RTEMS
5.1
Go to the documentation of this file. 33 #define LM32_TSMAC_RX_LEN_FIFO (0x000) 34 #define LM32_TSMAC_RX_DATA_FIFO (0x004) 35 #define LM32_TSMAC_TX_LEN_FIFO (0x008) 36 #define LM32_TSMAC_TX_DATA_FIFO (0x00C) 40 #define LM32_TSMAC_VERID (0x100) 41 #define LM32_TSMAC_INTR_SRC (0x104) 42 #define INTR_RX_SMRY (0x00020000) 43 #define INTR_TX_SMRY (0x00010000) 44 #define INTR_RX_FIFO_FULL (0x00001000) 45 #define INTR_RX_ERROR (0x00000800) 46 #define INTR_RX_FIFO_ERROR (0x00000400) 47 #define INTR_RX_FIFO_ALMOST_FULL (0x00000200) 48 #define INTR_RX_PKT_RDY (0x00000100) 49 #define INTR_TX_FIFO_FULL (0x00000010) 50 #define INTR_TX_DISCFRM (0x00000008) 51 #define INTR_TX_FIFO_ALMOST_EMPTY (0x00000004) 52 #define INTR_TX_FIFO_ALMOST_FULL (0x00000002) 53 #define INTR_TX_PKT_SENT (0x00000001) 54 #define LM32_TSMAC_INTR_ENB (0x108) 55 #define INTR_ENB (0x00040000) 56 #define LM32_TSMAC_RX_STATUS (0x10C) 57 #define STAT_RX_FIFO_FULL (0x00000010) 58 #define STAT_RX_ERROR (0x00000008) 59 #define STAT_RX_FIFO_ERROR (0x00000004) 60 #define STAT_RX_FIFO_ALMOST_FULL (0x00000002) 61 #define STAT_RX_PKT_RDY (0x00000001) 62 #define LM32_TSMAC_TX_STATUS (0x110) 63 #define STAT_TX_FIFO_FULL (0x00000010) 64 #define STAT_TX_DISCFRM (0x00000008) 65 #define STAT_TX_FIFO_ALMOST_EMPTY (0x00000004) 66 #define STAT_TX_FIFO_ALMOST_FULL (0x00000002) 67 #define STAT_TX_PKT_SENT (0x00000001) 68 #define LM32_TSMAC_RX_FRAMES_CNT (0x114) 69 #define LM32_TSMAC_TX_FRAMES_CNT (0x118) 70 #define LM32_TSMAC_RX_FIFO_TH (0x11C) 71 #define LM32_TSMAC_TX_FIFO_TH (0x120) 72 #define LM32_TSMAC_SYS_CTL (0x124) 73 #define SYS_CTL_TX_FIFO_FLUSH (0x00000010) 74 #define SYS_CTL_RX_FIFO_FLUSH (0x00000008) 75 #define SYS_CTL_TX_SNDPAUSREQ (0x00000004) 76 #define SYS_CTL_TX_FIFOCTRL (0x00000002) 77 #define SYS_CTL_IGNORE_NEXT_PKT (0x00000001) 78 #define LM32_TSMAC_PAUSE_TMR (0x128) 82 #define LM32_TSMAC_MAC_REGS_DATA (0x200) 83 #define LM32_TSMAC_MAC_REGS_ADDR_RW (0x204) 84 #define REGS_ADDR_WRITE (0x80000000) 85 #define LM32_TSMAC_MODE_BYTE0 (0x000) 86 #define MODE_TX_EN (1<<3) 87 #define MODE_RX_EN (1<<2) 88 #define MODE_FC_EN (1<<1) 89 #define MODE_GBIT_EN (1<<0) 90 #define LM32_TSMAC_TX_RX_CTL_BYTE0 (0x002) 91 #define TX_RX_CTL_RECEIVE_SHORT (1<<8) 92 #define TX_RX_CTL_RECEIVE_BRDCST (1<<7) 93 #define TX_RX_CTL_DIS_RTRY (1<<6) 94 #define TX_RX_CTL_HDEN (1<<5) 95 #define TX_RX_CTL_RECEIVE_MLTCST (1<<4) 96 #define TX_RX_CTL_RECEIVE_PAUSE (1<<3) 97 #define TX_RX_CTL_TX_DIS_FCS (1<<2) 98 #define TX_RX_CTL_DISCARD_FCS (1<<1) 99 #define TX_RX_CTL_PRMS (1<<0) 100 #define LM32_TSMAC_MAX_PKT_SIZE_BYTE0 (0x004) 101 #define LM32_TSMAC_IPG_VAL_BYTE0 (0x008) 102 #define LM32_TSMAC_MAC_ADDR_0_BYTE0 (0x00A) 103 #define LM32_TSMAC_MAC_ADDR_1_BYTE0 (0x00C) 104 #define LM32_TSMAC_MAC_ADDR_2_BYTE0 (0x00E) 105 #define LM32_TSMAC_TX_RX_STS_BYTE0 (0x012) 106 #define TX_RX_STS_RX_IDLE (1<<10) 107 #define TX_RX_STS_TAGGED_FRAME (1<<9) 108 #define TX_RX_STS_BRDCST_FRAME (1<<8) 109 #define TX_RX_STS_MULTCST_FRAME (1<<7) 110 #define TX_RX_STS_IPG_SHRINK (1<<6) 111 #define TX_RX_STS_SHORT_FRAME (1<<5) 112 #define TX_RX_STS_LONG_FRAME (1<<4) 113 #define TX_RX_STS_ERROR_FRAME (1<<3) 114 #define TX_RX_STS_CRC (1<<2) 115 #define TX_RX_STS_PAUSE_FRAME (1<<1) 116 #define TX_RX_STS_TX_IDLE (1<<0) 117 #define LM32_TSMAC_GMII_MNG_CTL_BYTE0 (0x014) 118 #define GMII_MNG_CTL_CMD_FIN (1<<14) 119 #define GMII_MNG_CTL_READ_PHYREG (0) 120 #define GMII_MNG_CTL_WRITE_PHYREG (1<<13) 121 #define GMII_MNG_CTL_PHY_ADD_MASK (0x001f) 122 #define GMII_MNG_CTL_PHY_ADD_SHIFT (8) 123 #define GMII_MNG_CTL_REG_ADD_MASK (0x001f) 124 #define GMII_MNG_CTL_REG_ADD_SHIFT (0) 125 #define LM32_TSMAC_GMII_MNG_DAT_BYTE0 (0x016) 126 #define LM32_TSMAC_MLT_TAB_0_BYTE0 (0x022) 127 #define LM32_TSMAC_MLT_TAB_1_BYTE0 (0x024) 128 #define LM32_TSMAC_MLT_TAB_2_BYTE0 (0x026) 129 #define LM32_TSMAC_MLT_TAB_3_BYTE0 (0x028) 130 #define LM32_TSMAC_MLT_TAB_4_BYTE0 (0x02A) 131 #define LM32_TSMAC_MLT_TAB_5_BYTE0 (0x02C) 132 #define LM32_TSMAC_MLT_TAB_6_BYTE0 (0x02E) 133 #define LM32_TSMAC_MLT_TAB_7_BYTE0 (0x030) 134 #define LM32_TSMAC_VLAN_TAG_BYTE0 (0x032) 135 #define LM32_TSMAC_PAUS_OP_BYTE0 (0x034) 139 #define LM32_TSMAC_RX_PKT_IGNR_CNT (0x300) 140 #define LM32_TSMAC_RX_LEN_CHK_ERR_CNT (0x304) 141 #define LM32_TSMAC_RX_LNG_FRM_CNT (0x308) 142 #define LM32_TSMAC_RX_SHRT_FRM_CNT (0x30C) 143 #define LM32_TSMAC_RX_IPG_VIOL_CNT (0x310) 144 #define LM32_TSMAC_RX_CRC_ERR_CNT (0x314) 145 #define LM32_TSMAC_RX_OK_PKT_CNT (0x318) 146 #define LM32_TSMAC_RX_CTL_FRM_CNT (0x31C) 147 #define LM32_TSMAC_RX_PAUSE_FRM_CNT (0x320) 148 #define LM32_TSMAC_RX_MULTICAST_CNT (0x324) 149 #define LM32_TSMAC_RX_BRDCAST_CNT (0x328) 150 #define LM32_TSMAC_RX_VLAN_TAG_CNT (0x32C) 151 #define LM32_TSMAC_RX_PRE_SHRINK_CNT (0x330) 152 #define LM32_TSMAC_RX_DRIB_NIB_CNT (0x334) 153 #define LM32_TSMAC_RX_UNSUP_OPCD_CNT (0x338) 154 #define LM32_TSMAC_RX_BYTE_CNT (0x33C) 158 #define LM32_TSMAC_TX_UNICAST_CNT (0x400) 159 #define LM32_TSMAC_TX_PAUSE_FRM_CNT (0x404) 160 #define LM32_TSMAC_TX_MULTICAST_CNT (0x408) 161 #define LM32_TSMAC_TX_BRDCAST_CNT (0x40C) 162 #define LM32_TSMAC_TX_VLAN_TAG_CNT (0x410) 163 #define LM32_TSMAC_TX_BAD_FCS_CNT (0x414) 164 #define LM32_TSMAC_TX_JUMBO_CNT (0x418) 165 #define LM32_TSMAC_TX_BYTE_CNT (0x41C) 168 void ipalign(
struct mbuf *m);
