RTEMS  5.1
uuidd.h
1 /*
2  * Definitions used by the uuidd daemon
3  *
4  * Copyright (C) 2007 Theodore Ts'o.
5  *
6  * %Begin-Header%
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, and the entire permission notice in its entirety,
12  * including the disclaimer of warranties.
13  * 2. Redistributions in binary form must reproduce the above copyright
14  * notice, this list of conditions and the following disclaimer in the
15  * documentation and/or other materials provided with the distribution.
16  * 3. The name of the author may not be used to endorse or promote
17  * products derived from this software without specific prior
18  * written permission.
19  *
20  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
21  * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
22  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ALL OF
23  * WHICH ARE HEREBY DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE
24  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
26  * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
27  * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
28  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
29  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
30  * USE OF THIS SOFTWARE, EVEN IF NOT ADVISED OF THE POSSIBILITY OF SUCH
31  * DAMAGE.
32  * %End-Header%
33  */
34
35 #ifndef _UUID_UUIDD_H
36 #define _UUID_UUIDD_H
37
38 #define UUIDD_SOCKET_PATH "/var/lib/libuuid/request"
39 #define UUIDD_PIDFILE_PATH "/var/lib/libuuid/uuidd.pid"
40 #define UUIDD_PATH "/usr/sbin/uuidd"
41
42 #define UUIDD_OP_GETPID 0
43 #define UUIDD_OP_GET_MAXOP 1
44 #define UUIDD_OP_TIME_UUID 2
45 #define UUIDD_OP_RANDOM_UUID 3
46 #define UUIDD_OP_BULK_TIME_UUID 4
47 #define UUIDD_OP_BULK_RANDOM_UUID 5
48 #define UUIDD_MAX_OP UUIDD_OP_BULK_RANDOM_UUID
49
50 extern void uuid__generate_time(uuid_t out, int *num);
51 extern void uuid__generate_random(uuid_t out, int *num);
52
53 #endif /* _UUID_UUID_H */
