RTEMS  5.1
twiRegs.h
1 /* Blackfin Two Wire Interface Registers
2  *
3  * Copyright (c) 2008 Kallisti Labs, Los Gatos, CA, USA
4  * written by Allan Hessenflow <allanh@kallisti.com>
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef _twiRegs_h_
12 #define _twiRegs_h_
13
14
15 /* register addresses */
16
17 #define TWI_CLKDIV_OFFSET 0x0000
18 #define TWI_CONTROL_OFFSET 0x0004
19 #define TWI_SLAVE_CTL_OFFSET 0x0008
20 #define TWI_SLAVE_STAT_OFFSET 0x000c
21 #define TWI_SLAVE_ADDR_OFFSET 0x0010
22 #define TWI_MASTER_CTL_OFFSET 0x0014
23 #define TWI_MASTER_STAT_OFFSET 0x0018
24 #define TWI_MASTER_ADDR_OFFSET 0x001c
25 #define TWI_INT_STAT_OFFSET 0x0020
26 #define TWI_INT_MASK_OFFSET 0x0024
27 #define TWI_FIFO_CTL_OFFSET 0x0028
28 #define TWI_FIFO_STAT_OFFSET 0x002c
29 #define TWI_XMT_DATA8_OFFSET 0x0080
30 #define TWI_XMT_DATA16_OFFSET 0x0084
31 #define TWI_RCV_DATA8_OFFSET 0x0088
32 #define TWI_RCV_DATA16_OFFSET 0x008c
33
34
35 /* register fields */
36
37 #define TWI_CLKDIV_CLKHI_MASK 0xff00
38 #define TWI_CLKDIV_CLKHI_SHIFT 8
39 #define TWI_CLKDIV_CLKLOW_MASK 0x00ff
40 #define TWI_CLKDIV_CLKLOW_SHIFT 0
41
42 #define TWI_CONTROL_SCCB 0x0200
43 #define TWI_CONTROL_TWI_ENA 0x0080
44 #define TWI_CONTROL_PRESCALE_MASK 0x007f
45 #define TWI_CONTROL_PRESCALE_SHIFT 0
46
47 #define TWI_SLAVE_CTL_GEN 0x0010
48 #define TWI_SLAVE_CTL_NAK 0x0008
49 #define TWI_SLAVE_CTL_STDVAL 0x0004
50 #define TWI_SLAVE_CTL_SEN 0x0001
51
52 #define TWI_SLAVE_STAT_GCALL 0x0002
53 #define TWI_SLAVE_STAT_SDIR 0x0001
54
55 #define TWI_SLAVE_ADDR_SADDR_MASK 0x007f
56 #define TWI_SLAVE_ADDR_SADDR_SHIFT 0
57
58 #define TWI_MASTER_CTL_SCLOVR 0x8000
59 #define TWI_MASTER_CTL_SDAOVR 0x4000
60 #define TWI_MASTER_CTL_DCNT_MASK 0x3fc0
61 #define TWI_MASTER_CTL_DCNT_SHIFT 6
62 #define TWI_MASTER_CTL_RSTART 0x0020
63 #define TWI_MASTER_CTL_STOP 0x0010
64 #define TWI_MASTER_CTL_FAST 0x0008
65 #define TWI_MASTER_CTL_MDIR 0x0004
66 #define TWI_MASTER_CTL_MEN 0x0001
67
68 #define TWI_MASTER_STAT_BUSBUSY 0x0100
69 #define TWI_MASTER_STAT_SCLSEN 0x0080
70 #define TWI_MASTER_STAT_SDASEN 0x0040
71 #define TWI_MASTER_STAT_BUFWRERR 0x0020
72 #define TWI_MASTER_STAT_BUFRDERR 0x0010
73 #define TWI_MASTER_STAT_DNAK 0x0008
74 #define TWI_MASTER_STAT_ANAK 0x0004
75 #define TWI_MASTER_STAT_LOSTARB 0x0002
76 #define TWI_MASTER_STAT_MPROG 0x0001
77
78 #define TWI_MASTER_ADDR_MADDR_MASK 0x007f
79 #define TWI_MASTER_ADDR_MADDR_SHIFT 0
80
81 #define TWI_INT_STAT_RCVSERV 0x0080
82 #define TWI_INT_STAT_XMTSERV 0x0040
83 #define TWI_INT_STAT_MERR 0x0020
84 #define TWI_INT_STAT_MCOMP 0x0010
85 #define TWI_INT_STAT_SOVF 0x0008
86 #define TWI_INT_STAT_SERR 0x0004
87 #define TWI_INT_STAT_SCOMP 0x0002
88 #define TWI_INT_STAT_SINIT 0x0001
89
90 #define TWI_INT_MASK_RCVSERVM 0x0080
91 #define TWI_INT_MASK_XMTSERVM 0x0040
92 #define TWI_INT_MASK_MERRM 0x0020
93 #define TWI_INT_MASK_MCOMPM 0x0010
94 #define TWI_INT_MASK_SOVFM 0x0008
95 #define TWI_INT_MASK_SERRM 0x0004
96 #define TWI_INT_MASK_SCOMPM 0x0002
97 #define TWI_INT_MASK_SINITM 0x0001
98
99 #define TWI_FIFO_CTL_RCVINTLEN 0x0008
100 #define TWI_FIFO_CTL_XMTINTLEN 0x0004
101 #define TWI_FIFO_CTL_RCVFLUSH 0x0002
102 #define TWI_FIFO_CTL_XMTFLUSH 0x0001
103
104 #define TWI_FIFO_STAT_RCVSTAT_MASK 0x000c
105 #define TWI_FIFO_STAT_RCVSTAT_EMPTY 0x0000
106 #define TWI_FIFO_STAT_RCVSTAT_SHIFT 2
107 #define TWI_FIFO_STAT_XMTSTAT_MASK 0x0003
108 #define TWI_FIFO_STAT_XMTSTAT_FULL 0x0003
109 #define TWI_FIFO_STAT_XMTSTAT_SHIFT 0
110
111 #define TWI_XMT_DATA8_XMTDATA8_MASK 0x00ff
112 #define TWI_XMT_DATA8_XMTDATA8_SHIFT 0
113
114 #define TWI_RCV_DATA8_RCVDATA8_MASK 0x00ff
115 #define TWI_RCV_DATA8_RCVDATA8_SHIFT 0
116
117
118 #endif /* _twiRegs_h_ */
