RTEMS  5.1
timepps.h
1 /*-
2  * ----------------------------------------------------------------------------
3  * "THE BEER-WARE LICENSE" (Revision 42):
4  * <phk@FreeBSD.org> wrote this file. As long as you retain this notice you
5  * can do whatever you want with this stuff. If we meet some day, and you think
6  * this stuff is worth it, you can buy me a beer in return. Poul-Henning Kamp
7  * ----------------------------------------------------------------------------
8  *
9  * Copyright (c) 2011 The FreeBSD Foundation
10  * All rights reserved.
11  *
12  * Portions of this software were developed by Julien Ridoux at the University
13  * of Melbourne under sponsorship from the FreeBSD Foundation.
14  *
15  * $FreeBSD: head/sys/sys/timepps.h 282424 2015-05-04 17:59:39Z ian $
16  *
17  * The is a FreeBSD version of the RFC 2783 API for Pulse Per Second
18  * timing interfaces.
19  */
20
21 #ifndef _SYS_TIMEPPS_H_
22 #define _SYS_TIMEPPS_H_
23
24 #include <sys/_ffcounter.h>
25 #include <sys/ioccom.h>
26 #include <sys/time.h>
27
28 #define PPS_API_VERS_1 1
29
30 typedef int pps_handle_t;
31
32 typedef unsigned pps_seq_t;
33
34 typedef struct ntp_fp {
35  unsigned int integral;
36  unsigned int fractional;
37 } ntp_fp_t;
38
39 typedef union pps_timeu {
40  struct timespec tspec;
41  ntp_fp_t ntpfp;
42  unsigned long longpad[3];
43 } pps_timeu_t;
44
45 typedef struct {
46  pps_seq_t assert_sequence; /* assert event seq # */
47  pps_seq_t clear_sequence; /* clear event seq # */
48  pps_timeu_t assert_tu;
49  pps_timeu_t clear_tu;
50  int current_mode; /* current mode bits */
51 } pps_info_t;
52
53 typedef struct {
54  pps_seq_t assert_sequence; /* assert event seq # */
55  pps_seq_t clear_sequence; /* clear event seq # */
56  pps_timeu_t assert_tu;
57  pps_timeu_t clear_tu;
58  ffcounter assert_ffcount; /* ffcounter on assert event */
59  ffcounter clear_ffcount; /* ffcounter on clear event */
60  int current_mode; /* current mode bits */
62
63 #define assert_timestamp assert_tu.tspec
64 #define clear_timestamp clear_tu.tspec
65
66 #define assert_timestamp_ntpfp assert_tu.ntpfp
67 #define clear_timestamp_ntpfp clear_tu.ntpfp
68
69 typedef struct {
70  int api_version; /* API version # */
71  int mode; /* mode bits */
72  pps_timeu_t assert_off_tu;
73  pps_timeu_t clear_off_tu;
74 } pps_params_t;
75
76 #define assert_offset assert_off_tu.tspec
77 #define clear_offset clear_off_tu.tspec
78
79 #define assert_offset_ntpfp assert_off_tu.ntpfp
80 #define clear_offset_ntpfp clear_off_tu.ntpfp
81
82
83 #define PPS_CAPTUREASSERT 0x01
84 #define PPS_CAPTURECLEAR 0x02
85 #define PPS_CAPTUREBOTH 0x03
86
87 #define PPS_OFFSETASSERT 0x10
88 #define PPS_OFFSETCLEAR 0x20
89
90 #define PPS_ECHOASSERT 0x40
91 #define PPS_ECHOCLEAR 0x80
92
93 #define PPS_CANWAIT 0x100
94 #define PPS_CANPOLL 0x200
95
96 #define PPS_TSFMT_TSPEC 0x1000
97 #define PPS_TSFMT_NTPFP 0x2000
98
99 #define PPS_TSCLK_FBCK 0x10000
100 #define PPS_TSCLK_FFWD 0x20000
101 #define PPS_TSCLK_MASK 0x30000
102
103 #define PPS_KC_HARDPPS 0
104 #define PPS_KC_HARDPPS_PLL 1
105 #define PPS_KC_HARDPPS_FLL 2
106
108  int tsformat;
109  pps_info_t pps_info_buf;
110  struct timespec timeout;
111 };
112
114  int tsformat;
115  pps_info_ffc_t pps_info_buf_ffc;
116  struct timespec timeout;
117 };
118
120  int kernel_consumer;
121  int edge;
122  int tsformat;
123 };
124
125 #define PPS_IOC_CREATE _IO('1', 1)
126 #define PPS_IOC_DESTROY _IO('1', 2)
127 #define PPS_IOC_SETPARAMS _IOW('1', 3, pps_params_t)
128 #define PPS_IOC_GETPARAMS _IOR('1', 4, pps_params_t)
129 #define PPS_IOC_GETCAP _IOR('1', 5, int)
130 #define PPS_IOC_FETCH _IOWR('1', 6, struct pps_fetch_args)
131 #define PPS_IOC_KCBIND _IOW('1', 7, struct pps_kcbind_args)
132 #define PPS_IOC_FETCH_FFCOUNTER _IOWR('1', 8, struct pps_fetch_ffc_args)
133
134 #ifdef _KERNEL
135
136 struct mtx;
137
138 #define KCMODE_EDGEMASK 0x03
139 #define KCMODE_ABIFLAG 0x80000000 /* Internal use: abi-aware driver. */
140
141 #define PPS_ABI_VERSION 1
142
143 #define PPSFLAG_MTX_SPIN 0x01 /* Driver mtx is MTX_SPIN type. */
144
145 struct pps_state {
146  /* Capture information. */
147  struct timehands *capth;
148  struct fftimehands *capffth;
149  unsigned capgen;
150  unsigned capcount;
151
152  /* State information. */
153  pps_params_t ppsparam;
154  pps_info_t ppsinfo;
155  pps_info_ffc_t ppsinfo_ffc;
156  int kcmode;
157  int ppscap;
158  struct timecounter *ppstc;
159  unsigned ppscount[3];
160  /*
161  * The following fields are valid if the driver calls pps_init_abi().
162  */
163  uint16_t driver_abi; /* Driver sets before pps_init_abi(). */
164  uint16_t kernel_abi; /* Kernel sets during pps_init_abi(). */
165  struct mtx *driver_mtx; /* Optional, valid if non-NULL. */
166  uint32_t flags;
167 };
168
169 void pps_capture(struct pps_state *pps);
170 void pps_event(struct pps_state *pps, int event);
171 void pps_init(struct pps_state *pps);
172 void pps_init_abi(struct pps_state *pps);
173 int pps_ioctl(unsigned long cmd, caddr_t data, struct pps_state *pps);
174 void hardpps(struct timespec *tsp, long nsec);
175
176 #else /* !_KERNEL */
177
178 static __inline int
179 time_pps_create(int filedes, pps_handle_t *handle)
180 {
181  int error;
182
183  *handle = -1;
184  error = ioctl(filedes, PPS_IOC_CREATE, 0);
185  if (error < 0)
186  return (-1);
187  *handle = filedes;
188  return (0);
189 }
190
191 static __inline int
192 time_pps_destroy(pps_handle_t handle)
193 {
194  return (ioctl(handle, PPS_IOC_DESTROY, 0));
195 }
196
197 static __inline int
198 time_pps_setparams(pps_handle_t handle, const pps_params_t *ppsparams)
199 {
200  return (ioctl(handle, PPS_IOC_SETPARAMS, ppsparams));
201 }
202
203 static __inline int
204 time_pps_getparams(pps_handle_t handle, pps_params_t *ppsparams)
205 {
206  return (ioctl(handle, PPS_IOC_GETPARAMS, ppsparams));
207 }
208
209 static __inline int
210 time_pps_getcap(pps_handle_t handle, int *mode)
211 {
212  return (ioctl(handle, PPS_IOC_GETCAP, mode));
213 }
214
215 static __inline int
216 time_pps_fetch(pps_handle_t handle, const int tsformat,
217  pps_info_t *ppsinfobuf, const struct timespec *timeout)
218 {
219  int error;
220  struct pps_fetch_args arg;
221
222  arg.tsformat = tsformat;
223  if (timeout == NULL) {
224  arg.timeout.tv_sec = -1;
225  arg.timeout.tv_nsec = -1;
226  } else
227  arg.timeout = *timeout;
228  error = ioctl(handle, PPS_IOC_FETCH, &arg);
229  *ppsinfobuf = arg.pps_info_buf;
230  return (error);
231 }
232
233 static __inline int
234 time_pps_fetch_ffc(pps_handle_t handle, const int tsformat,
235  pps_info_ffc_t *ppsinfobuf, const struct timespec *timeout)
236 {
237  struct pps_fetch_ffc_args arg;
238  int error;
239
240  arg.tsformat = tsformat;
241  if (timeout == NULL) {
242  arg.timeout.tv_sec = -1;
243  arg.timeout.tv_nsec = -1;
244  } else {
245  arg.timeout = *timeout;
246  }
247  error = ioctl(handle, PPS_IOC_FETCH_FFCOUNTER, &arg);
248  *ppsinfobuf = arg.pps_info_buf_ffc;
249  return (error);
250 }
251
252 static __inline int
253 time_pps_kcbind(pps_handle_t handle, const int kernel_consumer,
254  const int edge, const int tsformat)
255 {
256  struct pps_kcbind_args arg;
257
258  arg.kernel_consumer = kernel_consumer;
259  arg.edge = edge;
260  arg.tsformat = tsformat;
261  return (ioctl(handle, PPS_IOC_KCBIND, &arg));
262 }
263
264 #endif /* KERNEL */
265
266 #endif /* !_SYS_TIMEPPS_H_ */
Definition: timepps.h:53
Definition: timepps.h:39
Definition: timepps.h:45
Definition: timetc.h:46
Definition: kern_tc.c:156
Definition: timepps.h:119
Definition: timepps.h:69
Definition: timepps.h:34
Definition: if_fxpvar.h:78
Definition: timepps.h:107
Definition: timepps.h:113
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
