RTEMS  5.1
tms570_selftest.h
1
8 /*
9  * Copyright (c) 2016 Pavel Pisa <pisa@cmp.felk.cvut.cz>
10  *
11  * Czech Technical University in Prague
12  * Zikova 1903/4
13  * 166 36 Praha 6
14  * Czech Republic
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  *
20  * Algorithms are based on Ti manuals and Ti HalCoGen generated
21  * code available under following copyright.
22  */
23 /*
24  * Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
25  *
26  *
27  * Redistribution and use in source and binary forms, with or without
28  * modification, are permitted provided that the following conditions
29  * are met:
30  *
31  * Redistributions of source code must retain the above copyright
32  * notice, this list of conditions and the following disclaimer.
33  *
34  * Redistributions in binary form must reproduce the above copyright
35  * notice, this list of conditions and the following disclaimer in the
36  * documentation and/or other materials provided with the
37  * distribution.
38  *
39  * Neither the name of Texas Instruments Incorporated nor the names of
40  * its contributors may be used to endorse or promote products derived
41  * from this software without specific prior written permission.
42  *
43  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
44  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
45  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
46  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
47  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
50  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
51  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
52  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
53  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
54  *
55  */
56
57 #ifndef LIBBSP_ARM_TMS570_SELFTEST_H
58 #define LIBBSP_ARM_TMS570_SELFTEST_H
59
60 #include <stdint.h>
61 #include <stdbool.h>
62
63 #define CCMSELFCHECK_FAIL1 1U
64 #define CCMSELFCHECK_FAIL2 2U
65 #define CCMSELFCHECK_FAIL3 3U
66 #define CCMSELFCHECK_FAIL4 4U
67 #define PBISTSELFCHECK_FAIL1 5U
68 #define EFCCHECK_FAIL1 6U
69 #define EFCCHECK_FAIL2 7U
70 #define FMCECCCHECK_FAIL1 8U
71 #define CHECKB0RAMECC_FAIL1 9U
72 #define CHECKB1RAMECC_FAIL1 10U
73 #define CHECKFLASHECC_FAIL1 11U
74 #define VIMPARITYCHECK_FAIL1 12U
75 #define DMAPARITYCHECK_FAIL1 13U
76 #define HET1PARITYCHECK_FAIL1 14U
77 #define HTU1PARITYCHECK_FAIL1 15U
78 #define HET2PARITYCHECK_FAIL1 16U
79 #define HTU2PARITYCHECK_FAIL1 17U
80 #define ADC1PARITYCHECK_FAIL1 18U
81 #define ADC2PARITYCHECK_FAIL1 19U
82 #define CAN1PARITYCHECK_FAIL1 20U
83 #define CAN2PARITYCHECK_FAIL1 21U
84 #define CAN3PARITYCHECK_FAIL1 22U
85 #define MIBSPI1PARITYCHECK_FAIL1 23U
86 #define MIBSPI3PARITYCHECK_FAIL1 24U
87 #define MIBSPI5PARITYCHECK_FAIL1 25U
88 #define CHECKRAMECC_FAIL1 26U
89 #define CHECKRAMECC_FAIL2 27U
90 #define CHECKCLOCKMONITOR_FAIL1 28U
91 #define CHECKFLASHEEPROMECC_FAIL1 29U
92 #define CHECKFLASHEEPROMECC_FAIL2 31U
93 #define CHECKFLASHEEPROMECC_FAIL3 32U
94 #define CHECKFLASHEEPROMECC_FAIL4 33U
95 #define CHECKPLL1SLIP_FAIL1 34U
96 #define CHECKRAMADDRPARITY_FAIL1 35U
97 #define CHECKRAMADDRPARITY_FAIL2 36U
98 #define CHECKRAMUERRTEST_FAIL1 37U
99 #define CHECKRAMUERRTEST_FAIL2 38U
100 #define FMCBUS1PARITYCHECK_FAIL1 39U
101 #define FMCBUS1PARITYCHECK_FAIL2 40U
102 #define PBISTSELFCHECK_FAIL2 41U
103 #define PBISTSELFCHECK_FAIL3 42U
104
105 /* PBIST and STC ROM - PBIST RAM GROUPING */
106 #define PBIST_ROM_PBIST_RAM_GROUP 1U
107 #define STC_ROM_PBIST_RAM_GROUP 2U
108
109 #define VIMRAMLOC (*(volatile uint32_t *)0xFFF82000U)
110 #define VIMRAMPARLOC (*(volatile uint32_t *)0xFFF82400U)
111
112 #define NHET1RAMPARLOC (*(volatile uint32_t *)0xFF462000U)
113 #define NHET2RAMPARLOC (*(volatile uint32_t *)0xFF442000U)
114 #define adcPARRAM1 (*(volatile uint32_t *)(0xFF3E0000U + 0x1000U))
115 #define adcPARRAM2 (*(volatile uint32_t *)(0xFF3A0000U + 0x1000U))
116 #define canPARRAM1 (*(volatile uint32_t *)(0xFF1E0000U + 0x10U))
117 #define canPARRAM2 (*(volatile uint32_t *)(0xFF1C0000U + 0x10U))
118 #define canPARRAM3 (*(volatile uint32_t *)(0xFF1A0000U + 0x10U))
119 #define HTU1PARLOC (*(volatile uint32_t *)0xFF4E0200U)
120 #define HTU2PARLOC (*(volatile uint32_t *)0xFF4C0200U)
121
122 #define NHET1RAMLOC (*(volatile uint32_t *)0xFF460000U)
123 #define NHET2RAMLOC (*(volatile uint32_t *)0xFF440000U)
124 #define HTU1RAMLOC (*(volatile uint32_t *)0xFF4E0000U)
125 #define HTU2RAMLOC (*(volatile uint32_t *)0xFF4C0000U)
126
127 #define adcRAM1 (*(volatile uint32_t *)0xFF3E0000U)
128 #define adcRAM2 (*(volatile uint32_t *)0xFF3A0000U)
129 #define canRAM1 (*(volatile uint32_t *)0xFF1E0000U)
130 #define canRAM2 (*(volatile uint32_t *)0xFF1C0000U)
131 #define canRAM3 (*(volatile uint32_t *)0xFF1A0000U)
132
133 #define DMARAMPARLOC (*(volatile uint32_t *)(0xFFF80A00U))
134 #define DMARAMLOC (*(volatile uint32_t *)(0xFFF80000U))
135
136 #define MIBSPI1RAMLOC (*(volatile uint32_t *)(0xFF0E0000U))
137 #define MIBSPI3RAMLOC (*(volatile uint32_t *)(0xFF0C0000U))
138 #define MIBSPI5RAMLOC (*(volatile uint32_t *)(0xFF0A0000U))
139
140 #define mibspiPARRAM1 (*(volatile uint32_t *)(0xFF0E0000U + 0x00000400U))
141 #define mibspiPARRAM3 (*(volatile uint32_t *)(0xFF0C0000U + 0x00000400U))
142 #define mibspiPARRAM5 (*(volatile uint32_t *)(0xFF0A0000U + 0x00000400U))
143
153 enum pbistPort {
154  PBIST_PORT0 = 0U,
156 };
157
158 enum {
159  PBIST_TripleReadSlow = 0x00000001U,
160  PBIST_TripleReadFast = 0x00000002U,
161  PBIST_March13N_DP = 0x00000004U,
162 };
163
164 uint32_t tms570_efc_check( void );
165
166 bool tms570_efc_check_self_test( void );
167
168 void bsp_selftest_fail_notification( uint32_t flag );
169
170 void tms570_memory_port0_fail_notification(
171  uint32_t groupSelect,
172  uint32_t dataSelect,
173  uint32_t address,
174  uint32_t data
175 );
176
178  unsigned grp,
179  unsigned chan
180 );
181
183  unsigned grp,
184  unsigned chan
185 );
186
187 void tms570_pbist_self_check( void );
188
189 void tms570_pbist_run(
190  uint32_t raminfoL,
191  uint32_t algomask
192 );
193
194 bool tms570_pbist_is_test_completed( void );
195
196 bool tms570_pbist_is_test_passed( void );
197
198 void tms570_pbist_fail( void );
199
200 void tms570_pbist_stop( void );
201
202 void tms570_enable_parity( void );
203
204 void tms570_disable_parity( void );
205
206 bool tms570_efc_stuck_zero( void );
207
208 void tms570_efc_self_test( void );
209
210 bool tms570_pbist_port_test_status( uint32_t port );
211
212 void tms570_check_tcram_ecc( void );
213
214 #endif /*LIBBSP_ARM_TMS570_SELFTEST_H*/
Definition: tms570_selftest.h:155
bool tms570_pbist_is_test_completed(void)
Checks to see if the PBIST test is completed (HCG:pbistIsTestCompleted)
Definition: tms570_selftest.c:399
Definition: tms570_selftest.h:154
void tms570_enable_parity(void)
Enable peripheral RAM parity (HCG:enableParity)
Definition: tms570_selftest.c:563
bool tms570_pbist_port_test_status(uint32_t port)
Checks to see if the PBIST Port test is completed successfully (HCG:pbistPortTestStatus)
Definition: tms570_selftest.c:436
bool tms570_efc_stuck_zero(void)
Checks to see if the EFUSE Stuck at zero test is completed successfully (HCG:efcStuckZeroTest)....
Definition: tms570_selftest.c:59
int tms570_esm_channel_sr_get(unsigned grp, unsigned chan)
Routine to test is specified error channel is signalling error.
Definition: tms570_selftest.c:541
Definition: tms570_selftest.h:160
void tms570_check_tcram_ecc(void)
Check TCRAM ECC error detection logic (HCG:checkRAMECC)
Definition: tms570_tcram_tests.c:85
void tms570_esm_channel_sr_clear(unsigned grp, unsigned chan)
Routine to clear specified error channel signalling bit.
Definition: tms570_selftest.c:523
uint32_t tms570_efc_check(void)
EFUSE module self check Driver (HCG:efcCheck)
Definition: tms570_selftest.c:185
bool tms570_efc_check_self_test(void)
EFUSE module self check Driver (HCG:checkefcSelfTest)
Definition: tms570_selftest.c:142
bool tms570_pbist_is_test_passed(void)
Checks to see if the PBIST test is completed successfully (HCG:pbistIsTestPassed)
Definition: tms570_selftest.c:413
Definition: tms570_selftest.h:161
void tms570_pbist_self_check(void)
PBIST self test Driver (HCG:pbistSelfCheck)
Definition: tms570_selftest.c:230
Definition: tms570_selftest.h:159
void tms570_efc_self_test(void)
EFUSE module self check Driver (HCG:efcSelfTest)
Definition: tms570_selftest.c:118
void tms570_pbist_fail(void)
Reaction to PBIST failure (HCG:pbistFail)
Definition: tms570_selftest.c:458
void tms570_pbist_stop(void)
Routine to stop PBIST test enabled (HCG:pbistStop)
Definition: tms570_selftest.c:382
void tms570_pbist_run(uint32_t raminfoL, uint32_t algomask)
CPU self test Driver (HCG:pbistRun)
Definition: tms570_selftest.c:326
void tms570_disable_parity(void)
Disable peripheral RAM parity (HCG:disableParity)
Definition: tms570_selftest.c:585
pbistPort
Alias names for pbist Port number.
Definition: tms570_selftest.h:153
