RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
atsam
include
libchip
include
trace.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
64
#ifndef _TRACE_
65
#define _TRACE_
66
67
68
* Headers
69
70
71
#include "
pio.h
72
73
75
76
* Global Definitions
77
78
80
#define SOFTPACK_VERSION "1.5"
81
82
83
#define TRACE_LEVEL_DEBUG 5
84
#define TRACE_LEVEL_INFO 4
85
#define TRACE_LEVEL_WARNING 3
86
#define TRACE_LEVEL_ERROR 2
87
#define TRACE_LEVEL_FATAL 1
88
#define TRACE_LEVEL_NO_TRACE 0
89
90
/* By default, all traces are output except the debug one. */
91
#if !defined(TRACE_LEVEL)
92
#define TRACE_LEVEL TRACE_LEVEL_INFO
93
#endif
94
95
/* By default, trace level is static (not dynamic) */
96
#if !defined(DYN_TRACES)
97
#define DYN_TRACES 0
98
#endif
99
100
#if defined(NOTRACE)
101
#error "Error: NOTRACE has to be not defined !"
102
#endif
103
104
#undef NOTRACE
105
#if (DYN_TRACES==0)
106
#if (TRACE_LEVEL == TRACE_LEVEL_NO_TRACE)
107
#define NOTRACE
108
#endif
109
#endif
110
111
112
113
114
* Global Macros
115
116
117
118
extern
void
TRACE_CONFIGURE(uint32_t dwBaudRate, uint32_t dwMCk);
119
127
#ifndef DYNTRACE
128
#define DYNTRACE 0
129
#endif
130
131
#if (TRACE_LEVEL==0) && (DYNTRACE==0)
132
#define TRACE_CONFIGURE_ISP(mode, baudrate, mck) {}
133
#else
134
#define TRACE_CONFIGURE_ISP(mode, baudrate, mck) { \
135
const Pin pinsUART0[] = {PINS_UART}; \
136
PIO_Configure(pinsUART0, PIO_LISTSIZE(pinsUART0)); \
137
UART_Configure(baudrate, mck); \
138
139
#endif
140
146
147
148
/* Empty macro */
149
#define TRACE_DEBUG(...) { }
150
#define TRACE_INFO(...) { }
151
#define TRACE_WARNING(...) { }
152
#define TRACE_ERROR(...) { }
153
#define TRACE_FATAL(...) { while (1); }
154
155
#define TRACE_DEBUG_WP(...) { }
156
#define TRACE_INFO_WP(...) { }
157
#define TRACE_WARNING_WP(...) { }
158
#define TRACE_ERROR_WP(...) { }
159
#define TRACE_FATAL_WP(...) { while (1); }
160
161
#elif (DYN_TRACES == 1)
162
163
/* Trace output depends on dwTraceLevel value */
164
#define TRACE_DEBUG(...) { if (dwTraceLevel >= TRACE_LEVEL_DEBUG) { printf("-D- " __VA_ARGS__); } }
165
#define TRACE_INFO(...) { if (dwTraceLevel >= TRACE_LEVEL_INFO) { printf("-I- " __VA_ARGS__); } }
166
#define TRACE_WARNING(...) { if (dwTraceLevel >= TRACE_LEVEL_WARNING) { printf("-W- " __VA_ARGS__); } }
167
#define TRACE_ERROR(...) { if (dwTraceLevel >= TRACE_LEVEL_ERROR) { printf("-E- " __VA_ARGS__); } }
168
#define TRACE_FATAL(...) { if (dwTraceLevel >= TRACE_LEVEL_FATAL) { printf("-F- " __VA_ARGS__); while (1); } }
169
170
#define TRACE_DEBUG_WP(...) { if (dwTraceLevel >= TRACE_LEVEL_DEBUG) { printf(__VA_ARGS__); } }
171
#define TRACE_INFO_WP(...) { if (dwTraceLevel >= TRACE_LEVEL_INFO) { printf(__VA_ARGS__); } }
172
#define TRACE_WARNING_WP(...) { if (dwTraceLevel >= TRACE_LEVEL_WARNING) { printf(__VA_ARGS__); } }
173
#define TRACE_ERROR_WP(...) { if (dwTraceLevel >= TRACE_LEVEL_ERROR) { printf(__VA_ARGS__); } }
174
#define TRACE_FATAL_WP(...) { if (dwTraceLevel >= TRACE_LEVEL_FATAL) { printf(__VA_ARGS__); while (1); } }
175
176
#else
177
178
/* Trace compilation depends on TRACE_LEVEL value */
179
#if (TRACE_LEVEL >= TRACE_LEVEL_DEBUG)
180
#define TRACE_DEBUG(...) { printf("-D- " __VA_ARGS__); }
181
#define TRACE_DEBUG_WP(...) { printf(__VA_ARGS__); }
182
#else
183
184
185
#endif
186
187
#if (TRACE_LEVEL >= TRACE_LEVEL_INFO)
188
#define TRACE_INFO(...) { printf("-I- " __VA_ARGS__); }
189
#define TRACE_INFO_WP(...) { printf(__VA_ARGS__); }
190
#else
191
192
193
#endif
194
195
#if (TRACE_LEVEL >= TRACE_LEVEL_WARNING)
196
#define TRACE_WARNING(...) { printf("-W- " __VA_ARGS__); }
197
#define TRACE_WARNING_WP(...) { printf(__VA_ARGS__); }
198
#else
199
200
201
#endif
202
203
#if (TRACE_LEVEL >= TRACE_LEVEL_ERROR)
204
#define TRACE_ERROR(...) { printf("-E- " __VA_ARGS__); }
205
#define TRACE_ERROR_WP(...) { printf(__VA_ARGS__); }
206
#else
207
208
209
#endif
210
211
#if (TRACE_LEVEL >= TRACE_LEVEL_FATAL)
212
#define TRACE_FATAL(...) { printf("-F- " __VA_ARGS__); while (1); }
213
#define TRACE_FATAL_WP(...) { printf(__VA_ARGS__); while (1); }
214
#else
215
216
217
#endif
218
219
#endif
220
221
226
#if !defined(NOTRACE) && (DYN_TRACES == 1)
227
extern
uint32_t dwTraceLevel;
228
#endif
229
230
#endif //#ifndef TRACE_H
231
pio.h
