RTEMS  5.1
vc_defines.h
1
10 /*
11  * Copyright (c) 2015 Yang Qiao
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  *
16  * http://www.rtems.org/license/LICENSE
17  *
18  */
19
20 #ifndef LIBBSP_ARM_RASPBERRYPI_VC_DEFINES_H
21 #define LIBBSP_ARM_RASPBERRYPI_VC_DEFINES_H
22
23 #include <string.h>
24
41 #define BCM2835_MBOX_BUF_CODE_PROCESS_REQUEST 0x00000000
42 #define BCM2835_MBOX_BUF_CODE_REQUEST_SUCCEED 0x80000000
43 #define BCM2835_MBOX_BUF_CODE_REQUEST_PARSING_ERROR 0x80000001
44 #define BCM2835_MBOX_TAG_VAL_LEN_REQUEST 0x00000000
45 #define BCM2835_MBOX_TAG_VAL_LEN_RESPONSE 0x80000000
46
55 typedef struct {
62  uint32_t buf_size;
63
71  uint32_t buf_code;
73
82 typedef struct {
86  uint32_t tag;
90  uint32_t val_buf_size;
96  uint32_t val_len;
98
99 #define BCM2835_MBOX_TAG_REPLY_IS_SET( _t_ ) \
100  ( ( _t_ )->tag_hdr.val_len & 0x80000000 )
101
102 #define BCM2835_MBOX_INIT_BUF( _m_ ) { \
103  memset( ( _m_ ), 0, sizeof( *( _m_ ) ) ); \
104  ( _m_ )->hdr.buf_size = (void *)&(( _m_ )->end_tag) + 4 - (void *)( _m_ ); \
105  ( _m_ )->hdr.buf_code = BCM2835_MBOX_BUF_CODE_PROCESS_REQUEST; \
106  ( _m_ )->end_tag = 0; \
107 }
108
109 #define BCM2835_MBOX_INIT_TAG( _t_, _id_ ) { \
110  ( _t_ )->tag_hdr.tag = _id_; \
111  ( _t_ )->tag_hdr.val_buf_size = sizeof( ( _t_ )->body ); \
112  ( _t_ )->tag_hdr.val_len = sizeof( ( _t_ )->body.req ); \
113 }
114
115 #define BCM2835_MBOX_INIT_TAG_NO_REQ( _t_, _id_ ) { \
116  ( _t_ )->tag_hdr.tag = _id_; \
117  ( _t_ )->tag_hdr.val_buf_size = sizeof( ( _t_ )->body ); \
118  ( _t_ )->tag_hdr.val_len = 0; \
119 }
120
121 /*
122  * Mailbox buffers has to be aligned to 16 bytes because
123  * 4 LSB bits of the BCM2835_MBOX_WRITE and BCM2835_MBOX_READ
124  * registers are used to pass channel number.
125  *
126  * But there is another requirement for buffer allocation
127  * as well when interface is called after cache is enabled.
128  * The buffer should not share cache line with another variable
129  * which can be updated during data exchange with VideoCore.
130  * If cache is filled to satisfy another variable update
131  * during VideoCore output is stored into main memory then
132  * part of received data can be lost.
133  *
134  * Cache line length is 64 bytes for RPi2 Cortex-A7 data cache
135  * so align buffers to this value.
136  */
137 #define BCM2835_MBOX_BUF_ALIGN_ATTRIBUTE __attribute__( ( aligned( 64 ) ) )
138
139 /* Video Core */
140 #define BCM2835_MAILBOX_TAG_FIRMWARE_REVISION 0x00000001
141 typedef struct {
142  bcm2835_mbox_tag_hdr tag_hdr;
143  union {
144  struct {
145  } req;
146  struct {
147  uint32_t rev;
148  } resp;
149  } body;
151
152 /* Hardware */
153 #define BCM2835_MAILBOX_TAG_GET_BOARD_MODEL 0x00010001
154 #define BCM2835_MAILBOX_TAG_GET_BOARD_VERSION 0x00010002
155 typedef struct {
156  bcm2835_mbox_tag_hdr tag_hdr;
157  union {
158  struct {
159  } req;
160  struct {
161  uint32_t spec;
162  } resp;
163  } body;
165
166 #if (BSP_IS_RPI2 == 1)
167 #define BCM2836_MAILBOX_BOARD_V_2_B 0x4
168 #else
169 #define BCM2835_MAILBOX_BOARD_V_B_I2C0_2 0x2
170 #define BCM2835_MAILBOX_BOARD_V_B_I2C0_3 0x3
171 #define BCM2835_MAILBOX_BOARD_V_B_I2C1_4 0x4
172 #define BCM2835_MAILBOX_BOARD_V_B_I2C1_5 0x5
173 #define BCM2835_MAILBOX_BOARD_V_B_I2C1_6 0x6
174 #define BCM2835_MAILBOX_BOARD_V_A_7 0x7
175 #define BCM2835_MAILBOX_BOARD_V_A_8 0x8
176 #define BCM2835_MAILBOX_BOARD_V_A_9 0x9
177 #define BCM2835_MAILBOX_BOARD_V_B_REV2_d 0xd
178 #define BCM2835_MAILBOX_BOARD_V_B_REV2_e 0xe
179 #define BCM2835_MAILBOX_BOARD_V_B_REV2_f 0xf
180 #define BCM2835_MAILBOX_BOARD_V_B_PLUS 0x10
181 #define BCM2835_MAILBOX_BOARD_V_CM 0x11
182 #define BCM2835_MAILBOX_BOARD_V_A_PLUS 0x12
183 #endif
184
185 #define BCM2835_MAILBOX_TAG_GET_BOARD_MAC 0x00010003
186 #define BCM2835_MAILBOX_TAG_GET_BOARD_SERIAL 0x00010004
187 typedef struct {
188  bcm2835_mbox_tag_hdr tag_hdr;
189  union {
190  struct {
191  } req;
192  struct {
193  uint64_t board_serial;
194  } resp;
195  } body;
197
198 #define BCM2835_MAILBOX_TAG_GET_ARM_MEMORY 0x00010005
199 typedef struct {
200  bcm2835_mbox_tag_hdr tag_hdr;
201  union {
202  struct {
203  } req;
204  struct {
205  uint32_t base;
206  uint32_t size;
207  } resp;
208  } body;
210
211 #define BCM2835_MAILBOX_TAG_GET_VC_MEMORY 0x00010006
212 typedef struct {
213  bcm2835_mbox_tag_hdr tag_hdr;
214  union {
215  struct {
216  } req;
217  struct {
218  uint32_t base;
219  uint32_t size;
220  } resp;
221  } body;
223
224 #define BCM2835_MAILBOX_TAG_GET_CLOCKS 0x00010007
225 typedef struct {
226  bcm2835_mbox_tag_hdr tag_hdr;
227  union {
228  struct {
229  uint32_t clock_id;
230  } req;
231  struct {
232  uint32_t clock_id;
233  uint32_t clock_rate;
234  } resp;
235  } body;
237
238 /* Config */
239 #define BCM2835_MAILBOX_TAG_GET_CMD_LINE 0x00050001
240 typedef struct {
241  bcm2835_mbox_tag_hdr tag_hdr;
242  union {
243  struct {
244  } req;
245  struct {
246  uint8_t cmdline[ 1024 ];
247  } resp;
248  } body;
250
251 /* Shared resource management */
252 #define BCM2835_MAILBOX_TAG_GET_DMA_CHANNELS 0x00060001
253
254 /* Power */
255 #define BCM2835_MAILBOX_POWER_UDID_SD_Card 0x00000000
256 #define BCM2835_MAILBOX_POWER_UDID_UART0 0x00000001
257 #define BCM2835_MAILBOX_POWER_UDID_UART1 0x00000002
258 #define BCM2835_MAILBOX_POWER_UDID_USB_HCD 0x00000003
259 #define BCM2835_MAILBOX_POWER_UDID_I2C0 0x00000004
260 #define BCM2835_MAILBOX_POWER_UDID_I2C1 0x00000005
261 #define BCM2835_MAILBOX_POWER_UDID_I2C2 0x00000006
262 #define BCM2835_MAILBOX_POWER_UDID_SPI 0x00000007
263 #define BCM2835_MAILBOX_POWER_UDID_CCP2TX 0x00000008
264
265 #define BCM2835_MAILBOX_TAG_GET_POWER_STATE 0x00020001
266 typedef struct {
267  bcm2835_mbox_tag_hdr tag_hdr;
268  union {
269  struct {
270  uint32_t dev_id;
271  } req;
272  struct {
273  uint32_t dev_id;
274  uint32_t state;
275  } resp;
276  } body;
278
279 #define BCM2835_MAILBOX_POWER_STATE_RESP_ON (1 << 0)
280 #define BCM2835_MAILBOX_POWER_STATE_RESP_NODEV (1 << 1)
281
282 #define BCM2835_MAILBOX_TAG_GET_TIMING 0x00020002
283 #define BCM2835_MAILBOX_TAG_SET_POWER_STATE 0x00028001
284 typedef struct {
285  bcm2835_mbox_tag_hdr tag_hdr;
286  union {
287  struct {
288  uint32_t dev_id;
289  uint32_t state;
290  } req;
291  struct {
292  uint32_t dev_id;
293  uint32_t state;
294  } resp;
295  } body;
297
298 #ifndef BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON
299 /* Value is defined as a part of public VideoCore API */
300 #define BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON (1 << 0)
301 #define BCM2835_MAILBOX_SET_POWER_STATE_REQ_WAIT (1 << 1)
302 #endif
303
304 /* Clocks */
305 #define BCM2835_MAILBOX_UCID_CLOCK_RESERVED 0x000000000
306 #define BCM2835_MAILBOX_UCID_CLOCK_EMMC 0x000000001
307 #define BCM2835_MAILBOX_UCID_CLOCK_UART 0x000000002
308 #define BCM2835_MAILBOX_UCID_CLOCK_ARM 0x000000003
309 #define BCM2835_MAILBOX_UCID_CLOCK_CORE 0x000000004
310 #define BCM2835_MAILBOX_UCID_CLOCK_V3D 0x000000005
311 #define BCM2835_MAILBOX_UCID_CLOCK_H264 0x000000006
312 #define BCM2835_MAILBOX_UCID_CLOCK_ISP 0x000000007
313 #define BCM2835_MAILBOX_UCID_CLOCK_SDRAM 0x000000008
314 #define BCM2835_MAILBOX_UCID_CLOCK_PIXEL 0x000000009
315 #define BCM2835_MAILBOX_UCID_CLOCK_PWM 0x00000000a
316
317 #define BCM2835_MAILBOX_TAG_GET_CLOCK_STATE 0x00030001
318 #define BCM2835_MAILBOX_TAG_SET_CLOCK_STATE 0x00038001
319 #define BCM2835_MAILBOX_TAG_GET_CLOCK_RATE 0x00030002
320 #define BCM2835_MAILBOX_TAG_SET_CLOCK_RATE 0x00038002
321 #define BCM2835_MAILBOX_TAG_GET_MAX_CLOCK_RATE 0x00030004
322 #define BCM2835_MAILBOX_TAG_GET_MIN_CLOCK_RATE 0x00030007
323 #define BCM2835_MAILBOX_TAG_GET_TRUBO 0x00030009
324 #define BCM2835_MAILBOX_TAG_SET_TURBO 0x00038009
325
326 #define BCM2835_MAILBOX_TAG_GET_DOMAIN_STATE 0x00030030
327 #define BCM2835_MAILBOX_TAG_SET_DOMAIN_STATE 0x00038030
328
329 /* Voltage */
330 #define BCM2835_MAILBOX_VOLTAGE_RESERVED_UVID 0x000000000
331 #define BCM2835_MAILBOX_VOLTAGE_CORE_UVID 0x000000001
332 #define BCM2835_MAILBOX_VOLTAGE_SDRAM_C_UVID 0x000000002
333 #define BCM2835_MAILBOX_VOLTAGE_SDRAM_P_UVID 0x000000003
334 #define BCM2835_MAILBOX_VOLTAGE_SDRAM_I_UVID 0x000000004
335
336 #define BCM2835_MAILBOX_TAG_GET_VOLTAGE 0x00030003
337 #define BCM2835_MAILBOX_TAG_SET_VOLTAGE 0x00038003
338 #define BCM2835_MAILBOX_TAG_GET_MAX_VOLTAGE 0x00030005
339 #define BCM2835_MAILBOX_TAG_GET_MIN_VOLTAGE 0x00030008
340 #define BCM2835_MAILBOX_TAG_GET_TEMPERATURE 0x00030006
341 #define BCM2835_MAILBOX_TAG_GET_MAX_TEMPERATURE 0x0003000a
342
343 /* Memory */
344 #define BCM2835_MAILBOX_TAG_ALLOCATE_MEMORY 0x0003000c
345 #define BCM2835_MAILBOX_TAG_LOCK_MEMORY 0x0003000d
346 #define BCM2835_MAILBOX_TAG_UNLOCK_MEMORY 0x0003000e
347 #define BCM2835_MAILBOX_TAG_RELEASE_MEMORY 0x0003000f
348 #define BCM2835_MAILBOX_TAG_EXECUTE_CODE 0x00030010
349 #define BCM2835_MAILBOX_TAG_GET_DISPMANX_RESOURCE_MEM_HANDLE 0x00030014
350
351 #define BCM2835_MAILBOX_TAG_GET_EDID_BLOCK 0x00030020
352
353 /* Framebuffer */
354 #define BCM2835_MAILBOX_TAG_ALLOCATE_BUFFER 0x00040001
355 typedef struct {
356  bcm2835_mbox_tag_hdr tag_hdr;
357  union {
358  struct {
359  uint32_t align;
360  } req;
361  struct {
362  uint32_t base;
363  uint32_t size;
364  } resp;
365  } body;
367
368 #define BCM2835_MAILBOX_TAG_RELEASE_BUFFER 0x00048001
369
370 #define BCM2835_MAILBOX_TAG_BLANK_SCREEN 0x00040002
371
372 #define BCM2835_MAILBOX_TAG_GET_DISPLAY_SIZE 0x00040003
373 #define BCM2835_MAILBOX_TAG_TEST_DISPLAY_SIZE 0x00044003
374 #define BCM2835_MAILBOX_TAG_SET_DISPLAY_SIZE 0x00048003
375 typedef struct {
376  bcm2835_mbox_tag_hdr tag_hdr;
377  union {
378  struct {
379  uint32_t width;
380  uint32_t height;
381  } req;
382  struct {
383  uint32_t width;
384  uint32_t height;
385  } resp;
386  } body;
388
389 #define BCM2835_MAILBOX_TAG_GET_VIRTUAL_SIZE 0x00040004
390 #define BCM2835_MAILBOX_TAG_TEST_VIRTUAL_SIZE 0x00044004
391 #define BCM2835_MAILBOX_TAG_SET_VIRTUAL_SIZE 0x00048004
392 typedef struct {
393  bcm2835_mbox_tag_hdr tag_hdr;
394  union {
395  struct {
396  uint32_t vwidth;
397  uint32_t vheight;
398  } req;
399  struct {
400  uint32_t vwidth;
401  uint32_t vheight;
402  } resp;
403  } body;
405
406 #define BCM2835_MAILBOX_TAG_GET_DEPTH 0x00040005
407 #define BCM2835_MAILBOX_TAG_TEST_DEPTH 0x00044005
408 #define BCM2835_MAILBOX_TAG_SET_DEPTH 0x00048005
409 typedef struct {
410  bcm2835_mbox_tag_hdr tag_hdr;
411  union {
412  struct {
413  uint32_t depth;
414  } req;
415  struct {
416  uint32_t depth;
417  } resp;
418  } body;
420
421 #define BCM2835_MAILBOX_TAG_GET_PIXEL_ORDER 0x00040006
422 #define BCM2835_MAILBOX_TAG_TEST_PIXEL_ORDER 0x00044006
423 #define BCM2835_MAILBOX_TAG_SET_PIXEL_ORDER 0x00048006
424
425 #define BCM2835_MAILBOX_PIXEL_ORDER_BGR 0
426 #define BCM2835_MAILBOX_PIXEL_ORDER_RGB 1
427 typedef struct {
428  bcm2835_mbox_tag_hdr tag_hdr;
429  union {
430  struct {
431  uint32_t pixel_order;
432  } req;
433  struct {
434  uint32_t pixel_order;
435  } resp;
436  } body;
438
439 #define BCM2835_MAILBOX_TAG_GET_ALPHA_MODE 0x00040007
440 #define BCM2835_MAILBOX_TAG_TEST_ALPHA_MODE 0x00044007
441 #define BCM2835_MAILBOX_TAG_SET_ALPHA_MODE 0x00048007
442 typedef struct {
443  bcm2835_mbox_tag_hdr tag_hdr;
444  union {
445  struct {
446  uint32_t alpha_mode;
447  } req;
448  struct {
449  uint32_t alpha_mode;
450  } resp;
451  } body;
453
454 #define BCM2835_MAILBOX_ALPHA_MODE_0_OPAQUE 0
455 #define BCM2835_MAILBOX_ALPHA_MODE_0_TRANSPARENT 1
456 #define BCM2835_MAILBOX_ALPHA_MODE_IGNORED 2
457
458 #define BCM2835_MAILBOX_TAG_GET_PITCH 0x00040008
459 typedef struct {
460  bcm2835_mbox_tag_hdr tag_hdr;
461  union {
462  struct {
463  } req;
464  struct {
465  uint32_t pitch;
466  } resp;
467  } body;
469
470 #define BCM2835_MAILBOX_TAG_GET_VIRTUAL_OFFSET 0x00040009
471 #define BCM2835_MAILBOX_TAG_TEST_VIRTUAL_OFFSET 0x00044009
472 #define BCM2835_MAILBOX_TAG_SET_VIRTUAL_OFFSET 0x00048009
473 typedef struct {
474  bcm2835_mbox_tag_hdr tag_hdr;
475  union {
476  struct {
477  uint32_t voffset_x;
478  uint32_t voffset_y;
479  } req;
480  struct {
481  uint32_t voffset_x;
482  uint32_t voffset_y;
483  } resp;
484  } body;
486
487 #define BCM2835_MAILBOX_TAG_GET_OVERSCAN 0x0004000a
488 #define BCM2835_MAILBOX_TAG_TEST_OVERSCAN 0x0004400a
489 #define BCM2835_MAILBOX_TAG_SET_OVERSCAN 0x0004800a
490 typedef struct {
491  bcm2835_mbox_tag_hdr tag_hdr;
492  union {
493  struct {
494  uint32_t overscan_top;
495  uint32_t overscan_bottom;
496  uint32_t overscan_left;
497  uint32_t overscan_right;
498  } req;
499  struct {
500  uint32_t overscan_top;
501  uint32_t overscan_bottom;
502  uint32_t overscan_left;
503  uint32_t overscan_right;
504  } resp;
505  } body;
507
508 #define BCM2835_MAILBOX_TAG_GET_PALETTE 0x0004000b
509 #define BCM2835_MAILBOX_TAG_TEST_PALETTE 0x0004400b
510 #define BCM2835_MAILBOX_TAG_SET_PALETTE 0x0004800b
511 #define BCM2835_MAILBOX_TAG_SET_CURSOR_INFO 0x00008011
512 #define BCM2835_MAILBOX_TAG_SET_CURSOR_STATE 0x00008010
513
518 #endif /* LIBBSP_ARM_RASPBERRYPI_VC_DEFINES_H */
Definition: vc_defines.h:199
Definition: vc_defines.h:459
Definition: vc_defines.h:392
Definition: vc_defines.h:473
Definition: vc_defines.h:141
Definition: vc_defines.h:355
uint32_t buf_code
Buffer Code.
Definition: vc_defines.h:71
Buffer Header.
Definition: vc_defines.h:55
Definition: vc_defines.h:266
uint32_t buf_size
Buffer Size.
Definition: vc_defines.h:62
uint32_t val_len
The size of response buffer set by videocore.
Definition: vc_defines.h:96
Definition: vc_defines.h:187
The size of request qnd responce buffer.
Definition: vc_defines.h:90
Definition: vc_defines.h:225
Tag Header.
Definition: vc_defines.h:82
Definition: vc_defines.h:155
Definition: vc_defines.h:284
Definition: vc_defines.h:240
uint32_t tag
Property Tag ID.
Definition: vc_defines.h:86
Definition: vc_defines.h:375
Definition: vc_defines.h:442
Definition: vc_defines.h:409
unsigned size
Definition: tte.h:74
Definition: vc_defines.h:427
Definition: vc_defines.h:490
Definition: vc_defines.h:212
