RTEMS  5.1
ti-lm25066a.h
1 /*
2  * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org>
3  * All rights reserved.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /*
11  * TI LM25066A
12  * http://www.ti.com/product/LM25066A
13  */
14
15 #ifndef TI_LM25066A_H
16 #define TI_LM25066A_H
17
18 #include <dev/i2c/i2c.h>
19
20 /*
21  * PM Bus Command interface.
22  *
23  * The keys are:
24  * IO : IO direction R=read W=write
25  * SZ : Size in bytes.
26  */
27 typedef enum
28 { /* IO SZ Name */
29  TI_LM25066A_OPERATION = 0, /* R 1 PMBus */
30  TI_LM25066A_CLEAR_FAULTS = 1, /* W 0 PMBus */
31  TI_LM25066A_CAPABILITY = 2, /* R 1 PMBus */
32  TI_LM25066A_VOUT_UV_WARN_LIMIT = 3, /* RW 2 PMBus */
33  TI_LM25066A_OT_FAULT_LIMIT = 4, /* RW 2 PMBus */
34  TI_LM25066A_OT_WARN_LIMIT = 5, /* RW 2 PMBus */
35  TI_LM25066A_VIN_OV_WARN_LIMIT = 6, /* RW 2 PMBus */
36  TI_LM25066A_VIN_UV_WARN_LIMIT = 7, /* RW 2 PMBus */
37  TI_LM25066A_STATUS_BYTE = 8, /* R 1 PMBus */
38  TI_LM25066A_STATUS_WORD = 9, /* R 2 PMBus */
39  TI_LM25066A_STATUS_VOUT = 10, /* R 1 PMBus */
40  TI_LM25066A_STATUS_INPUT = 11, /* R 1 PMBus */
41  TI_LM25066A_STATUS_TEMPERATURE = 12, /* R 1 PMBus */
42  TI_LM25066A_STATUS_CML = 13, /* R 1 PMBus */
43  TI_LM25066A_STATUS_MFR_SPECIFIC = 14, /* R 1 PMBus */
44  TI_LM25066A_READ_VIN = 15, /* R 2 PMBus */
45  TI_LM25066A_READ_VOUT = 16, /* R 2 PMBus */
46  TI_LM25066A_READ_TEMPERATURE_1 = 17, /* R 2 PMBus */
47  TI_LM25066A_MFR_ID = 18, /* R 3 PMBus */
48  TI_LM25066A_MFR_MODEL = 19, /* R 8 PMBus */
49  TI_LM25066A_MFR_REVISION = 20, /* R 2 PMBus */
50  TI_LM25066A_MFR_READ_VAUX = 21, /* R 2 MFR_SPECIFIC_00 */
51  TI_LM25066A_MFR_READ_IIN = 22, /* R 2 MFR_SPECIFIC_01 */
52  TI_LM25066A_MFR_READ_PIN = 23, /* R 2 MFR_SPECIFIC_02 */
53  TI_LM25066A_MFR_IIN_OC_WARN_LIMIT = 24, /* RW 2 MFR_SPECIFIC_03 */
54  TI_LM25066A_MFR_PIN_OP_WARN_LIMIT = 25, /* RW 2 MFR_SPECIFIC_04 */
55  TI_LM25066A_MFR_PIN_PEAK = 26, /* R 2 MFR_SPECIFIC_05 */
56  TI_LM25066A_MFR_CLEAR_PIN_PEAK = 27, /* W 0 MFR_SPECIFIC_06 */
57  TI_LM25066A_MFR_GATE_MASK = 28, /* RW 1 MFR_SPECIFIC_07 */
58  TI_LM25066A_MFR_ALERT_MASK = 29, /* RW 2 MFR_SPECIFIC_08 */
59  TI_LM25066A_MFR_DEVICE_SETUP = 30, /* RW 1 MFR_SPECIFIC_09 */
60  TI_LM25066A_MFR_BLOCK_READ = 31, /* R 12 MFR_SPECIFIC_10 */
61  TI_LM25066A_MFR_SAMPLES_FOR_AVG = 32, /* RW 1 MFR_SPECIFIC_11 */
62  TI_LM25066A_MFR_READ_AVG_VIN = 33, /* R 2 MFR_SPECIFIC_12 */
63  TI_LM25066A_MFR_READ_AVG_VOUT = 34, /* R 2 MFR_SPECIFIC_13 */
64  TI_LM25066A_MFR_READ_AVG_IIN = 35, /* R 2 MFR_SPECIFIC_14 */
65  TI_LM25066A_MFR_READ_AVG_PIN = 36, /* R 2 MFR_SPECIFIC_15 */
66  TI_LM25066A_MFR_BLACK_BOX_READ = 37, /* R 12 MFR_SPECIFIC_16 */
67  TI_LM25066A_MFR_DIAGNOSTIC_WORD_READ = 38, /* R 2 MFR_SPECIFIC_17 */
68  TI_LM25066A_MFR_AVG_BLOCK_READ = 39, /* R 12 MFR_SPECIFIC_18 */
69 } ti_lm25066a_cmd;
70
71 /*
72  * Real world converters. Page 46 of the datasheet discusses reading and
73  * writing telemtry data and obtaining the real world values. There are 8
74  * separate conversions using the same formula.
75  *
76  * The formula is:
77  *
78  * 1 -R
79  * X = - (Y x 10 - b)
80  * m
81  *
82  * X: the calculated "real world" value (volts, amps, watt, etc.)
83  * m: the slope coefficient
84  * Y: a two byte two's complement integer received from device
85  * b: the offset, a two byte two's complement integer
86  * R: the exponent, a one byte two's complement integer
87  *
88  * R in the table is inverted because we cannot store 0.01 in an int. This
89  * makes the equation:
90  *
91  * 1 Y
92  * X = - (- - b)
93  * m R
94  *
95  * The R value lets the integer result have decimal places.
96  *
97  * There are 8 conversion table entries listed in Table 41 of the
98  * data sheet. They are:
99  *
100  * 1. READ_VIN, READ_AVG_VIN, VIN_OV_WARN_LIMIT, VIN_UV_WARN_LIMIT
101  * 2. READ_VOUT, READ_AVG_VOUT, VOUT_UV_WARN_LIMIT
102  * 3. READ_VAUX
103  * 4.GND READ_IIN, READ_AVG_IIN, MFR_IIN_OC_WARN_LIMIT
104  * 4.VDD READ_IIN, READ_AVG_IIN, MFR_IIN_OC_WARN_LIMIT
105  * 5.GND READ_PIN, READ_AVG_PIN, READ_PIN_PEAK, MFR_PIN_OP_WARN_LIMIT
106  * 5.VCC READ_PIN, READ_AVG_PIN, READ_PIN_PEAK, MFR_PIN_OP_WARN_LIMIT
107  * 6. READ_TEMPERATURE_1, OT_WARN_LIMIT, OT_FAULT_LIMIT
108  *
109  * You need to provide 6 sets of conversion factors. Row 4 and 5 depend on how
110  * the device is wired. The driver will use the matching table row to convert
111  * the 2-complement 12 bit to a real world value.
112  */
113 #define TI_LM25066A_CONVERSION_SIZE (6)
114 typedef struct
115 {
116  int m; /* The slope coefficient */
117  int b; /* The offset */
118  int R; /* The inverted power of 10 of -R */
120
121 /*
122  * IO control interface.
123  */
124 #define TI_LM25066A_GET (I2C_DEV_IO_CONTROL + 0)
125 #define TI_LM25066A_SET (I2C_DEV_IO_CONTROL + 1)
126
127 /*
128  * IO data types.
129  */
130 typedef enum
131 {
132  TI_LM25066A_8BIT = 0,
133  TI_LM25066A_16BIT = 1,
134  TI_LM25066A_VALUE = 2,
135  TI_LM25066A_VALUES = 3,
136  TI_LM25066A_STRING = 4,
137  TI_LM25066A_RAW = 5
138 } ti_lm25066a_data;
139
140 /*
141  * Struct to move data into and out of the driver.
142  */
143 typedef struct
144 {
145  ti_lm25066a_cmd cmd;
146  ti_lm25066a_data type;
147  union {
148  uint8_t u8;
149  uint16_t u16;
150  int value;
151  int values[6];
152  char string[9];
153  uint8_t* raw;
154  } data;
156
157 /*
158  * Register the device.
159  *
160  * The conversions table has 6 columns.
161  *
162  * The values are an integer so the decimal_point value scales the value so it
163  * can fit in an integer with the required number of decimal points.
164  */
165 int i2c_dev_register_ti_lm25066a(const char* bus_path,
166  const char* dev_path,
167  uint16_t address,
168  const ti_lm25066a_conversion* const conversions,
169  const int decimal_points);
170
171 /*
172  * Get.
173  */
174 static inline int
175 ti_lm25066a_get(int fd, ti_lm25066a_io* io)
176 {
177  return ioctl(fd, TI_LM25066A_GET, io);
178 }
179
180 /*
181  * Set.
182  */
183 static inline int
184 ti_lm25066a_set(int fd, ti_lm25066a_io* io)
185 {
186  return ioctl(fd, TI_LM25066A_SET, io);
187 }
188
189
190 #endif
Inter-Integrated Circuit (I2C) Driver API.
Definition: ti-lm25066a.h:114
Definition: ti-lm25066a.h:143
