RTEMS  5.1
timeffc.h
1 /*-
2  * Copyright (c) 2011 The University of Melbourne
3  * All rights reserved.
4  *
5  * This software was developed by Julien Ridoux at the University of Melbourne
6  * under sponsorship from the FreeBSD Foundation.
7  *
8  * Redistribution and use in source and binary forms, with or without
9  * modification, are permitted provided that the following conditions
10  * are met:
11  * 1. Redistributions of source code must retain the above copyright
12  * notice, this list of conditions and the following disclaimer.
13  * 2. Redistributions in binary form must reproduce the above copyright
14  * notice, this list of conditions and the following disclaimer in the
15  * documentation and/or other materials provided with the distribution.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * $FreeBSD: head/sys/sys/timeffc.h 228856 2011-12-24 01:32:01Z lstewart $
30  */
31
32 #ifndef _SYS_TIMEFF_H_
33 #define _SYS_TIMEFF_H_
34
35 #include <sys/_ffcounter.h>
36
37 /*
38  * Feed-forward clock estimate
39  * Holds time mark as a ffcounter and conversion to bintime based on current
40  * timecounter period and offset estimate passed by the synchronization daemon.
41  * Provides time of last daemon update, clock status and bound on error.
42  */
44  struct bintime update_time; /* Time of last estimates update. */
45  ffcounter update_ffcount; /* Counter value at last update. */
46  ffcounter leapsec_next; /* Counter value of next leap second. */
47  uint64_t period; /* Estimate of counter period. */
48  uint32_t errb_abs; /* Bound on absolute clock error [ns]. */
49  uint32_t errb_rate; /* Bound on counter rate error [ps/s]. */
50  uint32_t status; /* Clock status. */
51  int16_t leapsec_total; /* All leap seconds seen so far. */
52  int8_t leapsec; /* Next leap second (in {-1,0,1}). */
53 };
54
55 #if __BSD_VISIBLE
56 #ifdef _KERNEL
57
58 #ifndef __rtems__
59 /* Define the kern.sysclock sysctl tree. */
60 SYSCTL_DECL(_kern_sysclock);
61
62 /* Define the kern.sysclock.ffclock sysctl tree. */
63 SYSCTL_DECL(_kern_sysclock_ffclock);
64 #endif /* __rtems__ */
65
66 /*
67  * Index into the sysclocks array for obtaining the ASCII name of a particular
68  * sysclock.
69  */
70 #define SYSCLOCK_FBCK 0
71 #define SYSCLOCK_FFWD 1
72 extern int sysclock_active;
73
74 /*
75  * Parameters of counter characterisation required by feed-forward algorithms.
76  */
77 #define FFCLOCK_SKM_SCALE 1024
78
79 /*
80  * Feed-forward clock status
81  */
82 #define FFCLOCK_STA_UNSYNC 1
83 #define FFCLOCK_STA_WARMUP 2
84
85 /*
86  * Flags for use by sysclock_snap2bintime() and various ffclock_ functions to
87  * control how the timecounter hardware is read and how the hardware snapshot is
88  * converted into absolute time.
89  * {FB|FF}CLOCK_FAST: Do not read the hardware counter, instead using the
90  * value at last tick. The time returned has a resolution
91  * of the kernel tick timer (1/hz [s]).
92  * FFCLOCK_LERP: Linear interpolation of ffclock time to guarantee
93  * monotonic time.
94  * FFCLOCK_LEAPSEC: Include leap seconds.
95  * {FB|FF}CLOCK_UPTIME: Time stamp should be relative to system boot, not epoch.
96  */
97 #define FFCLOCK_FAST 0x00000001
98 #define FFCLOCK_LERP 0x00000002
99 #define FFCLOCK_LEAPSEC 0x00000004
100 #define FFCLOCK_UPTIME 0x00000008
101 #define FFCLOCK_MASK 0x0000ffff
102
103 #define FBCLOCK_FAST 0x00010000 /* Currently unused. */
104 #define FBCLOCK_UPTIME 0x00020000
105 #define FBCLOCK_MASK 0xffff0000
106
107 /*
108  * Feedback clock specific info structure. The feedback clock's estimation of
109  * clock error is an absolute figure determined by the NTP algorithm. The status
110  * is determined by the userland daemon.
111  */
112 struct fbclock_info {
113  struct bintime error;
114  struct bintime tick_time;
115  uint64_t th_scale;
116  int status;
117 };
118
119 /*
120  * Feed-forward clock specific info structure. The feed-forward clock's
121  * estimation of clock error is an upper bound, which although potentially
122  * looser than the feedback clock equivalent, is much more reliable. The status
123  * is determined by the userland daemon.
124  */
125 struct ffclock_info {
126  struct bintime error;
127  struct bintime tick_time;
128  struct bintime tick_time_lerp;
129  uint64_t period;
130  uint64_t period_lerp;
131  int leapsec_adjustment;
132  int status;
133 };
134
135 /*
136  * Snapshot of system clocks and related information. Holds time read from each
137  * clock based on a single read of the active hardware timecounter, as well as
138  * respective clock information such as error estimates and the ffcounter value
139  * at the time of the read.
140  */
141 struct sysclock_snap {
142  struct fbclock_info fb_info;
143  struct ffclock_info ff_info;
144  ffcounter ffcount;
145  unsigned int delta;
146  int sysclock_active;
147 };
148
149 /* Take a snapshot of the system clocks and related information. */
150 void sysclock_getsnapshot(struct sysclock_snap *clock_snap, int fast);
151
152 /* Convert a timestamp from the selected system clock into bintime. */
153 int sysclock_snap2bintime(struct sysclock_snap *cs, struct bintime *bt,
154  int whichclock, uint32_t flags);
155
156 /* Resets feed-forward clock from RTC */
157 void ffclock_reset_clock(struct timespec *ts);
158
159 /*
160  * Return the current value of the feed-forward clock counter. Essential to
161  * measure time interval in counter units. If a fast timecounter is used by the
162  * system, may also allow fast but accurate timestamping.
163  */
164 void ffclock_read_counter(ffcounter *ffcount);
165
166 /*
167  * Retrieve feed-forward counter value and time of last kernel tick. This
168  * accepts the FFCLOCK_LERP flag.
169  */
170 void ffclock_last_tick(ffcounter *ffcount, struct bintime *bt, uint32_t flags);
171
172 /*
173  * Low level routines to convert a counter timestamp into absolute time and a
174  * counter timestamp interval into an interval in seconds. The absolute time
175  * conversion accepts the FFCLOCK_LERP flag.
176  */
177 void ffclock_convert_abs(ffcounter ffcount, struct bintime *bt, uint32_t flags);
178 void ffclock_convert_diff(ffcounter ffdelta, struct bintime *bt);
179
180 /*
181  * Feed-forward clock routines.
182  *
183  * These functions rely on the timecounters and ffclock_estimates stored in
184  * fftimehands. Note that the error_bound parameter is not the error of the
185  * clock but an upper bound on the error of the absolute time or time interval
186  * returned.
187  *
188  * ffclock_abstime(): retrieves current time as counter value and convert this
189  * timestamp in seconds. The value (in seconds) of the converted timestamp
190  * depends on the flags passed: for a given counter value, different
191  * conversions are possible. Different clock models can be selected by
192  * combining flags (for example (FFCLOCK_LERP|FFCLOCK_UPTIME) produces
193  * linearly interpolated uptime).
194  * ffclock_difftime(): computes a time interval in seconds based on an interval
195  * measured in ffcounter units. This should be the preferred way to measure
196  * small time intervals very accurately.
197  */
198 void ffclock_abstime(ffcounter *ffcount, struct bintime *bt,
199  struct bintime *error_bound, uint32_t flags);
200 void ffclock_difftime(ffcounter ffdelta, struct bintime *bt,
201  struct bintime *error_bound);
202
203 /*
204  * Wrapper routines to return current absolute time using the feed-forward
205  * clock. These functions are named after those defined in <sys/time.h>, which
206  * contains a description of the original ones.
207  */
208 void ffclock_bintime(struct bintime *bt);
209 void ffclock_nanotime(struct timespec *tsp);
210 void ffclock_microtime(struct timeval *tvp);
211
212 void ffclock_getbintime(struct bintime *bt);
213 void ffclock_getnanotime(struct timespec *tsp);
214 void ffclock_getmicrotime(struct timeval *tvp);
215
216 void ffclock_binuptime(struct bintime *bt);
217 void ffclock_nanouptime(struct timespec *tsp);
218 void ffclock_microuptime(struct timeval *tvp);
219
220 void ffclock_getbinuptime(struct bintime *bt);
221 void ffclock_getnanouptime(struct timespec *tsp);
222 void ffclock_getmicrouptime(struct timeval *tvp);
223
224 /*
225  * Wrapper routines to convert a time interval specified in ffcounter units into
226  * seconds using the current feed-forward clock estimates.
227  */
228 void ffclock_bindifftime(ffcounter ffdelta, struct bintime *bt);
229 void ffclock_nanodifftime(ffcounter ffdelta, struct timespec *tsp);
230 void ffclock_microdifftime(ffcounter ffdelta, struct timeval *tvp);
231
232 /*
233  * When FFCLOCK is enabled in the kernel, [get]{bin,nano,micro}[up]time() become
234  * wrappers around equivalent feedback or feed-forward functions. Provide access
235  * outside of kern_tc.c to the feedback clock equivalent functions for
236  * specialised use i.e. these are not for general consumption.
237  */
238 void fbclock_bintime(struct bintime *bt);
239 void fbclock_nanotime(struct timespec *tsp);
240 void fbclock_microtime(struct timeval *tvp);
241
242 void fbclock_getbintime(struct bintime *bt);
243 void fbclock_getnanotime(struct timespec *tsp);
244 void fbclock_getmicrotime(struct timeval *tvp);
245
246 void fbclock_binuptime(struct bintime *bt);
247 void fbclock_nanouptime(struct timespec *tsp);
248 void fbclock_microuptime(struct timeval *tvp);
249
250 void fbclock_getbinuptime(struct bintime *bt);
251 void fbclock_getnanouptime(struct timespec *tsp);
252 void fbclock_getmicrouptime(struct timeval *tvp);
253
254 /*
255  * Public system clock wrapper API which allows consumers to select which clock
256  * to obtain time from, independent of the current default system clock. These
257  * wrappers should be used instead of directly calling the underlying fbclock_
258  * or ffclock_ functions.
259  */
260 static inline void
261 bintime_fromclock(struct bintime *bt, int whichclock)
262 {
263
264  if (whichclock == SYSCLOCK_FFWD)
265  ffclock_bintime(bt);
266  else
267  fbclock_bintime(bt);
268 }
269
270 static inline void
271 nanotime_fromclock(struct timespec *tsp, int whichclock)
272 {
273
274  if (whichclock == SYSCLOCK_FFWD)
275  ffclock_nanotime(tsp);
276  else
277  fbclock_nanotime(tsp);
278 }
279
280 static inline void
281 microtime_fromclock(struct timeval *tvp, int whichclock)
282 {
283
284  if (whichclock == SYSCLOCK_FFWD)
285  ffclock_microtime(tvp);
286  else
287  fbclock_microtime(tvp);
288 }
289
290 static inline void
291 getbintime_fromclock(struct bintime *bt, int whichclock)
292 {
293
294  if (whichclock == SYSCLOCK_FFWD)
295  ffclock_getbintime(bt);
296  else
297  fbclock_getbintime(bt);
298 }
299
300 static inline void
301 getnanotime_fromclock(struct timespec *tsp, int whichclock)
302 {
303
304  if (whichclock == SYSCLOCK_FFWD)
305  ffclock_getnanotime(tsp);
306  else
307  fbclock_getnanotime(tsp);
308 }
309
310 static inline void
311 getmicrotime_fromclock(struct timeval *tvp, int whichclock)
312 {
313
314  if (whichclock == SYSCLOCK_FFWD)
315  ffclock_getmicrotime(tvp);
316  else
317  fbclock_getmicrotime(tvp);
318 }
319
320 static inline void
321 binuptime_fromclock(struct bintime *bt, int whichclock)
322 {
323
324  if (whichclock == SYSCLOCK_FFWD)
325  ffclock_binuptime(bt);
326  else
327  fbclock_binuptime(bt);
328 }
329
330 static inline void
331 nanouptime_fromclock(struct timespec *tsp, int whichclock)
332 {
333
334  if (whichclock == SYSCLOCK_FFWD)
335  ffclock_nanouptime(tsp);
336  else
337  fbclock_nanouptime(tsp);
338 }
339
340 static inline void
341 microuptime_fromclock(struct timeval *tvp, int whichclock)
342 {
343
344  if (whichclock == SYSCLOCK_FFWD)
345  ffclock_microuptime(tvp);
346  else
347  fbclock_microuptime(tvp);
348 }
349
350 static inline void
351 getbinuptime_fromclock(struct bintime *bt, int whichclock)
352 {
353
354  if (whichclock == SYSCLOCK_FFWD)
355  ffclock_getbinuptime(bt);
356  else
357  fbclock_getbinuptime(bt);
358 }
359
360 static inline void
361 getnanouptime_fromclock(struct timespec *tsp, int whichclock)
362 {
363
364  if (whichclock == SYSCLOCK_FFWD)
365  ffclock_getnanouptime(tsp);
366  else
367  fbclock_getnanouptime(tsp);
368 }
369
370 static inline void
371 getmicrouptime_fromclock(struct timeval *tvp, int whichclock)
372 {
373
374  if (whichclock == SYSCLOCK_FFWD)
375  ffclock_getmicrouptime(tvp);
376  else
377  fbclock_getmicrouptime(tvp);
378 }
379
380 #else /* !_KERNEL */
381
382 /* Feed-Forward Clock system calls. */
383 __BEGIN_DECLS
384 int ffclock_getcounter(ffcounter *ffcount);
385 int ffclock_getestimate(struct ffclock_estimate *cest);
386 int ffclock_setestimate(struct ffclock_estimate *cest);
387 __END_DECLS
388
389 #endif /* _KERNEL */
390 #endif /* __BSD_VISIBLE */
391 #endif /* _SYS_TIMEFF_H_ */
Definition: timeffc.h:43
