( :-(
786  * - no separate vector space for VME vectors. Some vectors would
787  * have to overlap with existing PCI/ISA vectors.
788  * - RTEMS/BSP API allocates a structure for every possible vector
789  * - the irq_on(), irq_off() functions add more bloat than helping.
790  * They are (currently) only used by the framework to disable
791  * interrupts at the device level before removing a handler
792  * and to enable interrupts after installing a handler.
793  * These operations may as well be done by the driver itself.
794  *
795  * Hence, we maintain our own (VME) handler table and hook our PCI
796  * handler into the standard RTEMS/BSP environment. Our handler then
797  * dispatches VME interrupts.
798  */
799
800 typedef void (*VmeUniverseISR) (void *usrArg, unsigned long vector);
801
802 /* use these special vectors to connect a handler to the
803  * universe specific interrupts (such as "DMA done",
804  * VOWN, error irqs etc.)
805  * NOTE: The wrapper clears all status LINT bits (except
806  * for regular VME irqs). Also note that it is the user's
807  * responsibility to enable the necessary interrupts in
808  * LINT_EN
809  *
810  * !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
811  * DO NOT CHANGE THE ORDER OF THESE VECTORS - THE DRIVER
812  * DEPENDS ON IT
813  * !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
814  *
815  */
816 #define UNIV_VOWN_INT_VEC 256
817 #define UNIV_DMA_INT_VEC 257
818 #define UNIV_LERR_INT_VEC 258
819 #define UNIV_VERR_INT_VEC 259
820 /* 260 is reserved */
821 #define UNIV_VME_SW_IACK_INT_VEC 261
822 #define UNIV_PCI_SW_INT_VEC 262
823 #define UNIV_SYSFAIL_INT_VEC 263
824 #define UNIV_ACFAIL_INT_VEC 264
825 #define UNIV_MBOX0_INT_VEC 265
826 #define UNIV_MBOX1_INT_VEC 266
827 #define UNIV_MBOX2_INT_VEC 267
828 #define UNIV_MBOX3_INT_VEC 268
829 #define UNIV_LM0_INT_VEC 269
830 #define UNIV_LM1_INT_VEC 270
831 #define UNIV_LM2_INT_VEC 271
832 #define UNIV_LM3_INT_VEC 272
833
834 #define UNIV_NUM_INT_VECS 273
835
836
837 /* install a handler for a VME vector
838  * RETURNS 0 on success, nonzero on failure.
839  */
840 int
841 vmeUniverseInstallISR(unsigned long vector, VmeUniverseISR handler, void *usrArg);
842
843 /* remove a handler for a VME vector. The vector and usrArg parameters
844  * must match the respective parameters used when installing the handler.
845  * RETURNS 0 on success, nonzero on failure.
846  */
847 int
848 vmeUniverseRemoveISR(unsigned long vector, VmeUniverseISR handler, void *usrArg);
849
850 /* query for the currently installed ISR and usr parameter at a given vector
851  * RETURNS: ISR or 0 (vector too big or no ISR installed)
852  */
853 VmeUniverseISR
854 vmeUniverseISRGet(unsigned long vector, void **parg);
855
856 /* utility routines to enable/disable a VME IRQ level.
857  *
858  * To enable/disable the internal interrupt sources (special vectors above)
859  * pass a vector argument > 255.
860  *
861  * RETURNS 0 on success, nonzero on failure
862  */
863 int
864 vmeUniverseIntEnable(unsigned int level);
865 int
866 vmeUniverseIntDisable(unsigned int level);
867
868 /* Check if an interrupt level or internal source is enabled:
869  *
870  * 'level': VME level 1..7 or internal special vector > 255
871  *
872  * RETURNS: value > 0 if interrupt is currently enabled,
873  * zero if interrupt is currently disabled,
874  * -1 on error (invalid argument).
875  */
876 int
877 vmeUniverseIntIsEnabled(unsigned int level);
878
879
880 /* Change the routing of IRQ 'level' to 'pin'.
881  * If the BSP connects more than one of the eight
882  * physical interrupt lines from the universe to
883  * the board's PIC then you may change the physical
884  * line a given 'level' is using. By default,
885  * all 7 VME levels use the first wire (pin==0) and
886  * all internal sources use the (optional) second
887  * wire (pin==1).
888  * This feature is useful if you want to make use of
889  * different hardware priorities of the PIC. Let's
890  * say you want to give IRQ level 7 the highest priority.
891  * You could then give 'pin 0' a higher priority (at the
892  * PIC) and 'pin 1' a lower priority and issue.
893  *
894  * for ( i=1; i<7; i++ ) vmeUniverseIntRoute(i, 1);
895  *
896  * PARAMETERS:
897  * 'level' : VME interrupt level '1..7' or one of
898  * the internal sources. Pass the internal
899  * source's vector number (>=256).
900  * 'pin' : a value of 0 routes the requested IRQ to
901  * the first line registered with the manager
902  * (vmeIrqUnivOut parameter), a value of 1
903  * routes it to the alternate wire
904  * (specialIrqUnivOut)
905  * RETURNS: 0 on success, nonzero on error (invalid arguments)
906  *
907  * NOTES: - DONT change the universe 'map' registers
908  * directly. The driver caches routing internally.
909  * - support for the 'specialIrqUnivOut' wire is
910  * board dependent. If the board only provides
911  * a single physical wire from the universe to
912  * the PIC then the feature might not be available.
913  */
914 int
915 vmeUniverseIntRoute(unsigned int level, unsigned int pin);
916
917 /* Loopback test of the VME interrupt subsystem.
918  * - installs ISRs on 'vector' and on UNIV_VME_SW_IACK_INT_VEC
919  * - asserts VME interrupt 'level'
920  * - waits for both interrupts: 'ordinary' VME interrupt of 'level' and
921  * IACK completion interrupt ('special' vector UNIV_VME_SW_IACK_INT_VEC).
922  *
923  * NOTES:
924  * - make sure no other handler responds to 'level'.
925  * - make sure no ISR is installed on both vectors yet.
926  * - ISRs installed by this routine are removed after completion.
927  * - no concurrent access protection of all involved resources
928  * (levels, vectors and registers [see vmeUniverseIntRaise()])
929  * is implemented.
930  * - this routine is intended for TESTING (when implementing new BSPs etc.).
931  * - one RTEMS message queue is temporarily used (created/deleted).
932  * - the universe 1 always yields a zero vector (VIRQx_STATID) in response
933  * to a self-generated VME interrupt. As a workaround, the routine
934  * only accepts a zero vector when running on a universe 1.
935  *
936  * RETURNS:
937  * 0: Success.
938  * -1: Invalid arguments.
939  * 1: Test failed (outstanding interrupts).
940  * rtems_status_code: Failed RTEMS directive.
941  */
942 int
943 vmeUniverseIntLoopbackTst(int level, unsigned vector);
944
945
946 /* the universe interrupt handler is capable of routing all sorts of
947  * (VME) interrupts to 8 different lines (some of) which may be hooked up
948  * in a (board specific) way to a PIC.
949  *
950  * This driver only supports at most two lines. By default, it routes the
951  * 7 VME interrupts to the main line and optionally, it routes the 'special'
952  * interrupts generated by the universe itself (DMA done, VOWN etc.)
953  * to a second line. If no second line is available, all IRQs are routed
954  * to the main line.
955  *
956  * The routing of interrupts to the two lines can be modified (using
957  * the vmeUniverseIntRoute() call - see above - i.e., to make use of
958  * different hardware priorities of the two pins.
959  *
960  * Because the driver has no way to figure out which lines are actually
961  * wired to the PIC, this information has to be provided when installing
962  * the manager.
963  *
964  * Hence the manager sets up routing VME interrupts to 1 or 2 universe
965  * OUTPUTS. However, it must also be told to which PIC INPUTS they
966  * are wired.
967  * Optionally, the first PIC input line can be read from PCI config space
968  * but the second must be passed to this routine. Note that the info read
969  * from PCI config space is wrong for many boards!
970  *
971  * PARAMETERS:
972  * vmeIrqUnivOut: to which output pin (of the universe) should the 7
973  * VME irq levels be routed.
974  * vmeIrqPicLine: specifies to which PIC input the 'main' output is
975  * wired. If passed a value < 0, the driver reads this
976  * information from PCI config space ("IRQ line").
977  * specialIrqUnivOut: to which output pin (of the universe) should the
978  * internally irqs be routed. Use 'vmeIRQunivOut'
979  * if < 0.
980  * specialIrqPicLine: specifies to which PIC input the 'special' output
981  * pin is wired. The wiring of the 'vmeIRQunivOut' to
982  * the PIC is determined by reading PCI config space.
983  *
984  * RETURNS: 0 on success, -1 on failure.
985  *
986  */
987
988 /* This routine is outside of the __INSIDE_RTEMS_BSP__ test for bwrds compatibility ONLY */
989 int
990 vmeUniverseInstallIrqMgr(int vmeIrqUnivOut,
991  int vmeIrqPicLine,
992  int specialIrqUnivOut,
993  int specialIrqPicLine);
994
995
996 #if defined(__INSIDE_RTEMS_BSP__)
997 #include <stdarg.h>
998
999 /* up to 4 universe outputs are now supported by this alternate
1000  * entry point.
1001  * Terminate the vararg list (uni_pin/pic_pin pairs) with a
1002  * '-1' uni_pin.
1003  * E.g., the old interface is now just a wrapper to
1004  * vmeUniverseInstallIrqMgrAlt(0, vmeUnivOut, vmePicLint, specUnivOut, specPicLine, -1);
1005  *
1006  * The 'IRQ_MGR_SHARED' flag uses the BSP_install_rtems_shared_irq_handler()
1007  * API. CAVEAT: shared interrupts need RTEMS workspace, i.e., the
1008  * VME interrupt manager can only be installed *after workspace is initialized*
1009  * if 'shared' is nonzero (i.e., *not* from bspstart()).
1010  *
1011  * If 'PW_WORKAROUND' flag is set then the interrupt manager will try to
1012  * find a way to access the control registers from VME so that the universe's
1013  * posted write FIFO can be flushed after the user ISR returns:
1014  *
1015  * The installation routine looks first for CSR registers in CSR space (this
1016  * requires:
1017  * - a VME64 crate with autoid or geographical addressing
1018  * - the firmware or BSP to figure out the slot number and program the CSR base
1019  * in the universe.
1020  * - the BSP to open an outbound window to CSR space.
1021  *
1022  * If CSR registers cannot be found then the installation routine looks for CRG registers:
1023  * - BSP must map CRG on VME
1024  * - CRG must be visible in outbound window
1025  * CAVEAT: multiple boards with same BSP on single backplane must not map their CRG
1026  * to the same address!
1027  */
1028
1029 #define VMEUNIVERSE_IRQ_MGR_FLAG_SHARED 1 /* use shared interrupts */
1030 #define VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND 2 /* use shared interrupts */
1031
1032 int
1033 vmeUniverseInstallIrqMgrAlt(int flags, int uni_pin0, int pic_pin0, ...);
1034
1035 int
1036 vmeUniverseInstallIrqMgrVa(int flags, int uni_pin0, int pic_pin0, va_list ap);
1037
1038 #endif /* __INSIDE_RTEMS_BSP__ */
1039 #endif /* __rtems__ */
1040
1041 #ifdef __cplusplus
1042 }
1043 #endif
1044
1045 #endif
Definition: jffs2.h:95
vxworks compatible addressing modes
Definition: vmeUniverse.h:88
