RTEMS  5.1
tms570-pinmux.h
1
9 /*
10  * Copyright (c) 2015 Premysl Houdek <kom541000@gmail.com>
11  *
12  * Google Summer of Code 2014 at
13  * Czech Technical University in Prague
14  * Zikova 1903/4
15  * 166 36 Praha 6
16  * Czech Republic
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_TMS570_PINMUX_H
24 #define LIBBSP_ARM_TMS570_PINMUX_H
25
26 #ifndef ASM
27 #include <bsp/tms570.h>
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif /* __cplusplus */
32
33
34 #define TMS570_PIN_NUM_SHIFT 0
35 #define TMS570_PIN_NUM_MASK 0x000007ff
36
37 /*
38  * Request clear of interconnection in setup
39  * to ensure that previous peripheral to pin
40  * connection is not enabled in parallel to other one.
41  * Mask is ored with pin number in such list.
42  */
43 #define TMS570_PIN_CLEAR_RQ_MASK 0x00000800
44
45 #define TMS570_PIN_FNC_SHIFT 12
46 #define TMS570_PIN_FNC_MASK 0x0000f000
47
48 #define TMS570_PIN_NUM_FNC_MASK 0x0000ffff
49
50 #define TMS570_PIN_IN_ALT_SHIFT 16
51 #define TMS570_PIN_IN_ALT_MASK 0xffff0000
52
53 #define TMS570_PIN_FNC_AUTO (-1)
54
55 #define TMS570_PIN_AND_FNC(pin, fnc) \
56  ((pin) | ((fnc) << TMS570_PIN_FNC_SHIFT))
57
58 #define TMS570_PIN_WITH_IN_ALT(pin_num_and_fnc, pin_in_alt_num_and_fnc) \
59  ((pin_num_and_fnc) | ((pin_in_alt_num_and_fnc) << TMS570_PIN_IN_ALT_SHIFT))
60
61 #define TMS570_BALL_WITH_MMR(mmrx, pos) \
62  ((pos) | ((mmrx) << 2))
63
64 /* Generic functions select pin to peripheral connection */
65
66 void tms570_bsp_pin_set_function(int pin_num, int pin_fnc);
67
68 void tms570_bsp_pin_clear_function(int pin_num, int pin_fnc);
69
70 void tms570_bsp_pin_config_one(uint32_t pin_num_and_fnc);
71
72 void tms570_bsp_pinmmr_config(const uint32_t *pinmmr_values, int reg_start, int reg_count);
73
74 static inline void
75 tms570_bsp_pin_to_pinmmrx(volatile uint32_t **pinmmrx, unsigned int *pin_shift,
76  int pin_num)
77 {
78  pin_num = (pin_num & TMS570_PIN_NUM_MASK) >> TMS570_PIN_NUM_SHIFT;
79  *pinmmrx = &TMS570_IOMM.PINMUX.PINMMR0 + (pin_num >> 2);
80  *pin_shift = (pin_num & 0x3)*8;
81 }
82
83 #define TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) \
84  (((((pin) & TMS570_PIN_NUM_MASK) >> 2 != (reg)) || ((pin) & TMS570_PIN_CLEAR_RQ_MASK))? 0: \
85  1 << ((((pin) & TMS570_PIN_FNC_MASK) >> TMS570_PIN_FNC_SHIFT) + \
86  ((pin) & 3) * 8) \
87  )
88
89 #define TMS570_PINMMR_REG_VAL_ACTION(reg, pin) \
90  TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) | \
91  ((pin) & TMS570_PIN_IN_ALT_MASK? \
92  TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, (pin) >> TMS570_PIN_IN_ALT_SHIFT ): \
93  0) |
94
108 #define TMS570_PINMMR_REG_VAL(reg, pin_list) \
109  pin_list(TMS570_PINMMR_REG_VAL_ACTION, reg) 0
110
111 #define TMS570_PINMMR_COMA_LIST_ACTION(reg, pin) \
112  (pin),
113
125 #define TMS570_PINMMR_COMA_LIST(pin_list) \
126  pin_list(TMS570_PINMMR_COMA_LIST_ACTION, 0)
127
128
129 #endif
130
133 #ifdef __cplusplus
134 }
135 #endif /* __cplusplus */
136
137 #endif /* LIBBSP_ARM_TMS570_IRQ_H */
configure one pin according to its function specification
Definition: pinmux.c:110
select desired function of pin/ball
Definition: pinmux.c:49
clear connection between pin and specified peripherals/function
Definition: pinmux.c:74
configure block or whole pin multiplexer
Definition: pinmux.c:161
